speed-sensitive steering damping
Discussion in 'Motorcycle Racing' started by Ziguy, Oct 13, 2003.
  1. Ziguy
    Ziguy Guest
    Is Hyperpro speed sensitive steering damping a good concept???
    Ziguy, Oct 13, 2003
  2. Ziguy
    herman Guest
    how about the electronic honda one
    herman, Oct 13, 2003
  3. Ziguy
    Phil Scott Guest
    Id guess that it is a real good idea....it would go tight at higher speeds
    yet relax around town at lower speeds.
    Phil Scott
    Phil Scott, Oct 13, 2003
  4. Ziguy
    FuTAnT Guest
    I want to know how it works ... ???
    Cam
    '00 ZX6R
    FuTAnT, Oct 13, 2003
  5. Ziguy
    Moike Guest
    Sensor in the seat?
    Moike
    Moike, Oct 13, 2003
  6. Ziguy
    FuTAnT Guest
    sphincter sensor?
    Cam
    '00 ZX6R
  7. Ziguy
    RM Guest
    Someone let Moike at loose on an internet connection
    and the result was:
    me too...to be truly 'road speed sensetive' u'd think it'd be hooked to the
    pulse generator for the speedo and have a servo to wind it up and down with
    speed...then it'd have to be calibrated an stuff...no mention of such a
    thing...praps velocity sensetive with a bit of mechanical valving trickery?
    anyway, wassamatter doncha got arms?
    RM, Oct 13, 2003
  8. Ziguy
    Greg Byrnes Guest
    By "Speed sensitive" I am assuming you mean the speed the bars are being
    flicked from side to side and not the speed of the bike itself?
    Yes good idea (the 1st one that is) - low resistance for normal riding then
    if you hit a bump and the bars try to twist out of your hands the damper
    reacts to sudden changes and stops it from happening (or at least lessening
    it).
    Greg
    Greg Byrnes, Oct 13, 2003
  9. Ziguy
    Ziguy Guest
    It not road speed sensitive but handlebar rotation speed sensitive!!! When
    the handle bar are turned slowly the damping is very low but the faster you
    turn it, the more damping you have.
    Ziguy, Oct 13, 2003
  10. Ziguy
    James Clark Guest
    Why should the road speed of the bike have anything at all to
    do with the valving of the damper?
    All you should concern yourself with is frequency and amplitude
    of front end oscillations.
    James Clark, Oct 13, 2003
  11. Ziguy
    _Bob Nixon_ Guest
    On Mon, 13 Oct 2003 08:31:31 GMT, Timberwoof
    Phil, your old dirt bike knowledge is getting in the way on this one.
    Your arms and body tend to magnify any input towards oscillations in
    spite of attempts to do the opposite, where' as a steering damper is
    like a shock absorber, (think low Q resistive tank circuit) thus
    causing oscillations to die out quickly.
    So no, a light input on the bars at all speeds except when
    deliberately counter steering. Properly designed motorcycles WANT to
    go in a straight line, so if the rear end slides, it wants to right
    itself via wiggle at the steering head. Our body mass just gets in the
    way in such instances, so a passive approach is the best course.
    The exception is light DIRT bikes on SOFT DIRT surfaces where you CAN
    muscle the bike around with longhorn bars and even leveraging with leg
    input. At low speeds on street bikes, a foot can help control a slide
    on sand or gravel. Also, a well placed knee bounce can save SOME front
    end tucks at the race track but generally only works for the Rossi set
    Also, body steering on heavy street bikes is at best a secondary force
    in comparison to counter steering and hanging off is moving the center
    of mass to the inside, allowing the bike to lean less for a given
    radius/speed. On dirt bikes, particularly at low speeds, body steering
    to the outside is the norm or similar to low speed "non counter
    steering" (steering head actually turning) on a pavement bike.
    The same can be said, of steering the rear of a motorcycle via rear
    brake or compression braking. It's more suited for light bikes on soft
    surfaces but can be done on asphalt bikes to a lesser degree. Front
    trail braking is less natural but effective, trading cornering
    traction for braking. It's a vector sum, so the more the lean the less
    braking and so on. This also tends to make the bike stand up and
    requires additional counter steering to hold a line.
    IMO, road conditions or lack of certainty of said, will dictate the
    use of front or rear braking in a turn. (soft surface: rear brake,
    hard surface: front brake or even both). The safe thing to do for
    street riders is to get the braking out of the way prior to entering a
    turn. The no brakes drill using compression to slow to bike, but
    'generally' this requires good road memory, particularly on foliage
    obscured, poorly marked roads. IMO, aggressive or late braking to
    trail front braking is in the realm of the expert track rider. This is
    different than just overcooking a turn, standing the bike up and
    getting on the front binders, thus chancing going into the oncoming
    lane. It's sometimes unavoidable, should be done in steps (straighten,
    lean. straighten lean) and generally folks who find themselves in such
    a predicament, could have just leaned in harder or "dare I say it",
    slide the back out a bit (rear brake) momentarily, to correct the
    apex.
    More than the scope of this thread but I got carried away -:)
    Bob Nixon
    Phoenix AZ
    01 Sprint ST "RED"
    03 Suzuki ST "SILVER"
    _Bob Nixon_, Oct 13, 2003
  12. Ziguy
    Phil Scott Guest
    errr... I said the STEERING DAMPER goes tight at higher speeds with that
    device..NOT your grip.
    gripping tighter at higher speeds is a whole other range of issues...in a
    speed wobble muscle tension and its delayed reaction can make a speed wobble
    worse. and also make your arms tired. The steering damper has no such
    delay or resonance.
    Phil Scott
  13. Ziguy
    Phil Scott Guest
    So...Bob... do you thing the progressive steering damper gets tighter or
    loose with added speed?
    My guess is tighter.
    Phil Scott
  14. Ziguy
    Phil Scott Guest
    It would have to have an input in digital form from the speedometer..that
    would operate a restrictor valve in the hydraulic circuit of the steering
    damper though a pressure electric transducer most likely.
    Phil Scott
  15. Ziguy
    Manu ® Guest
    And how does the damper knows you're at 40mph coming out of a tight corner
    and whip it onto the next straight? because then you might get some
    headshake.
    I wonder...
    --Manu
    Manu ®, Oct 13, 2003
  16. Ziguy
    James Clark Guest
    No.
    Too tight prevents a wobble to the extent that it causes a weave.
    Too loose may not contribute to a wobble, but it does nothing to
    damp a wobble.
  17. Not really any news. Øhlins have had high speed adjustment on their off road
    rotary steering dampers for years. BTW it look quite similar to the new
    fancy Honda s.d.
    /MBE
    Morten Becker-Eriksen, Oct 13, 2003
  18. Ziguy
    Phil Scott Guest
    not likely at all...but worn and too tight bearings could...as the head
    tended to click into ball indents off line then back out... thats stretching
    it though.
    Phil Scott
  19. Ziguy
    Phil Scott Guest
    that move is still very very slow compared to a speed wobble.
    Phil Scott
  20. Ziguy
    _Bob Nixon_ Guest
    I agree, Phil.
    Bob Nixon
    Phoenix AZ
    01 Sprint ST "RED"
    _Bob Nixon_, Oct 14, 2003
