ST1050 not starting
Discussion in 'UK Motorcycles' started by Catman, Dec 9, 2007.
  1. Catman
    Catman Guest
    FOAK, got a problem with the Sprint. Started fine yesterday, today it
    just spins. Doesn't sound 'right', like the engine is not even turning.
    Shipping it to the shop tomorrow I hope, but any suggestions?
    TIA
    www.cuore-sportivo.co.uk
    Catman, Dec 9, 2007
  2. Catman
    If you can't tell if the engine's turning or not, it's a bit difficult
    to suggest anything. If the starter motor's turning but the engine
    isn't, it could be the old starter sprag clutch thingy or sonething
    similar. Definitely a dealer job. Still under warranty, is it?
    _______
    ..'_/_|_\_'. Ace (bdotrogers a.t compaqnet.fr)
    Ace, Dec 9, 2007
  3. Catman
    Put the battery on the charger first, check if it's feeling a bit low...
    Timo Geusch, Dec 9, 2007
  4. Catman
    Paul G Guest
    Hand over the end of the exhaust, hit the starter, if you can't feel
    anything then the engine is probably not spining!
    Paul
    Paul G, Dec 9, 2007
  5. Catman
    Pete Fisher Guest
    <praces bet on sprag clutch>
    | Pete Fisher at Home: |
    Pete Fisher, Dec 9, 2007
  6. Catman
    Tosspot Guest
    Isn't the time honored solution to hit it with a hammer?
    Tosspot, Dec 10, 2007
  7. Catman
    Catman Guest
    That certainly is what seems to be happening.
    Sadly, no
    Catman, Dec 10, 2007
  8. Catman
    Catman Guest
    Checked with a jump pack.
  9. Catman
    Catman Guest
    Oooh, good idea. Posting at the bottom would be good to ;)
    Cheers
  10. Catman
    Catman Guest
    I had considered that, had I know WTF it was
  11. Catman
    deadmail Guest
    If it is this, it could be because it's cold etc.
    A solution could be to bump start, change oil to a diesel oil (high
    detergent) and then bump start again and get it good and hot. Hopefully
    this will flush all crap out of the system and get it functional again.
    I've had limited success with this with K series BMWs. (worked once,
    failed once)
    deadmail, Dec 10, 2007
  12. Catman
    It's a piece of hardened, shaped steel attached to a wooden handle,
    usually.
    Pip, Dec 10, 2007
  13. Catman
    Catman Guest
    I was considering bump starting it, but felt that would not be massively
    reliable at work where the car park is uphill.
  14. Catman
    Catman Guest
    s/what/where ;)
  15. Catman
    Catman Guest
    Indeed it is. We have a local gravitational anomaly.
  16. Catman
    dog Guest
    dog, Dec 10, 2007
  17. Catman
    But your office must be a good 40 miles from Dodger's.
    ogden, Dec 10, 2007
  18. Catman
    Tosspot Guest
    In a time honored REME parlance, "It's a tricky problem, I need a bigger
    hammer".
  19. Catman
    Catman Guest
    Brute Force: if it doesn't work, you're not using enough.
  20. Catman
    Ex-Pat Andy Guest
    Is this the same REME that has the regimental/corps motto of "If we can't
    fix it, we **** it"?
    Ex-Pat Andy, Dec 11, 2007
