Stall problem
Discussion in 'Motorcycle Technical Discussion' started by Roddy Meatstick.............., Dec 24, 2006.
  1. Why is it that my lights dim a little when I rev up the motor from idle.
    I distinctly see the head light dim when I increase the rpm from idle.
    Sometimes it also stalls like the coil voltage went too low and it lost
    the spark. Sometimes it stalls when I turn the blinker on at a stop. I
    have to rev it a little to put the blinker on. It always starts right
    back up again. It's a 1996 Suzuki Intruder 1400. Does it sound like a
    flaky regulator?
  2. Check your battery.
    Venture Rider, Dec 24, 2006
  3. On second thought, perhaps your alternator is not producing enough
    electrical power, and you are actually sucking on the battery. Connect
    a volt meter to your battery, and see if you measure over 13 volts
    when the engine is running. Try it at different RPMs. Low voltage
    would indicate that your alternator is not pushing enough juice.
  4. I'm no expert, but shouldn't there be a rectifier or voltage regulator
    hooked up to the stator that keeps the current the same? So if the
    headlight is changing depending on the RPM maybe the rectifier is bad.
    On second thought, if that were true, the headlight should get brighter
    when you rev so what the hell do I know.
    SS.
    Sergeant Stedanko, Dec 24, 2006
  5. There are a number of possibilities why your lights would go dim as you
    rev up the engine.
    You might be "sinking" the alternator's battery charging current into
    an old sulfated battery. When you "sink" current into a short circuit
    or an overload, it turns into heat and the voltage applied to the
    circuit drops dramatically, as you have noticed when your lights
    dimmed.
    Or, the battery might have a lot of lead particles in the bottom of the
    cells, shorting the plates together. You can see the lead sludge if you
    remove the battery and look up through the clear plastic case.
    Old batteries that have been dehydrated may have bulges in the sides of
    the case, or the battery may have the "starved horse" look, with ribs
    sticking out and the sidewalls are curved inward.
    Even maintenance free batteries will eventually lose their sealed-in
    water and begin to bulge or look like a starving horse.
    Your generator is a permanent magnet type. It has stationary copper
    windings and a rotating magnet called a "rotor" attached to the
    crankshaft. It's possible that the nut holding the rotor is loose and
    the rotor isn't turning with the crankshaft.
    One of the things that I was taught when I went to aircraft electrician
    school in the Air Force was not to *ass*sume that the alternator was
    turning just because the engine was running. If the alternator doesn't
    turn with the engine, it cannot generate electricity.
    Suzuki bolted the rotor on the tapered end of your expen$ive
    crankshaft. But it still might not be turning when the engine is
    running.
    That would be bad news on your Intruder, which has a woodruff key
    locating the rotor in one position. A broken woodruff key would chew up
    the end of your crankshaft.
    I had battery charging problems as you describe on my GS-1100. It
    turned out that the alternator rotor was loose on the crankshaft, and
    eventually the inner taper of the rotor wore so badly the rotor wasn't
    turning as the crankshaft spun. The stub on the end of the crankshaft
    got all chewed up and I will have to replace that part if I ever have
    the crankshaft rebuilt or straightened.
    Then there is the problem with poor quality crimped connectors and
    mismatched electrical connectors in the charging system.
    Suzuki and the rest of the manufacturers use crimped electrical
    connections for speed in production and quick replacement of parts in
    the $tealer$hip$.
    Crimped connections are poor connections, compared to permanent
    soldered connections. Many owners cut off the crimped connections when
    they have problems with them and they solder the wires directly
    together.
    Suzuki and the rest of the manufacturers buy alternators and rectifier
    regulators that have connectors that don't match, so they have to add a
    little jumper pigtail between the alternator and the rectifier
    regulator and the bike's wiring harness and that just adds more poor
    quality connections to the system.
    The poor quality connections heat up because they make poor cotact from
    being loose or corroded. You may find that the plastic connector shell
    is melted, or plastic sleeving used for insulation has turned black
    from overheating.
    You may notice that the wires coming from the alternator stator are
    blackened for an inch or more back from the bullet connectors where
    they attach to the motorcycle's wiring harness. It's time to cut off
    those connectors and solder the wires directly together.
    Don't overlook the possibility that your ignition switch is the
    problem. If you run the engine for ten minutes and then feel the back
    side of the ignition switch and it is too hot to touch, the ignition
    switch needs to be replaced because it's making bad contact.
    The rectifier regulator on your Intruder is a shunt type device. When
    voltage rises above a certain voltage (usually around 14.5 to 15.0
    volts) a zener diode will trigger a silicon control rectifier to ground
    one of the three phases in the stator to ground for half a sine wave.
    Then the SCR stops conducting until the next high voltage event, which
    occurs as soon as the voltage on the next phase rises above the zener
    set point.
    This cuts power output from the three phase stator in half, because
    each normally ungrounded phase generates AC power and returns it to the
    next phase in rotation
    A, B, C, etc.
    If you do a continuity test on the stator, you should get around 1 ohm
    or less from phase to phase to phase, and infinity to to the crankcase.
    If you get any reading from phase to the crankcase, you have a shorted
    stator.
    The rectifier part has six power diodes which can be checked with an
    ohmmeter. The three AC input pins on the rectifier will conduct
    positive to the power output pin, and negative to the case or the
    ground lead. All three readings will be the same. If you don't get a
    reading on one of the six continuity checks, the diode is blown out and
    the output from the rectifier will be cut in half.
    The charging test has to be done with a fully charged battery, in good
    condition.
    The headlight must be on, too. As you rev the engine up, voltage should
    rise from 12.0 volts to 14.5 or 15 volts and then drop back sharply to
    12 or 12.5 volts. That tells you that the zener diode and the SCR are
    working.
    Then, roll off the throttle and let the engine idle and rev the engine
    up again. You should see the same rise from 12 volts to 14.5 or 15
    volts, followed by the same sharp drop in voltage every time you rev
    the engine up and let it idle down.
    If the regulator doesn't cycle as described, the zener or the SCR is
    toast.
    Electrosport USA makes better quality aftermarket rectifier regulators
    to replace the outrageously expen$ive original equipment part.
    Potage St. Germaine, Dec 24, 2006
  6. Roddy Meatstick..............
    John Johnson Guest
    Check your battery first. You won't be able to diagnose anything else in
    the electrical system without a good battery. If your battery is more
    than 4-5 years old, you would probably do well simply to replace it.
    After the battery, check your voltage regulator/rectifier. Actually, go
    to the electrosportusa website, download their electrical
    troubleshooting flowchart, and go to town.
    Get back to us with more questions, or with information after you've run
    through the flowchart and gotten info.
    Later,
    John
    John Johnson, Dec 24, 2006
  7. Roddy Meatstick..............
    alan&alon Guest
    the headlight dimming is normal that shows your regulator is working sounds
    to me like a battery problem if your bike was to start hard ill bet it
    wouldnt turn over but a few tries. either way hook a volt meter up to your
    battery on dc volts observe what you start with,while cranking,at idle
    ,above idle and with your turn signals on at idle should stay in the 13 to
    14 v area when running no matter what you do
    alan&alon, Jan 5, 2007
