Starter not starting occasionally
Discussion in 'Motorbike Technical Discussion' started by zeeexsixare, Feb 25, 2006.
  1. zeeexsixare
    zeeexsixare Guest
    Bike in question: CBR600 F2
    Sometimes my starter won't work. The first time it happened 2 weeks
    ago, the instrument lights got dim, and the engine cranked once or
    twice, very slowly, about 1Hz. After letting it sit for a day, it
    started up just fine later and for many starts afterwards. Yesterday,
    I rode 40 miles (far longer than my usual runs) and stopped for gas.
    After filling up, I went to start... no go.
    The sound is like "bzzz" of a door buzzer in the old movies. It's
    coming from what I think is the battery under the seat; I can feel it
    when I stick my hand under there. I'm guessing it's the starter
    relay/solenoid that's giving up the ghost. Anyways, I was able to use
    the 15 feet of downslope at the gas station to get the bike started
    again, and I rode another 130 miles, and made it to my destination. I
    then tried to start it... started right up, no hesitation, no problems.
    Does this sound like a starter relay/solenoid problem? Are they easy
    to fix/replace? Are there generic parts available?
    Phil, Squid-in-Training
  2. It sounds more like an absolutely fucked battery to me.
    The Older Gentleman, Feb 25, 2006
  3. zeeexsixare
    fweddybear Guest
    How old is the battery? Have you checked it under load to see if it
    still provides the necessary amperage you need to turn over the starter?
    sounds like your battery isn't holding a charge....for very long..
    Fwed
    fweddybear, Feb 25, 2006
  4. zeeexsixare
    FB Guest
    How old is your battery? It's possible that the plates are all covered
    with lead sulfate so the battery only takes what is called a "surface
    charge". Batteries used for vehicles are different from stationary
    batteries which have large hard metal plates. Instead, vehicle
    batteries use soft porous lead in the plates to allow the electrolyte
    to pentrate, soaking into the porous lead.
    The battery will have enough beans to start the engine *once* and then
    it goes dead when it's sulfated, because the electrolyte cannot
    penetrate the hard sulfate to deep charge the battery.
    There is also the possibility that humidity and road salt down there in
    Florida have corroded the wiring connections so badly the starter
    solenoid soesn't get enough voltage to hold the solenoid contacts
    closed.
    But my first bet is an old sulfated battery.
    FB, Feb 25, 2006
  5. zeeexsixare
    MadDogR75 Guest
    Sounds like a jammed or bad solenoid.
    The lights dimming means the starter was drawing current.
    The intermittant nature of the problem wispers that the battery has the
    power, but something is locking the works somewhere.
    The next time it happens 'bump` her once and try again.
    If you get the start it's a problem in the mechanics, not the battery.
    MadDog
    "R75/5 Forever!"
    MadDogR75, Feb 25, 2006
  6. zeeexsixare
    John Johnson Guest
    This fault-finding chart will come in handy whether it's the battery or
    something else:
    http://electrosport.com/electrosport_fault_finding.html
    To use such a diagram, you really want to know that your battery is good
    first. You could take it somewhere and have them load-test it. If you
    wanted to check it at home, I suggest:
    1) if the battery is 5 or more years old, just replace it. I know that
    there are people here that see this as an unnecessary expense ("Why
    replace a perfectly good battery!?! My batteries last 1500 years!!!"),
    but batteries _do_ age, and 5 years seems to be an age after which
    batteries start to fail without prior warning.
    2) check the battery case for swelling, cracks, etc. If it's bulging or
    misshapen, replace it. If not, wipe the top off with a rag. Be careful
    not to short-circuit the battery! If the terminals have junk on them,
    clean it all off. Battery terminal cleaning is pretty straightforward,
    and I imagine that instructions are easily available online, so I won't
    go into that here.
    3) If you know how to use a Volt-meter, go ahead and measure the rest
    voltage of the battery (ideally without anything connected to it). As I
    recall, a Voltage below about 12.7 indicates that the battery is not
    fully charged. If you've just charged it, then you you need to figure
    out why the battery isn't fully charged the problem might be the
    battery, or it might be the charging system.
    There's more that you can do, but the above checks are pretty quick and
    usually reliable. Here's some more reading about lead-acid batteries. I
    checked them over quickly for accuracy, and they seem about right
    (though lots of the information is not directly relevant). As always,
    caveat lector.
    http://www.windsun.com/Batteries/Battery_FAQ.htm
    http://xtronics.com/reference/batterap.htm
    No matter what the problem is, you should inspect and clean all
    accessible electrical connections (including frame ground/return lines!)
    while you are in there checking your wiring. It's tedious but easy work,
    and clean electrical connections help prevent all sorts of problems.
