spark plugs
Discussion in 'UK Motorcycles' started by marc, Oct 7, 2003.
  1. marc
    marc Guest
    any suggestions on how to change a spark plug on a Yam XTZ660 ?
    marc, Oct 7, 2003
  2. marc
    you need to change it again already?
    darsy, Oct 7, 2003
  3. marc
    Ginge Guest
    Unscrew it, screw in a new one.
    Very easy.
    Ginge, Oct 7, 2003
  4. marc
    Ginge Guest
    Actually if you can't do it I'll give you £25 for your carbs.
    Ginge, Oct 7, 2003
  5. marc
    flashgorman Guest
    from google
    Q-
    Anybody know exactly how I get the spark plug out of the thing?
    The frame seems to be in the way, as the gap between top of head & frame is
    less than the depth down to the plug itself.
    Unless I need to use one of those 'bendy' socket extensions? Or a special
    tool from Yamaha costing an arm & a leg?
    A-
    The original tool is nothing more than a tube spanner (hex at both
    ends) with a grommet in it to hold the plug. The whole thing is just
    long enough to go over the plug & stick above the head a bit so you
    can put a normal spanner on it
    flashgorman, Oct 7, 2003
