Starting Problems CBR1000F
Discussion in 'Motorbike Technical Discussion' started by Captain Trips, Dec 18, 2003.
  1. I'm tearing my hair out with starting problems with my Honda CBR1000 (92).
    When the starter is turning it will get sluggish and then stop as if the
    motor is seized or on a tight spot. It happened fairly suddenly too. One
    moment it just wouldn't start. Here is what I've had checked by a mechanic
    who can't figure it out atm either :( .
    Crankshaft is straight
    Camchain is fine.
    Cams are straight.
    Bearings are fine.
    When your turn motor by hand using a torque wrench it spins fine with no
    binding or tight spots.
    Tenshioner is ok.
    Replaced Primary Chain
    Tried new starter motor and still have the same problem.
    Tried new battery.
    Replaced all leads that go to the starter.
    Bike is in perfect tune. Once push started it runs fine.
    Considering myself and 2 mechanics can't figure out the problem it must be
    something weird. Any help would be appreciated as until its fixed I'm stuck
    riding a Kwaka GT550 and no one should have to go through that.
    Thanx in advance
    Rob
    CBR1000(in pieces)
    GT550 "The loaner"
  2. Captain Trips
    Gniewko Guest
    If you replaced your starter and it didn't help, it sounds like the
    problem is somewhere between your starter button and the starter.
    Check/replace your starter relay. The relay might be disconnecting
    after a bit of cranking and cause your problems.
    -Gniewko
    Gniewko, Dec 18, 2003
  3. Captain Trips
    Big Al Guest
    I'm agreeing with Wessman here, it sounds like an electrical problem.
    Have you checked the relay between the battery and the starter? I
    don't see it on your list. Crudded contacts are a common problem with
    high current relays, so you might want to add the replacement of that
    to your troubleshooting. Also check all the screw contacts for
    corrosion and tightness, although if you really have replaced all
    cables between battery and starter, these should be fine.
    This really sounds like a relay flaking out to me. Check the wiring
    diagram for all components and contacts between the battery and
    starter, in case you might have missed something. Good luck, and post
    again when you get it fixed!
    Big Al, Dec 18, 2003
  4. Captain Trips
    GB Guest
    What he said Captain Trips.
    Quick/easy test: take a set of jumper leads, and connect one
    end straight to the battery, and touch/hold the other end on
    the connector on the starter solenoid that the wire from
    the start button/start relay connects to.
    (You only need one side of the jumper leads, just leave
    the other colour hanging)
    Bike *should* start/run as if you'd pressed the starter
    button (let go when it's running and/or obviously not gonna
    happen, etc, etc).
    That cuts out all the middle men except for the starter
    solenoid itself.
    If that works, then you've nailed it down to something
    between the button, the relay and the wiring (inclusive).
    The solenoid is actually a mechanical combination of a
    solenoid and a relay. Sometimes those clag up in the 'relay'
    part (with soot, etc from arcing), and sometimes the
    solenoid won't throw out properly 'cos the grease inside
    went all gummy from age and weather.
    If you get exactly the same result (ie: it doesn't go) with
    a new starter/solenoid combination (are they an all-in-one
    unit?) then I figure the problem isn't in the starter/solenoid,
    so you should try the aforementioned test, then go hunting
    electrical gremlins as appropriate.
    G
    GB, Dec 18, 2003
  5. Captain Trips
    Try swapping the starter solenoid (if you haven't already). My '87
    CBR1000F had a CX500 solenoid fitted when I got it, so it mustn't be
    unheard of for them to die.
    BT Humble, Dec 18, 2003
  6. I suspect gas is leaking into the cylinders causing a hydraulic lock on
    start... next time it stops unscrew the spark plugs... watch for gas
    escaping... careful the liquid will be under extreme pressure...
    Larry L
    94 RC45 #2
    Have a wheelie NICE day...
    Lean & Mean it... the extended warranty in every corner of your life...
    If it wasn't for us the fast lane would rust...
