Starter clutch problem/ Honda Nighthawk 750
Discussion in 'Motorbike Technical Discussion' started by Andy, Apr 27, 2007.
  1. Andy
    Andy Guest
    Hello, I have recently taken my Honda Nighthawk 750 out of storage
    after it sat for a couple of years. I did all the recommend things
    before putting it away so I was hoping for a relatively easy start.
    However, I find that my starter motor just spins away without even
    turning the engine over.
    I took out the starter motor; the pinion gear looks fine. I know the
    engine is not seized because I can get it to turn over (but not start)
    by rolling the bike and popping the clutch. So I think I must have a
    starter clutch that is slipping.
    So, question A: why would the starter clutch start acting like this
    after sitting for a couple years? It was working fine before I put
    the bike away. Question B: how difficult is it to get at and replace?
    My clymer manual is not so clear, but it looks like I would have to
    practically take the whole engine apart!
    please help if you can and thanks in advance.
    Andy
    Andy, Apr 27, 2007
  2. Andy
    Albrecht Guest
    It would be nice if you'd mention what year your Nighthawk is.
    I looked at the 1982/1983 models. Fixing the starter clutch would be a
    piece of cake on those models.
    But the 1991 and on Nighthawks have a nightmare starter clutch on a
    jackshaft that drives the crankshaft via a chain.
    Albrecht, Apr 27, 2007
  3. Bad Bike Pixies.
    On the DOHC 16v 750, the one wih hydraulic tappets, you do. It's a
    common fault on these lumps and a right PITA.
    The Older Gentleman, Apr 27, 2007
  4. Andy
    Albrecht Guest
    If your Nighthawk is a 1991 or later model, with a starter that has
    planetary gear reduction, you might just have a problem with
    the reduction drive unit. You can see two of the planetary gears on
    the starter motor drawing at www.partsfish.com.
    Yamaha Virago models were plagued with reduction gear problems.
    The nightmare late model Nighthawk starter clutch design has some sort
    of weird directional dog coupling device that seems to connect the
    starter clutch to the sprocket that turns the chain that turns the
    crankshaft. And the dog coupling thingamajig is preloaded by four
    dished springs that are called "belleville washers".
    Those springs are item # 6 on the starter clutch drawing. I have seen
    stacks of preloaded belleville washers used as clutches.
    The whole idea of the chain drive starter clutch on a shaft buried
    deep inside the engine is to get the alternator off the end of the
    crankshaft.
  5. Andy
    Andy Guest
    Thanks for the informative replies! I do unfortunately have a 1991
    model nighthawk, which apparently has the starter clutch buried inside
    the engine.
    Now concerning the planetary gears, If you mean the large ring gear
    with two smaller gears inside, that is inside the starter motor, I'm
    pretty sure those are fine. I took out the starter motor and took the
    end cap with the pinion gear off to reveal these gears and they didn't
    appear damaged. So I dabbed a little fresh grease in there and put the
    motor back together. I did not try applying current to the motor while
    it was out of the bike to see if the pinion gear was actually
    spinning. But I could spin the inner gear that connects to the
    alternator shaft freely with my finger, which suggests to me that the
    clutch was not engaged, i.e. not working. Though I don't understand
    what actuates the starter clutch, so I don't know if that's a valid
    conclusion.
    After looking at the manual in more detail its clear I need
    essentially disassemble the motorcycle enough to lift the motor out of
    the frame, then disassemble the crankcase to even get a look at that
    clutch. I'm feeling pretty overwhelmed and undertooled to attempt a
    job like that. I'm sure I could get it apart but not at all sure I
    could put it all back together!
    Andy
    Andy, Apr 27, 2007
  6. Andy
    Albrecht Guest
    That's what the engineers did to get the alternator off the end of the
    crankshaft to make the engine narrower.
    Typically, an operating planetary gear reduction system has a
    stationary ring gear, and two or three planetary gears have to follow
    the internal teeth of the ring gear, while they turn a sun gear
    attached to the final output shaft.
    The planetary gears have to be mounted to a metal "spider" and it's
    usually the spider that breaks, spot welds come loose, or the
    planetary gears' axles break off the spider.
    You might want to google for some Nighthawk 750 forums to see what
    problems other owners are encountering with the reduction drive
    starter.
    Automatic transmissions often have planetary gear reduction systems,
    and the ring gears are allowed to spin freely while the transmission
    is in neutral. Then the ring gears are braked to a stop by
    hydraulically actuated bands and the planetary gears have to start
    turning the sun gear, and the car goes.
    Ah, yes. Starter clutches were invented by the psychotic Doctor
    Frankenstein and his equally looney assistant, Professor Sprag...
    Refer to the STARTER CLUTCH diagram on www.partsfish.com or www.bikebandit.com.
    When the engine is running, #9 CHAIN turns #4 SPROCKET (21T). The
    sprocket has splines, so it turns the
    #7 SHAFT, ALTERNATOR.
    #3 CLUTCH OUTER is also splined to the # 7 shaft, so the outer clutch
    has to turn with the shaft.
