Sprint ST (955)
Discussion in 'UK Motorcycles' started by Jeremy, Sep 16, 2005.
  1. Jeremy
    Jeremy Guest
  2. Jeremy
    I had one for nearly four years and liked it a lot, but it did have
    its fair share of problems and the finish didn't put up with my
    cleaning schedule (i.e. never) too well. but a very nice bike to ride
    and both comfortable and economical for ling distances. On a steady
    cruisy run I could get well over 200 miles from a tankful.
    Doesn't look bad, and that late a model will have had a lot of the
    early[1] problems pre-sorted, IYSWIM.
    [1] Mine was a 99 model, one of the first batch, and was affected by a
    number of recalls.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Sep 16, 2005
  3. Jeremy
    Jeremy Guest
    Sounds good - is there any difference between the Sprint RS and ST other
    than the fairing?
    jeremy
    '02 Fazer 600 in blue
    jeremy0505 at gmail.com
  4. Jeremy
    Jeremy emerged from their own little world to say
    Yes. The RS has a conventional swing arm rather than the Sprint's copycat
    of the Honda VFR single sided one. Apparently, the design of the swingarn
    allows the exhaust to be routed so that it does not heat the colour
    cordinated panniers. This gives a fully kitted ST a narrower profile than
    some other sports tourers with luggage fitted.
    I rode an RS when they first came out. I liked the bike but as Ace said,
    the build quality at that time was a bit hit and miss so I went for a Honda
    CBR600. On reflection, I think I would've enjoyed the RS more.
    I think Triumph have worked on their quality issues since 1999 and a more
    recent bike would be a better proposition.
    The other thing to bear in mind is that the ST cost 25% more than the RS.
    Therefore, IMO anyone buying a new one is more likely to pay for the nice
    to have extras such as heated grips & luggage. As a used bike you will
    probably get better value to the pound with the ST: the value of the extras
    will not make a huge difference to the resale value of the bike.
    wessie, Sep 16, 2005
  5. Yes indeed. Not really a sports bike but quite comfortable. Mines an )3
    in silver. The front forks are a bit naff but otherwise OK.
    It's got the gel seat which is good for the pillion. It got the panniers
    wich where about 900 quid IIRC. It's also low mileage. These bikes tend to
    do high mileage because they are easy to ride all the time. Make sure its
    had the fuel connector recall. That's the only recall mines had. The build
    quality is a lot better than the early ones. The panniers will leak, you
    will have to fit dog leg levers unless you have hands like an ape. They
    handle well, the suspensions quite soft and compliant and the motors very
    nice. If a bit lacking in top end go. A really good bike for two up.
    eric the brave, Sep 16, 2005
  6. Jeremy
    Jeremy Guest
    Noted, ta.
    jeremy
    Jeremy, Sep 19, 2005
  7. Jeremy
    Jeremy Guest
    Been leafing through my stack of Bike magazines and pulling out all the
    road tests of the Sprint ST and VFR.
    Seems like the Sprint gets it on "character" whreas the VFR on
    refinement (and some refer to it as blandness).
    The report I waas reading (from 2001) said the Sprint started to weave
    (although I think this was with luggage) at around 100 and that the
    gearbox was a bit clunky with a tendency to lead to missed gears.
    Any probs like this?
    jeremy
  8. Jeremy
    What's wrong with the forks?
    £500 for the hard panniers, but presumably you're including the box in
    that price too.
    Mine never had that. Just ask Timo.
    Yup. Plastic bags required. But they will fall off. The mounting
    clip/lock is a right royal PITA. So easy to not have it properly
    secured.
    Oh, really? Ook oook ook.
    I never found this. Mine was good for an indicate 165 == genuine
    150mph, which I found perfectly acceptable.
    Aye, not bad, but the grab handles are too low and far back for many
    shorter people. Better, when the luggage is attached, to use the
    pannier handles, provided they're on properly (see above).
    _______
    Ace, Sep 19, 2005
  9. Jeremy
    Jeremy Guest
    <g>
    jeremy
  10. Jeremy
    I never did. 25000 miles with hard panniers on[1] and nary a wobble.
    Mebbe the top box is worse.
    [1] They made naff all difference to either fuel consumption or
    performance so I never took 'em off.
    _______
    Ace, Sep 19, 2005
  11. Jeremy
    Jeremy Guest
    OK but which colour is best?
    I rather like the green but the silver looks good too (and there is a
    3,000 miler for sale at Hughenden M40 nr Oxford).
    Not keen on the red.
    jeremy
  12. Jeremy
    If you need to ask, you clearly won't understand the answer, which is
    'the one true colour', of course.
    _______
    Ace, Sep 19, 2005
  13. Jeremy
    Jeremy Guest
    They do them in *purple*?
    jeremy
  14. Ace wrote
    Well put Sir.
    steve auvache, Sep 19, 2005
  15. Jeremy
    Jeremy says...
    You need a fucking slap
    Lozzo, Sep 19, 2005
