spark tester
Discussion in 'Classic Motorbikes' started by Juco, Jan 11, 2004.
  1. Juco
    Juco Guest
    anyone know the name of the tool that you screw into the the sparkplug bit
    (in line) thats lets u see the colour of the spark for testing for rich/weak
    fuel mix.
    thanks
    Juco, Jan 11, 2004
  2. Juco
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Juco
    Gunson's Colourtune. Available from you local friendly Halfrauds.
    Know which size of spark plug thread you need before you go to buy one.
    Nigel Eaton, Jan 11, 2004
  3. Juco
    Indeed. Now, remind me, Nigel - is it yellow for rich ... ?
    Pip, Jan 11, 2004
  4. Juco
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    FOYRHB
  5. Juco
    Battleax Guest
    Why not just look at your current plugs to see how the mixture is?
    b
    Battleax, Jan 11, 2004
  6. Juco
    Juco Guest
    I have borrowed one so might as well try but need instructions ...anyone got
    that can email to me
    thanks
    Juco, Jan 11, 2004
  7. run engine 'til it's up to temperature, fit colortune plug, start engine,
    look down hole. yellow = too rich, blue = good, white = too lean.
    in practical terms, there's sod all you can do to most bike carbs other than
    rejetting, or possibly changing needle positions or needles and jets.
    but it's handing for checking.
    remember to check each pot on >1 cylinder things with >1 carbs
    Austin Shackles, Jan 12, 2004
  8. Juco
    Ben Blaney Guest
    <g>
    Ben Blaney, Jan 12, 2004
