SR250: Brake light and neutral indicator stuck on
Discussion in 'Australian Motorcycles' started by mark.maslen, Dec 7, 2006.
  1. mark.maslen
    mark.maslen Guest
    Hi All,
    I've got a 1985 SR250 that's copped a bit of a hammering in the four or
    so years I've owned it. Actually I bought it from a guy who posted a
    for-sale ad in this newsgroup and have lurked ever since.
    At the moment, the brake light is always on. Less importantly, so is
    the neutral indicator light. I disengaged the rear brake light switch
    (one of those ones where there's a spring connected to the brake pedal,
    attached to a kind of unit with a matchstick kind of thing). I prodded
    and pushed the matchstick-resembling piece but nothing happened. It's
    made of metal, and when I moved it near the frame a spark jumped across
    which suggests that it is live. I'm pretty sure that's not meant to be
    the case.
    I did a bit of online research and a bad earth somewhere looks like it
    could be the cause. I had a look at the wiring diagram and checked
    where the earths were: The negative battery terminal, the starter
    motor, the spark plug (of course!) and then one near the ignition, one
    down near the front sprocket (I think this is the earth for the neutral
    switch). Given the neutral light is stuck on, I had a good look at
    this one which was indeed a bit loose. However when I made sure this
    had good contact, the neutral light would be *on*, even though the bike
    was in gear, and when I disconnected it the neutral light went off.
    This had no effect on the brake light. There's also an earth in each
    switch housing on the handlebars, but I kind of think it's unlikely
    that anything would have gone wrong with those ones - a fair
    assumption?
    Every other earth that I've found looks OK, and I have cleaned them
    all. Not sure what else could be wrong... a short circuit? Dodgy
    neutral switch? Something else? I loosened up the front brake pretty
    heavily and the light stayed on, so I'm pretty sure that the brakes are
    not actually always on. At the moment I've got the fuel tank and seat
    off and the headlight out of its chamber and haven't noticed any bare
    wires or anything...
    If anyone has ideas for other things to look for it would be
    appreciated.
    On a related note I'm planning to make a website with some photos and
    basic descriptions of what I'm doing in future jobs. There's a long
    "to do list" and I'm treating it as a bit of a project to learn
    maintenance, though a lot of the jobs will get put off till winter 2007
    when I won't be riding as much. If people are interested I'll put some
    details here as I do things (or post a link to the website once I've
    made it).
    Happy riding,
    -- Mark
  2. mark.maslen
    J5 Guest
    damn lurkers
    if you disconnect the rear switch and the light is still on then you have a
    prob with the front switch
    the brake light and neutral light are independant
    the neutral light is prob a switch which goes to ground when in neutral
    sounds like a bad switch
    look at the front switch , sounds either stuck on , if you have too much
    freeplay
    in the front lever the switch can stay on as its not pressed in far enough
    J5, Dec 7, 2006
  3. mark.maslen
    Hammo Guest
    Greetings
    The SR250 has a single wire (green?) going to the neutral light switch that
    is behind the left hand engine cover. The cover is the metal thing that is
    on level with the chain, not the plastic side covers.
    That has more than likely moved in or out enough to give an open circuit (or
    died). Try screw it in a few turns or out a few turns, ONLY after you have
    recorder how many turns left or right you are doing, or else it'll be hit
    and miss (though that can work too).
    The rear brake may just need adjusting too. Look at it closely and you'll
    see that it has the ability to rotate on a plastic screw out (i.e. Make it
    longer). Adjust that (assuming the spring is still inside the switch?).
    Eventually the light should go off.
    If it is the front switch, go buy another microswitch from Jaycar or Yamaha
    as you can do much with them.
    Happy trails....
    Hammo
    Hammo, Dec 7, 2006
  4. mark.maslen
    Mark Guest
    Thanks J5 and Hammo. I had a look at the front brake and indeed it was
    that switch that had come loose. It was about a two minute job. Man
    that's annoying, I'd really stripped the bike down trying to trace the
    problem. At least I learnt a lot about it in the process :)
    I am familiar with the wire Hammo menitioned - it's sky blue according
    to the manual - that goes to the neutral switch. When I connect this
    the neutral light comes on (no matter what the gear). So I think the
    switch might be dodgy. I unscrewed it to have a look, and then oil
    started dripping out everywhere and I decided to postpone that job
    until my next oil change.
    Thanks again,
    -- Mark
    Mark, Dec 9, 2006
  5. mark.maslen
    sharkey Guest
    Yeah, it'll be not so much a switch as a little contact thingy which
    touches another thingy in the gearbox (often a little leaf spring on
    the selector shaft) ... so the other end of it is in whith all the oil
    and shit.
    For little tiny jobs like replacing an O-ring or whatever, it's often
    easier to lean the bike over the other way so you can get to them
    without dumping all the oil. Steady as she goes.
    -----sharks
    sharkey, Dec 9, 2006
  6. mark.maslen
    Hammo Guest
    Have a shot at putting it in gear and then screwing it in until the light
    goes off. It may be a tedious task (or as you suspect, rooted).
    It is indeed a simple switch so it is potential gummed up with all sorts of
    gunk.
    All the best
    Hammo
    Hammo, Dec 9, 2006
  7. mark.maslen
    Hammo Guest
    Is it that SR?
    WOW!
    Often_intrigued at hot mail com
    Cheers
    H
    Hammo, Dec 11, 2006
  8. mark.maslen
    Mark Guest
    G'day Bruce,
    Yep the old SR is still going, despite two crashes (one was more of a
    slip than a crash) and a bit of time with minimal riding. Needs a bit
    of work done but nothing too major. And Hammo has seen the bike too?
    Small world!
    -- M
    Mark, Dec 12, 2006
  9. mark.maslen
    Hammo Guest
    Do you need a carby?
    Cheers
    H
    Hammo, Dec 13, 2006
  10. mark.maslen
    Mark Guest
    G'day Hammo,
    Don't need a carby at this stage - about six months ago I took it off
    and a mate of mine at work helped clean it with the aid of a lot of
    Nulon. Before that the jet was blocked and was causing problems. I
    will keep it in mind though if my current one bites the dust.
    Bruce - my new email is firstname dot lastname at gmail dot com. You
    may have sent the email to my old address....
    -- M
    Mark, Dec 14, 2006