    Later,
    John
    John Johnson, Feb 26, 2006
  7. zeeexsixare
    zeeexsixare Guest
    When it's not working, it's really not working. When it's working, it
    works perfectly. There is no in-between or "weak" starting. It's
    either very strong and reliable, or almost completely dead. I go up to
    4 or 5 days without riding and it starts up just as strong as if I
    start it after leaving it for one day.
    zeeexsixare, Feb 26, 2006
  8. zeeexsixare
    zeeexsixare Guest
    I will check the battery. But I'm leaning away from that because the
    vast majority of my trips are 2-mile trips, short enough to not
    recharge the battery all that fully, and it starts up virtually every
    time. It's also never had a problem starting up multiple times because
    I don't notice that some moron has flipped my kill switch until I've
    cranked it for a good 10 seconds or so...
    That brings up another question. Generally speaking, how long should a
    bike be able to crank on a fully-charged battery? IOW, should a bike
    be able to crank for 30 straight seconds with the kill switch on?
    I see what you mean by sulfated.
    There's no road salt down here in inland Florida, so it's not likely
    the problem. But the solenoids for the seat-release have gotten old
    and don't retract all the way, so it's possible the starter solenoid
    has too.
  9. zeeexsixare
    zeeexsixare Guest
    I think it's a bad solenoid, too. The lights are strong when I turn
    the key to on, so I don't think the battery is weak or anything. I
    jiggled a bunch of cables and stuff near the buzzing area to see if
    anything would move, but it didn't help... maybe a tap would have done
    the trick.
  10. zeeexsixare
    zeeexsixare Guest
    Thank you John for the informative post. I'll examine what I can with
    my voltmeter when I get back into town.
  11. zeeexsixare
    zeeexsixare Guest
    Does anyone know if generic starter solenoids and relays are available
    and are easy to fix? I am not keen at all to going to my local
    impolite repair shop.
  12. zeeexsixare
    John Johnson Guest
    1) availability of 3rd-party spares varies by bike, and I don't remember
    what sort of bike you have. Including quoted material, or re-stating the
    relevant information, is helpful.
    2) ease of installation/repair of components varies by bike. See #1, and
    get the factory service manual if you don't already have it; it's an
    invaluable service aid.
    3) You aren't forced to purchase from your local shop, even if you want
    genuine spares. For example, I've purchased Honda components for my
    VFR750 (bodywork and a Reg/rect, respectively) from:
    http://www.dynamohumm.com/Scripts/default.asp
    http://ridenow.com/
    There's lots of places out there, some better than others. Finding and
    sorting them is left as an exercise for your search engine (this group's
    archives, and bike-specific web-fora, often contain people's
    recommendations on what shops are good or bad).
    Later,
    John
  13. zeeexsixare
    FB Guest
    If you know for sure that the solenoid is NFG (not functionally good),
    you might try a motorcycle salvage yard instead of a Honda $tealer$hip.
    You could probably take the starter solenoid to some auto parts store
    where there isn't a crowd standing in line demanding quick service and
    if you could find some friendly old fart who's willing to help, maybe
    he would look for a starter solenoid for you.
    But, if you go to some busy store, and tell the guy behind the computer
    that you're looking for a solenoid for your CBR600 F2 he's going to
    tell you to go to a Honda dealer.
    You might check the online catalog at www.denniskirk.com for
    replacement solenoids and you might also try the Tucker Rocky online
    catalog too.
    You might try googling for generic solenoids in online electronics
    supply catalogs, but you have to know what you need in terms of stud
    sizes and the correct number of terminals for the solenoid coil.
    Most car solenoids probably would have much larger main terminals than
    the Honda solenoid would have. Car solenoids would probably have
    5/16ths or even 3/8th's inch studs, while your Honda solenoid probably
    has 1/4 inch studs for the main terminal that carry the battery power.
    Then there is the solenoid coil grounding system. Some solenoids will
    have a terminal for power input to the coil and a terminal for the
    solenoid ground. Other solenoids will get the coil power from one of
    the main terminals and use a ground wire to complete the circuit. Some
    solenoids will have a power input wire to the solenoid coil and a
    ground wire coming out of the relay coil.
    So you need to know the input voltage, the stud sizes and the wiring
    arrangement of the solenoid coil itself.
    If you remove the starter solenoid and carefully inspect it, you may
    find that it has some corrosion inside, or main contact arcing that
    prevents it from making good contact.
    Or, the problem might be at the starter button itself. Sometimes the
    Mickey Mouse starter button won't be making good contact and that would
    make the solenoid coil chatter.
    If you take the starter switch apart to clean it, be careful you don't
    lose any of the tiny parts inside. Honda won't sell them separately.
    FB, Feb 26, 2006
  14. zeeexsixare
    FB Guest
    If you're traying to start the engine, and it's in a good state of
    tune, it should start within about 5 seconds, even if it's cold. If it
    doesn't immediately start, wait 15 or 20 seconds and crank for 5 more
    seconds.
