Speedo recalibration device
Discussion in 'Australian Motorcycles' started by Johnnie5, Jul 23, 2004.
  1. Johnnie5
    Johnnie5 Guest
    available from september from www.jaycar.com.au for $45
    just the thing for adjusting electronically driven speedos when they are
    incorrect
    STOCK-CODE: KC5380
    Ref: High Performance Electronic Projects for Cars - Silicon Chip
    Publications.
    If you upgrade your gearbox, change diff ratios or even change to a larger
    circumference tyre, you could be plagued with an inaccurate speedo. It
    alters the speedo signal up or down from 0% to 99% of the original signal.
    The adjustment is easy to dial in using multi position switches. This unit
    could avoid traffic fines, which may result from using a non-calibrated
    speedo. It is also suitable for altering speed sensor input reading to the
    ECU or auto transmission control computer. Kit supplied with PCB, and all
    electronic components.
    * Requires car to be fitted with electronic type speed sensor. It will not
    work with a cable type system.
  2. Johnnie5
    conehead Guest
    Does it have a calibration for jetting?
    conehead, Jul 24, 2004
  3. Johnnie5
    Johnnie5 Guest
    thats the other kit they have ;)
    they do actually have a kit that is along the lines of a power commander
    though but dont think it would work on bikes by the quick look of it
    Johnnie5, Jul 24, 2004
