Speedo calibration in Melb?
Discussion in 'Australian Motorcycles' started by Brenton Spear, Feb 14, 2005.
  1. Where can I get my speedo calibrated in Melbourne? Its 20Km/h higher than
    actual at the moment.
  2. Brenton Spear
    smack Guest
    yellow pages
    smack, Feb 14, 2005
  3. Brenton Spear
    Boggyman Guest
    Hi Brenton,
    Depending on where you are... Try
    Ringwood Speedometer Service
    693 Whitehorse Rd Mitcham VIC 3132
    ph: (03) 9874 2260
    or
    Footscray Speedometer & Instrument Services
    110 Northern Rd Heidelberg Heights VIC 3081
    ph: (03) 9314 2341
    or
    Lonsdale St Instrument Service
    15 Park Drv Dandenong South VIC 3175
    ph: (03) 9706 5598
    Cheers
    Phil
    Boggyman, Feb 14, 2005
  4. Brenton Spear
    Smiley Guest
    There is a joint on Maroondah hwy Corydon. can't remember the name.
    a friend of mine got his car speedo done there and said that they did a good
    job.
    Smiley, Feb 14, 2005
  5. Brenton Spear
    Hugh Guest
    Theres a little place in Ringwood,dont know the name,opposite Hungryjacks at
    top of hill melb side.Hugh
    Hugh, Feb 14, 2005
  6. Buy a bicycle speedometer - and just ignore your main speedo.
    Baron Von Rotter, Feb 14, 2005
  7. Brenton Spear
    Goaty Guest
    Goaty, Feb 14, 2005
  8. Brenton Spear
    glitch1 Guest
    That's the one...
    All the Eastern Subs Bike Shops are customers there...
    cheers
    pete
    glitch1, Feb 14, 2005
  9. Bend the needle back 20 k's
    Objectionable Fred, Feb 14, 2005
  10. Brenton Spear
    Conehead Guest
    You could do a crash course in mental arithmetic.
    Conehead, Feb 15, 2005
  11. Im already there :)
    Rang the place in Ringwood, $45 to recalibrate.
    Brenton
    Brenton Spear, Feb 15, 2005
  12. Brenton Spear
    Goaty Guest
    Goaty, Feb 15, 2005
  13. Brenton Spear
    vifer Guest
    For that money get yourself a Sigma BC-800. Accurate up to 300km/h and with
    a few other features such a clock, max and average speed. Easy to install
    and calibrate. And you can take it with you when you leave the bike.
    Have one on the ducati for a year now. Just need to backlight it with a high
    intensity LED one of these days.
    http://www.google.com.au/groups?hl=en&lr=&scoring=d&q=sigma+800+group:aus.motorcycles
    http://www.bicyclestore.com.au/item...ccessories/computers/sigma-bc-800-8-function/
    http://www.canyonchasers.net/shop/generic/sigma.php
    vifer
    vifer, Feb 15, 2005
  14. Brenton Spear
    Vincent Guest
    Place a small "C" clamp, about 50mm. on the speedo cable, tighten it up to
    13.755 psi, that should restrict the continual spin of the cable enough to
    withhold it by the required amount of 20 kph,
    if not, then you may have to give it an extra tweak of about 0.2275 psi.
    If you have trouble measuring the correct amount, try to use a Supertool
    torque wrench,
    they are more accurate than the Kingcraft models
    Vincent, Feb 15, 2005
