Stainless welding...
Discussion in 'Classic Motorbikes' started by Guest, Dec 8, 2008.
  1. Guest
    Guest Guest
    Cracks in the Beemer's exhaust again (groan), and it needs an MOT. It's
    gone by the bracket, and there is stainless reinforcing under the outer
    sheet (where the two mounting bolts go in, so I reckon I might get away
    with welding it, but...
    I've got the Argon, but only 0.8mm stainless wire for the MIG. Casting
    about on eBay etc., this seems the smallest wire easily found. Is it
    sensible for thin stainless? I've got some to practice on (old flue from
    the boiler), and my mild steel welding is OK-ish, but before spending
    ages on more futile spatterings*, what doth t'team think?
    Yes, I know this isn't uk.diy ...
    Cheerth,
    S.
    *I suppose otherwise I need to find someone nearby with a TIG set.
    Guest, Dec 8, 2008
  2. Guest
    Have a look at eBay item 220318147087 as an easier alternative. It is a
    brazing product.
    Hog, Dec 8, 2008
  3. Guest
    Rusty_Hinge Guest
    The message <>
    If you're anywhere near Attleborough in Norfolk, Nick Paravanni on the
    Bunns Bank industrial site on the Diss road is an ace SS welder.
    He'll tell you anything you need to know.
    Rusty_Hinge, Dec 8, 2008
  4. Guest
    Guest Guest
    Sadly not (Bristle, CUBA), but as it's now searchable, someone
    may benefit in future!
    Cheers,
    S.
    Guest, Dec 8, 2008
  5. Guest
    Guest Guest
    Thanks for that - duly 'watching' in eBay in case.
    Trouble is it needs 1400 deg. and I don't have oxy-propane, although I
    do have Mapp gas, which might work (with the right nozzle). Has to be
    said though that the exhaust is quite brittle enough already*, so I
    don't want to make matters worse.
    Having cast around a bit more, it looks like 0.8mm is the smallest gauge
    S/S wire easily available (as well as being wot I've got). I think I'll
    experiment on the gash thin bits I've got, and see if I can tame the
    welder. Annoyingly, it's a Clarke reel & doesn't say what grade of S/S
    it's supposed to be for. Regrettably, I think this is the Christmas
    project.
    Cheers,
    S.
    *Wiki has this: "MAPP like all of the Liquified Petroleum gasses is not
    appropriate for welding of steel, due to the high concentration of
    hydrogen in the flame. The hydrogen infuses into the molten steel and
    renders the welds brittle." <http://en.wikipedia.org/wiki/Mapp_gas>.
    I know brazing is not welding, but it might be an issue. Mind you, it
    could hardly make the thing worse at the moment.
    Guest, Dec 8, 2008
  6. Guest
    crn Guest
    What guage wire do you normally use ?.
    If your gun is set up for 1mm you should fit the correct liner and
    nozzle for 0.8mm.
    crn, Dec 8, 2008
  7. I've used it on 1mm microbore tubing and 1mm sheet, using the normal
    "Coogar" mix gas, an' all. Making custom rack for a pushbike.
    worked OK.
    Austin Shackles, Dec 8, 2008
  8. Guest
    Rusty_Hinge Guest
  9. Guest
    Guest Guest
    Sounds like I just need to practice, er, lots.
    Thanks, I think! :)
    Guest, Dec 8, 2008
  10. Guest
    Guest Guest
    Liner is PTFE, intended for .6 or .8mm, and I have both .6 and .8 tips.
    I usually use .6, for small mild steel jobs. It works well even on
    rebar, as long as I give it enough welly, and the weld penetration is
    adequate for the light duty stuff I need to do. I know it's no good for
    big fabrication work.
    The welder's probably good for around 130A (officially 150), and has a
    good wire feed mech. that doesn't slip, although the controller circuit
    is badly designed (fed off the welding Xfmer, so the voltage bounces
    around dreadfully).
    The last s/s project I tried with it rusted at the weld (same wire). I
    may have had the Argon down too low tho, and I didn't pre-heat it. Will
    try more gas, preheat and faster wire this time (and practice on scrap
    first).
    Cheers,
    S.
    Guest, Dec 8, 2008
  11. Guest
    Guest Guest
    That's a very kind thought. I'll see what I can find gas-wise & go from
    there. My plumbing soldering's fine, so brazing/silver soldering can't
    be all that hard. Meanwhile, that scrap SS is in my sights...
    Guest, Dec 8, 2008
  12. Guest
    Rusty_Hinge Guest
    The message <>
    Brazing and silver-soldering (white metal brazing, basically) is a
    doddle with gas.
    Rusty_Hinge, Dec 9, 2008
  13. need to get the feed/power ratio right, as ever - more important the thinner
    the material.
    Austin Shackles, Dec 9, 2008
  14. Guest
    Brian Hill Guest
    It needs to be welded with a TIG setup by an experienced welder or you'll
    end up with a mess. Take it from a Yank Master Welder and lifelong Triumph
    rider.
    BTW- Merry Xmas from across the pond.
    Brian
    Brian Hill, Dec 24, 2008
  15. Guest
    Depends on the quality of weld expected. I've repaired my Guzzi's SS
    collector box with a MIG welder using 0.8mm wire. The weld went black
    but cleaned up icely with a wire brush. Still hasn't failed for some
    6-10K miles.
    <fx: touches wood [fnarr]>
    Pip Luscher, Jan 9, 2009
  16. Guest
    Guest Guest
    That's what I'm going to do. The collector box split a while back on the
    same exhaust set, and was MIG or TIG welded beautifully by an expert
    (didn't see it done, but think it was TIG). I've done SS with 0.8mm in
    the past with mixed results (went a bit rusty), but the plan this time
    is to heat it well with MAPP gas first, then turn the argon well up - I
    don't think I had enough gas flow previously.
    Santa brought me an auto-darkening shield for Christmas, which I've been
    playing with already - wonderful bit of kit, should've got one years
    ago. I've also got some thin scrap SS to practice on this time, which I
    didn't have before.
    And anyway, it wouldn't be an SOB if I didn't fettle it myself...
    Guest, Jan 9, 2009
  17. Guest
    Yeah, I bought one of those shortly after I bought my new welder (back
    in the days when I had money) and they make life *so* much easier.
    Indeed.
