spongy (disc) brake
Discussion in 'Motorbike Technical Discussion' started by Dave, Sep 4, 2007.
  1. Dave
    Dave Guest
    Geez, if that's the best they could do for handling I'm glad I don't own any
    more Yamahas... this bike is *NOT* a great handler. I'd call it "acceptable
    for a cruiser bike that's 27 years old". I've got new rubber on it and it's
    ok but really needs a fork brace and some sort of modern front suspension
    with rebound dampening.
    Although the motor is reliable, would it be any less reliable if they used a
    90-degree offset for the firing angle and got rid of all that shitty
    vibration? It doesn't help the handling to have the steering components
    mounted on squishy rubber bushings so your arms and hands don't go numb.
    Just my 2 cents.
    Dave, Sep 17, 2007
  2. Dave
    Ron Gibson Guest
    Well yeah of course. I owned mine in 1980. Back then the 4 cylinders
    were so top heavy if you looked at them cross eyed they'd fall over.
    The vibration was terrible. Stock tuning sucked but a little work went a
    long way.
    I have a road I use for testing. It's out in the boonies and is new
    asphalt with several sharp turns and even two S's. I put a big conti on
    the rear and adjusted the shocks and whatever else I could. I used to
    have a blast driving down that road as it was a short cut to where I
    lived.
    Bottom line it was an old motorcycle - old design. But Yamaha certainly
    sold a lot of them over what 14 years? Having said that I'd never buy
    another one. Starting 1981 or so the technology advanced too fast to make
    it a wise choice anymore.
    Like you said the vibration was awful and the power band was absurd. My
    little 83 XS400RK would run circles around one. I use that around town.
    I like the 49MPG :)
    Ron Gibson, Sep 18, 2007
  3. That's a bit more like it.... ;-)
    The Older Gentleman, Sep 18, 2007
  4. Dave
    Dave Guest
    I've got a '73 CB750K3 Honda. It's heavy, but when you get used to the fact
    that you need an extra gear down going into the curves to pull the bike up
    you get used to it. The suspension is no worse than the XS650 which came
    out 7 years later. And the powerband is way way smoother. The drum brake
    on the rear does suck.
    Dave, Sep 19, 2007
  5. Nothing wrong with a drum on the back, given that most of the braking
    should be done by the front.
    The Older Gentleman, Sep 19, 2007
  6. Dave
    Ron Gibson Guest
    It would be nice if someone could make a reliable transverse mounted V4.
    Well maybe there is but I am not aware of one. I think Yamaha used to
    make one but am not sure (Also not sure if it was reliable).
    Ron Gibson, Sep 20, 2007
  7. Dave
    Ron Gibson Guest
    You know what? As much as I've heard the name I've never seen one in the
    showroom at my dealer. I know very little about them and all I've ever
    ridden is Yamaha. Go figure...Coincidence I guess.
  8. Dave
    Ron Gibson Guest
    Oh I see they are 1200CC engines and weigh 580 pounds dry w/ 140HP
    (2003). That's heavier than I like and several 600CC motors are as
    powerful. It looks like they could trim some weight but I'd rather see a
    600CC version.
  9. Dave
    paul c Guest
    Wouldn't that make a rather long drive-train? Or are you assuming a
    very big displacement? Just curious ...
    paul c, Sep 20, 2007
  10. Like the VFR750/800, one of the most reliable bikes ever made?
    The Older Gentleman, Sep 20, 2007
  11. Dave
    Ron Gibson Guest
    Actually I'm just thinking of a engne design shape that lowers and
    narrows the weight distribution of the 4 cylinder engine.
  12. Have a look at the new BMW four-cylinder sports bikes.
    chateau.murray, Sep 20, 2007
  13. Dave
    Dave Emerson Guest
    message
    Most drum brakes suck because they're not working properly.
    Here's v simple trick to improve feel and power of a drum brake....
    - Loosen wheel spindle
    - Apply brake *hard*
    - Re-tighten spindle while holding brake on
    The plate that the brake shoes are fitted too is a clearance fit on the
    spindle and will normally hang under gravity when assembled.
    The above process ensures that it's centered to the drum and can make a huge
    difference.
    Dave Emerson, Sep 24, 2007
