Sprockets & Torque & Cruising Speed & MPG & Chains
Discussion in 'Motorbike Technical Discussion' started by Bill Miller., Aug 18, 2008.
  1. Bill Miller.
    Bill Miller. Guest
    Not stupid at all you ignorant ****. The trail section of the dual
    sprocket required a small additional length of chain and that was how
    you changed it from street to trail use, you added the fucking small
    extra length you dodo. Now whether or not that agrees with your
    twisted, screwed mind, I could care less. Why don't you just go crawl
    off into a corner and die and do the world a favor.
    No frothing at the mouth, just wondering why your parents didn't abort
    an imbecile and piece of human shit like yourself. No definition was
    made. The oinly thing wrong was TOG's inability to understand the
    English language. He says he's a big expert but is actually nothing
    but a total asshead masquerading as someone who has half a brain.
    Just a pathetic of bastard at best....
    Bill
    Bill Miller., Aug 22, 2008
    #41
  2. Bill Miller.
    Bill Miller. Guest
    He probably will never get it. His head's too full of monkey shit to
    have room to absorb anything elswe. Just another old dumbass Limey
    prick acting like he really matters. A sad and pathetic old washed up
    wrinkly geezer who probably looks at 8x10 photos of English Bulldogs
    and masturbates. HAHAHAHAHA
    #42
  3. Bill Miller.
    Bill Miller. Guest
    Thanks for the intelligent treatise on gearing. It's refreshing to
    see a post that not just volumes of hot air blowing across my computer
    monitor.
    Bill
    #43
  4. That's absurd. � � � � � � � � � � � � � � �
    ÃÄÈËÎÐÓÖØÙ, Aug 22, 2008
    #44
  5. Bill Miller.
    Who Me? Guest
    And your incessant bitching about it is just as pointless as the original
    spew.
    It is what it IS. Take it or leave it.
    Nothing you do will make the situation any better. Don't ADD to the noise.
    PS Trim your quotes, please. Re-spewing isn't good either !!
    Who Me?, Aug 22, 2008
    #45
  6. Bill Miller.
    TOG@Toil Guest
    An engine will produce the amount of power it produces. If it's been
    dyno'd at (say) 20bhp max, then that maximum power output will not be
    changed by gearing.
    Good gearing will allow best use to be made of that power, sure, and
    incorrect gearing will have exactly the opposite effect (as Bill
    Miller is likely to discover), but you don't change an engine's power
    output by shoving a different gear cluster behind it.
    TOG@Toil, Aug 22, 2008
    #46
  7. Bill Miller.
    TOG@Toil Guest
    Ah, like: "I never said anything about two master links?"
    Ri-i-ght.
    #47
  8. Bill Miller.
    A.Clews Guest
    Thus spake Hans-Christian Becker () unto the assembled multitudes:
    In other words, the power at the wheel is not the same as that at the
    crankshaft...
    A.Clews, Aug 22, 2008
    #48
  9. Who *gives* a dead rat's ass about inaccurate statements or omissions
    and all this "b-b-b-but *you* said bla bla" crap?
    #49
  10. Bill Miller.
    TOG@Toil Guest
    He likes doing it.
    #50
  11. True. You win an all day sucker, so go *suck it*.
    #51
  12. Bill Miller.
    A.Clews Guest
    Thus spake Mark Olson () unto the assembled multitudes:
    Perhaps I phrased it badly. The power at the crankshaft is constant at a
    given RPM no matter what lies between it and the back wheel, and the
    frictional losses in the gear train and transmission contribute to the
    reduction in power at the back wheel, not the gear ratioing as such. I'm
    pretty sure that's what TOG was getting at too.
    #52
  13. Bill Miller.
    TOG@Toil Guest
    Effectively, yes. There are other issues, like at a given rpm in a low
    gear, you probably won't have the throttle open so much as you might
    in a higher gear at the same road rpm, and so the engine will be
    putting out less power, but the fact remains that you can't change an
    engine's potential, maximum or whatever horsepower by a gearing
    change. Torque is another matter.
    If getting more power out of an engine was simply a matter of gearing,
    then tuners would not exist.
    #53
  14. Bill Miller.
    TOG@Toil Guest
    You, evidently. Oh, and Bill, of course. :))
    Look, it's the same old story. Bill is given the answers he seeks,
    which aren't the answers he *wants*, and goes postal.
    He's been told (including by you) that any drastic gearing-up changes
    are a bad idea, given that (as you pointed out) a TW200 doesn't have
    much power to begin with. But he won't take that. He goes postal.
    <Thinks> Didn't we have some similar fantasist here, a while back,
    going on about how raising the gearing of his (very) old Honda CB350
    would make it do 120mph? This is similar.
    He's told that shoving a second master link in a drive chain is a bad
    idea (which it is), and again he goes postal.
    And he hasn't even got the bike anyway. He's told that leaving it
    until he actually gets and rides it in stock trim is the best option.
    And... he goes postal.
    It's funny, really.
    #54
  15. An engine produces no more power than that which is necessary to equal
    the applied load, which may be no more than pumping air in and exhaust
    out and ovwercoming internal friction, if the engine isn't connected
    to an external load.
    A chassis dyno simulates aerodynamic drag and rolling resistance. The
    engine must produce enough thrust at the tire contact patch to
    overcome the simulated load.
    If the load opposing the thrust exceeds the thrust, the engine will
    not reach the RPM at which the thrust is maximum and the maximum power
    output will NOT be achieved.
    #55
  16. Yeah, it's about as funny as debating with a 12-year old.
    Whatever gets you off...
    #56
  17. If the load opposing the thrust exceeds the thrust, the bike would go
    backwards.
    The Older Gentleman, Aug 22, 2008
    #57
  18. Or to put it another way, all engines reach a point when load and thrust
    are balanced. And they stop accelerating.
    But you still can't change an engine's potential maximum power output by
    gearing.
    #58
  19. Bill Miller.
    Bill Miller. Guest
    spew. It is what it IS.  Take it or leave it.
    Hmm, one of those who just rolls over and accepts things, no matter
    how negative and uses the shopworn phrase "It is what it IS, take it
    or leave it." Are you also the kinda guy who'll grab his ankles just
    because someone offers to kiss you first? Develop some spine WHO ME
    and then maybe you'll know WHO YOU ARE.
    Bill
    #59
  20. Bill Miller.
    Bill Miller. Guest
    Actually, you haven't said anything in this entire thread worth two
    farthings pus brain. Give it up, crawl back into your corner, put on
    the dunce cap and be a good goney.
    Ri-i-i-i-i-i-i-i-i-i-i-i-i-i-i-i-i-i-i-ght!
    #60