    V4'S are music to the seat of my pants...
    1952 De Havilland Chipmunk...
    Yank and bank your brains loose...
    http://members.ebay.com/aboutme/-xlax-/
    http://home.comcast.net/~netters2/
    Larry xlax Lovisone, Dec 18, 2003
  7. Captain Trips
    Ahh, with all the extra newsgroups I thought you might have been a
    foreigner!
    Anyhoo, give Jason a ring at ACT Motorcycle Wreckers, he seems to know
    a thing or two about these older CBR motors:
    http://www.actmotorcyclewreckers.com.au/
    02 6297 7075
    If you tell him "The GPX250 Guy" sent you he'll probably laugh at you
    for a bit, then have a chat. ;-)
    BT Humble, Dec 19, 2003
  8. Captain Trips
    Johnnie5 Guest
    whats that , you let him have some GPX's ????
    Johnnie5, Dec 19, 2003
  9. Captain Trips
    Marty H Guest
    every laughs at you when you mention "The GPX250 Guy"
    well....it is harsh week
    mh
    Marty H, Dec 19, 2003
  10. snippety-snip
    Try jumpering your handy car battery directly across the starter terminals.
    If that works, you know to look at the wiring stuff going to the starter.
    George R. Young, Dec 19, 2003
  11. Captain Trips
    Mike.S Guest
    For once only one stupid bit of advice and the rest being useful, rather than the reverse *amazing*
    But yes, starter relay is where i'd point the finger, i had to take mine apart and go at it with a soft
    metal brush to clean all the rubbish off it, then put a bit more grease in the right spot. then the starter
    worked great. The only problem was i later blew the motor up for a unrelated reason.
    Mike.S
    Mike.S, Dec 19, 2003
  12. P.S. By the way, I hope you didn't have to pull the whole bike engine
    apart
    Yup gotta split the cases.
    Captain Trips, Dec 19, 2003
  13. Captain Trips
    GB Guest
    **** you!
    G
    GB, Dec 19, 2003
  14. Captain Trips
    Big Al Guest
    Ouch.
    Big Al, Dec 19, 2003
  15. If you paid for a starter motor, battery and all the other new parts as
    part of troubleshooting the problem I think you might want to try swapping
    in a different mechanic.
    Sounds like a bad ground or similar problem. You probably want to look
    for a voltage drop between battery positive and starter positive
    and between battery negative and starter ground. While you're at it,
    you might also want to look for mechanical losses when the starter
    engages (anything rubbing or otherwise creating excessive friction)
    though this seems unlikely.
    Rob Kleinschmidt, Dec 19, 2003
  16. Yes... hydraulic lock means no electric start and no push start... but
    if enough time passes between the electric start attempt and the push
    start effort the gas may have a chance to bleed pass the gaps in the
    rings...
    Larry L
    94 RC45 #2
    Larry xlax Lovisone, Dec 19, 2003
  17. Captain Trips
    matt weber Guest
    Two things... Get a big Ammeter, and see what happens to the starter
    draw.
    The thing I'd be looking at very closely is the overrunning clutch.
    That's the mechanism that disengates the starter once the engine
    starts. My guess is that is binding somewhere.
    matt weber, Dec 19, 2003
  18. When you push started the bike an ran it, did it idle the same way before
    Ran perfectly
    Captain Trips, Dec 20, 2003
  19. Check the starter motor clutch, the starter motor turns but the engine
    turns too slowly to start, happened 1 week before the warranty ran out.
    The only way I could start it was to roll start it.
    Mark.
    Mark Hutchison, Dec 20, 2003
  20. Captain Trips
    Don Fearn Guest
    It doesn't SOUND like a good idea to me.
    Really, I mean that literally. When I've done it (inadvertently every
    time), the motorcycle I did it to has made a sound that indicates it's
    a bad idea . . . . <shudder>
    pooder was here saying "not ok"
    I, Pooder, aPproved this Post . . . .
    Don Fearn, Dec 20, 2003
