starting bike after storage
Discussion in 'UK Motorcycles' started by dundonald, May 30, 2004.
  1. dundonald
    dundonald Guest
    I'm new to bikes so I can't help a mate but I thought I'd ask here. He has
    a Suzuki GSXR400. He's had it in his shed for a couple years. Last year he
    started it up ok but didn't take it on the road. This year he's wanting it
    on the road again. He's flushed and cleaned the tank out and replaced the
    air filter. The problem he's having is after bike has started, any turn of
    the throttle kills the engine. The bike only starts with choke too. I
    suspect something with the carbs, with fuel supply. Am I on the right lines?
    Any advice for him? Will the carbs need taking out and cleaning?
    Ta.
  2. dundonald
    His carb jets will be gummed up. The pilot jets are apparently clear,
    but as soon as the throttle is opened, the main jets come in to play
    and there's not enough fuel getting through.
    Carb removal, strip and de-gunge with carb cleaner is the only way,
    really.
    Pip, May 30, 2004
  3. dundonald
    tallbloke Guest
    Hey up Donald.
    You going to make EOSM then?
    tallbloke, May 30, 2004
  4. dundonald
    dundonald Guest
    Hey up mate. Where you located?
    I haven't been around UKRM for a while, where and when?
  5. dundonald
    dundonald Guest
    Thanks a lot Pip, much appreciated. Kinda what I thought, though I wasn't
    aware there were pilot and main jets.
  6. dundonald
    Monkey Guest
    Wot he said - we had no end of trouble getting my girlfriend's GS500 started
    after a long sit in her dad's garage, for this very reason.
    One other point to bear in mind: if the bike has been run for any length of
    time with blocked carbs - depending on where the various breather hoses /
    overflows go - some of the fuel may have found its way into the airbox, and
    made a mess of that shiny new air filter. Took us a while to figure out that
    was why the bike still wasn't running after getting the carbs cleaned.
    Monkey, May 31, 2004
  7. dundonald
    dundonald Guest
    Thanks for the heads up Monkey.
    dundonald, May 31, 2004
  8. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember dundonald
    Urgh...
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 31, 2004
  9. Yup. I have that problem more and more, these days, when renovating
    SOBs. It's the additives in unleaded petrol that makes it worse,
    apparently.
    Replacing, quite probably. I've given up trying to clean carbs when
    they're gummed up. You can get the jets sorted, but all the little
    galleries in the carbs will still be blocked. A total *complete* carb
    strip and ultrasound cleaning may be the only way.
    From the sublime to the ridiculous - I'm restoring a Z200 single, and I
    bought a second donor bike for the carb (an a few other bits) as the one
    on the bike emitted that horrible varnishy small when I drained the
    fuel.
    The Older Gentleman, Jun 1, 2004
  10. dundonald
    "Gloss Paint Smell of Death"
    sweller, Jun 1, 2004
  11. It was somewhere around Barstow, on the edge of the desert, when the
    (The Older Gentleman) saying
    something like:
    <makes note not to clean underwear in petrol>
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jun 1, 2004
  12. dundonald
    dundonald Guest
    Lol!
    dundonald, Jun 1, 2004
  13. dundonald
    dundonald Guest
    (The Older Gentleman) thoughtfully
    wrote:
    Cheers TOG. I'll advise him to try cleaning and if no success, start looking
    at used prices.
