Spinny head....
Discussion in 'UK Motorcycles' started by Fr Jack, Dec 8, 2004.
  1. Fr Jack
    Fr Jack Guest
    Ta
    Cheers!
    Fr Jack
    96 Tiger.
    FRJACKUKRM AT GMAIL DOT COM
  2. Fr Jack
    mb Guest
    8<
    Stop the room spinning by hanging your head over the side of the bed,
    while lying on your back.
    It's magic.
    mb, Dec 8, 2004
  3. Fr Jack
    porl Guest
    Or tragic; when you pass out and choke on your own vomit.
    porl, Dec 8, 2004
  4. I had a very similar thing 5 years ago.
    It turned out to be a condition called Benign Positional Vertigo.
    Bits of stuff (technical term) floating around in the eary tubes get
    caught up somewhere and upset the balance gyroscopes in yer heed.
    The doctor chappess at the hospicle (the sainted MKG A&E) said there
    was nothing they could do, bye bye. Great, I couldn't stand let alone
    ride or drive.
    I got taken home and set about searching the interweb thingy for a
    cure.
    I found a method of head turning which I tried without apparant
    success, then went to sleep and woke up and the room was still once
    more.
    Are you certain of your diagnosis?
    see more at:
    http://www-surgery.ucsd.edu/ent/PatientInfo/info_bppv.html
    ColonelTupperware,
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/ UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Dec 8, 2004
  5. Fr Jack
    mb Guest
    Well, if it stops the room spinning...
    mb, Dec 8, 2004
  6. Fr Jack
    Fr Jack Guest
    2 Docs have come to the same conclusion, FWIW.... :-/
    Cheers!
    Fr Jack
    96 Tiger.
  7. Fr Jack
    I got uncontrollable vomiting after I the shit kicked out of me, every
    time I lifted my head off the pillow. The thing about this is, that you
    run out of stuff to sick up.
    Muck, Dec 8, 2004
  8. Fr Jack
    Nursey Guest
    Yep, that is all they can do. :-/
    Nursey RN
    ALS Provider OSOS#25 MIRTTH#6 IbW#09 4#COFF EFFA MOP#1
    Honda Deauville (NTV650-V) (Mine)
    Tweenies Trike (Caitlin's)
    Nursey, Dec 8, 2004
  9. Suspect I was boreder. Just came out of Grimbo Hozzy after the "it'll
    just be an overnighter for tests" turned into a ten day stretch for a
    lung infection that they stilll can't positively identify
    Stan Stannard - Grimsby, UK
    "Statto's evil twin"
    ANORAK#01 BONY#57 UKRMSBC#01
    Kawazaki ZZR1100D
    Stan Stannard, Dec 8, 2004
  10. It was somewhere around Barstow, on the edge of the desert, when the
    Melatonin...
    http://www.youngagain2000.com/melatonin.html
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Dec 8, 2004
  11. Fr Jack
    Lady Nina Guest
    Lady Nina, Dec 8, 2004
  12. Fr Jack
    Stan Stannard said...
    I had one of those 3 years ago. They never did find out exactly what it
    was, but it laid me up for 3 weeks. I'm only just back at work after
    another chest infection kept me on the sick for a fortnight.
    Lozzo, Dec 9, 2004
  13. Fr Jack
    Fr Jack Guest
    Stuff like this was available over the counter in UK until recently.
    For some reason the authorities tweaked some legislation and now, you
    cant.
    Cheers!
    Fr Jack
    96 Tiger.
    Fr Jack, Dec 9, 2004
  14. Fr Jack
    Lady Nina Guest
    I did some research into it a couple of years back and discounted it
    then, but this is getting silly now. I've not had a flare up this bad
    for a long while. I have a strong urge to run down the street banging
    pots and pans shouting 'wake up you fuckers, if i can't sleep i don't
    see why you should'. I think I'm now officially in the grumpy stage.
    Oh my tomorrow is going to be fun.
    Lady Nina, Dec 9, 2004
  15. It was somewhere around Barstow, on the edge of the desert, when the
    Big Drug Companies Conspiracy Theory, or simply over-zealous paternalism
    on the part of the GMC.
    Possibly a bit of both, iwt. The same applies here; I've to get mine
    mail order. This is the crazy thing - the most litigious country in the
    world has no bar on selling this an an OTC thingy; it makes me wonder
    just what the grounds are for restricting its sale in the UK & Ireland.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Dec 9, 2004
  16. Fr Jack
    Snowleopard Guest
    cant.[/QUOTE]
    They also got rid of Dramamine, which is the only thing I've ever
    found that stops my travel sickness (as well as being a great knock
    out drug).
    LN - have you tried getting hold of some anti-histamines? The chemist
    gave me phenergen to replace the dramamine and it certainly helps
    sleep, if not much use for the nausea.
    Snowleopard, Dec 9, 2004
  17. Fr Jack
    Lady Nina Guest
    out drug).
    sleep, if not much use for the nausea.[/QUOTE]
    I'm going for the getting pissed option.
  18. No Rohypnol left?
    Simon Atkinson, Dec 9, 2004
  19. Oi, in my state of mind I could do with a few of them!
    Whinging Courier, Dec 9, 2004
  20. Fr Jack
    Lady Nina Guest
    Where did I put that strap on?