    I was at a brake shop having my car's brake rotors reground and there
    were two Mexicans there trying to start a Yamaha. They cranked that
    poor thing continously for minutes at a time. I tried to explain to
    them they they would be very unhappy if they had to buy a new starter
    from the Yamaha $tealer$hip. They ignored my advice and kept on
    cranking. The engine never started.
    Extended cranking is not advisable due to heat buildup inside the
    starter. It's probably about a 500 watt device, and you can imagine how
    hot five 100 watt light bulbs can get. It's just that the starter heats
    up a lot slower. It could conceivably melt the solder in the
    commutator, and then where would you be? At the Honda $tealer$hip,
    finding out that a new starter cost $750?
    If you want to check the capacity of your battery, then check the
    capacity of your battery in a logical way.
    Suppose you have a fully-charged 8 ampere hour battery. It should
    produce a continuous 8 amperes for an hour without the output voltage
    dropping below 12 volts.
    You could check your owners manual for the wattage of your head light
    and tail lights and running lights and instrument lights and add all
    those wattage and divide by 12
    to figure out the amperage involved in the lighting loads.
    Suppose the normal lighting load is 100 watts. 100 / 12 = 8.333.
    So, if you have 100 watts of lighting load and an 8 ampere hour battery
    and a voltmeter, you should be able to turn the headlights on and leave
    them on for an hour
    and come back and check the voltage and it should still be more than 12
    volts.
    If I was going to run a battery capacity test like that I would remove
    the battery from the motorcycle and hook up some headlight bulbs of
    known wattage that weren't installed in the motorcycle to avoid
    damaging other parts of the electrical system or melting the plastic
    parts of the fairing.
    Like two 55/60 watt halogen bulbs from your car would be about the
    right load for the battery capacity test.
    Alternatively, you could take the battery down to your local Honda
    $tealer$hip and have a mechanic test the battery on his motorcycle
    battery charger/tester. But, keep in mind that the Honda $tealer$hip
    wants to sell you a battery inthe worst way.
    FB, Feb 26, 2006
  15. zeeexsixare
    fweddybear Guest
    Another place to look is on ebay...you can find some good deals there as
    I have, but as with a junk yard, you will also need to be careful and ask
    questions....
    Fwed
    fweddybear, Feb 26, 2006
  16. zeeexsixare
    Gary Walker Guest
    I assume you were the OP on this topic. If not, I'm
    sorry. I see to recall from my initial read of the post
    that the starter operation is intermittent, and other
    electrical items go dark(somewhat paraphrased).
    I really don't even recall the bike make, but I will
    offer my own similar experience(s) with my Honda
    Valkyrie.
    The Valkyrie's had/have a bad starter button. It app-
    arently (mis)behaves in many ways, but when mine
    acts up, it will either spin the starter very slowly, which
    makes you think the battery is near death, or not spin
    it at all.
    Second, aside from the start/nostart issue, this button
    has a cutout circuitry to dark the lights for the starting
    current draw.
    This failure to sometimes spin the starter was particularly
    prevalent when the bike might sit for a long period in the
    hot sun. Usually, just playing with the start button would
    cure the situation. I only noticed the dark lights during the
    night time riding, and again, playing with the starter butt-
    on would bring them back to life.
    I know your bike is not a Valkyrie, but you might look
    at this area for a possible similar cause/failure.
    Thanks,
    Gary
    Gary Walker, Feb 26, 2006
  17. It's a CBR, so maybe... I'll look into it, thanks.
    Phil, Squid-in-Training, Feb 27, 2006
  18. zeeexsixare
    Gary Walker Guest
    Sure.... It's probably got the same switch/assembly as
    the Valk, or at least, the same manufacturer.
    Let us know what you discovered.
    Gary
    Gary Walker, Feb 27, 2006
  19. Still sounds like a battery/charging problem. The buzzing sound
    is likely to be the starter relay.
    When the battery gets low, there's enough power to engage
    the relay but as soon as it tries to activate the starter, the
    starter sucks up all the power and the relay drops out again.
    As soon as it drops out, there's enough power to engage
    again and the cycle repeats.
    Sounds like either an intermittant charging problem, a tired
    battery or maybe just trying to power too many accessories
    and lights in low speed traffic.
    First check your battery voltage to see if the battery's
    good or on it's last legs. If it's good, recheck when you
    have the problem.
    One nice gadget you can get is a Radio Shack "alternator/battery
    tester" for $5.95 . This is a 6 LED gizmo that'll show you voltage
    in 1/2 volt increments. It's easy to wire this into an electrical
    system for a permanant display. All you need is a hot wire that's off
    when the engine's not running. For $5.95 it'll tell you quite a bit
    about your battery and charging.
    Rob Kleinschmidt, Feb 28, 2006
  20. That is useful. And cheap.
    The Older Gentleman, Feb 28, 2006
