Spelling a carb...
Discussion in 'UK Motorcycles' started by Biker2 \(Threadstopper\), Aug 31, 2004.
  1. I have just received a brand new carb for my Velocette Clubman 500
    The label on the box states that it is a carburetter but I thought it should
    be spelt carburettor but Google suggests carburetor.
    Who cares ?
  2. Biker2 \(Threadstopper\)
    Eddie Guest
    Eddie, Aug 31, 2004
  3. Biker2 \(Threadstopper\)
    Molly Guest
    This is UKRM, we all care.
    Molly, Aug 31, 2004
  4. Biker2 \(Threadstopper\)
    Four barrel double pumper ...
    Pip, Aug 31, 2004
  5. Biker2 \(Threadstopper\)
    TomTheKraut Guest
    1) it's spelt "V-e-r-g-a-s-e-r"
    2) the box is probably "Made in Taiwan"
    3) Google is a 'merkin company. They have thrown proper English over
    board together with the tea, back then...
    Tom :{)
    BOTAFOT#105 COFF#02/ OSOS#15 KwaSoH#2
    SR500(.de), SRX-4(.jp)
    Make it idiot-proof and someone invents a better idiot...
    Hiroshima pics: http://makeashorterlink.com/?C12E12B97
    TomTheKraut, Aug 31, 2004
  6. Biker2 \(Threadstopper\)
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Dr Ivan D. Reid
    Karbooreattour.
    Nigel - Manufacturer of the "Champion-104" range of rearsets
    WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20 BOTAFOT#150 HYPO#0(KoTL)
    Honda GL1000K2 Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Nigel Eaton, Sep 1, 2004
  7. I didn't know you spoke Dutch.
    Vlad the Inhaler., Sep 1, 2004
  8. Biker2 \(Threadstopper\)
    Petel Guest
    Paging Tom The Kraut,
    Not having a German/English dictionary on me I wonder if you could help?
    I`ve been researching a certain make of carb and it`s settings for our `lil
    red sprinter and the best source is a German NG.
    Could you translate Nebeldeuse for me? Is it Needlejet?
    A run down of the following would be handy as well.
    English-German for :-
    Mainjet.
    Pilot Jet.
    Starter Jet.
    Needle Jet.
    Throttle valve.
    Also am I correct in thinking Candle is Spark Plug?
    I`d appreciate this.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    Piaggio/Gilera 125 Red Dwarf Sprinter
    http://homepage.ntlworld.com/peteh1/website/index.html
    Petel, Sep 1, 2004
  9. Biker2 \(Threadstopper\)
    TomTheKraut Guest
    "sprinter" as in the Mercedes van? - hardly, they are much too modern to
    have carbs anymore... what make of carb?
    Literally, "Nebeldüse" = "Fog Jet" - might be used as general
    description of what the jets help to do with any fluid that passes
    through them.
    Should be "Leerlaufdüse" (I've seen both, "Idle Jet" and "Pilot Jet",
    been used for it)
    That should be "Kaltstartdüse", if it's connected to and controlled by
    the choke.
    Zündkerze or (short form) "Kerze", yep.
    Tom :{)
    TomTheKraut, Sep 1, 2004
  10. Biker2 \(Threadstopper\)
    Petel Guest
    Petel, Sep 1, 2004
  11. Biker2 \(Threadstopper\)
    TomTheKraut Guest
    http://www.mikuni.com/pdf/vmmanual.pdf gives you an exploded view and
    part list in (American) English.
    On http://www.motorcyclecarbs.com/mikuni/VMsingle.htm you find some more
    info - interesting though that the VM28 seems to have been dumped and
    replaced by the VM30. Details for that one on
    http://www.mikuni-topham.de/DEUTSCHSITE/VMDeutsch/VM2TAKT01.html - a
    German Mikuni dealer infopage for VM carbs.
    Tom :{)
    TomTheKraut, Sep 2, 2004
  12. Biker2 \(Threadstopper\)
    Petel Guest
    Thanks for the links, I`ve already browsed the German "Topham" site.
    The research is for the application in a non-std way.
    I`ve got no problem getting jets/parts etc.
    The VM28 was never meant to be fitted to a Gilera 125!
    These use either a Dellorto 20mm or sometimes a Mik VM20.
    Anyway it`s sorted for now (until we fit a 172cc kit then the fun starts
    over again).
    Petel .
    02 M2 Buell.
    C90-ZZR.
    Petel, Sep 2, 2004