    If the outer clutch is typical of many Frankenstein starter clutches
    (1), there are three cylindrical rollers which are pushed away from
    the protruding end of the # 1 GEAR by centrifugal force. The # 1 gear
    sits motionless on the #18 BEARING (25X30X20) as the alternator shaft
    turns at high RPM.
    #18 bearing is a needle bearing with very small diameter rollers, and
    it's probably getting plenty of oil from the engine.
    (Gawd help you if that bearing seizes and locks up the starter clutch
    while you're riding down the highway at speed. The starter clutch will
    try to backdrive the starter at very high RPM and the rear wheel may
    lock up as the starter refuses to turn.)
    When the engine is NOT running, three little springs push the
    cylindrical rollers in the #3 outer clutch down onto the protruding
    end of the #1 gear. If you hear a "whiz ching!" sound when you turn
    your ignition key off, that's the sound of the rollers dropping down
    onto the end of the #1 gear.
    (It's possible that your starter clutch is slipping because the
    cylindrical rollers are stuck in their ramps. You might try putting
    the transmission into high gear and rolling the motorcycle back and
    forth a little bit.)
    When you push the starter button, the starter turns its own little #1
    GEAR (shown on the STARTER MOTOR
    drawing. The small #1 gear turns the larger #1 gear, and since that
    gear is in contact with the three cylindrical rollers, the #3 clutch
    outer has to turn the #7 alternator shaft.
    (1) Another diabolical alternative to the starter clutch with
    cylindrical rollers is the Sprag clutch, which looks like an ordinary
    roller bearing. The devilish twist is that the rollers don't roll,
    they slip when the bearing is turned one way, and they jam the inner
    and outer races together when the Sprag clutch is turned the other
    way.
    The dastardly effect of Sprag clutches is that they are slipping when
    the rider isn't trying to start the engine and they wear out *when not
    in use*!
    I sympathize with you, Andy. I never would have bought my Yamaha
    FZR-1000 if I had known about the buried starter clutch. It's the
    first thing that goes into the crankcase, and the last thing that
    comes out, after tearing the engine down!
    Albrecht, Apr 28, 2007
  7. Find a breaker and buy a complete engine. There are loads of Nighthawks
    out there.
    Do an engine swap. A decent used lump can't be more than a very few
    hundred dollars, and you could easily spend that on gaskets, fluids and
    a few special tools.
    It sounds silly, just for a small fault, it's probably the easiest
    solution.
    The Older Gentleman, Apr 28, 2007
  8. Andy
    Bruce Farley Guest
    You said that it does push start. If the starter was working when the
    bike was last used the problem could be that the caps on the springs
    that push the rollers are stuck, and that getting the oil hot while
    running the engine for awhile might clear up the problem. You would have
    nothing to loose if you wanted to push start and go for a 10-20 mile
    ride and maybe the starter would work afterwards.
    Bruce Farley, Apr 29, 2007
  9. Andy
    Andy Guest
    Thanks everyone for the replies...this a great list! I have not gotten
    it to push start yet, just rolled it up and down the driveway with the
    plugs out. After it's been sitting for awhile it usually takes some
    cranking to start it... so my plan is to get a couple of guys to push
    me up a really big hill and try to get it to start on the way
    down...I'm HOPING that bruce is right, the hot oil and vibrations
    might do the trick.
    Andy
    Andy, May 1, 2007
  10. Andy
    Andy Guest
    Well, I have tried push starting while rolling down a hill, and can
    get the motor to turn over plenty of times and can smell the gas
    flowing. No sign of ignition however. So I am assuming I have no
    spark. However, I don't know if that problem is related to the starter
    clutch problem. I get no spark when just spinning the starter motor
    with the ignition on. I don't have a convenient way to see if there is
    any spark while rolling the bike downhill. Is it possible the
    alternator isn't spinning because of the starter clutch being
    disengaged?? Or is it more likely a bad coil or broken wire?
    Andy, Jun 16, 2007
  11. Andy
    fweddybear Guest
    It sounds to me like you have no spark too.... but a simple test would
    let you know definitely. remove a pspark plug and hold it so that you can
    see if you get a spark while you try starting it (assuming you have a push
    button to start the bike). If no spark, then you need to trace it back to
    see if you are getting spark to the coil(s). If no, then keep going back
    until you find spark, then replace the component that does not give you
    spark during testing.
    Hope this helps..
    Fwed
    fweddybear, Jun 16, 2007
  12. Andy
    Andy Guest
    Thanks for taking the time to explain all that.
    The battery is brand new and was fully charged, so I'm pretty sure
    that wasn't the problem. Main fuse has to be fine if the lights work
    and the starter motor spins, which they do.
    I can inspect and clean the kill switch and sidestand switch and
    connections everywyere, but it's impossible to really troubleshoot
    them with the bike rolling, which is the only way I could get the
    crankshaft to turn and activate the pulse generating
    mechanism...right? I will also check the the voltage on the ignition
    coils with a multimeter.
    If only I had a kick-starter! or one of those cranks, like on an old
    model T.
    Andy
    Andy, Jun 17, 2007
