spag rally
Discussion in 'Australian Motorcycles' started by Zebee Johnstone, Oct 18, 2011.
  1. Zebee Johnstone
    Diogenes Guest
    It was the last 100kms that did me in. :-( Then again, they say
    "that which doesn't kill you makes you stronger"...
    Kurrajong from now on wins my vote too.
    Onya bike
    Gerry
    Diogenes, Oct 24, 2011
  2. Zebee Johnstone
    TimC Guest
    Heh. I did 1800km over the 4 days I gave myself for this weekend.
    Probably about 400km of it on dirt too.
    And only 1 broken mirror a rear mudguard to show for it too. The rear
    guard from hitting a hole hard enough so that it snapped the guard off
    its mounts (hmm, those R1200GS guards are a bit fragile looking, but
    perhaps a loose strap I had forgotten to tie down got tangled and
    ripped it off. Unlikely, because nothing was pulled loose from the
    strap being yanked, and there were no tangles by the time I stopped).
    The broken mirror from failing to put my foot down solidly enough.
    I have no idea how BMW constructed the mirror - I've got one with
    smashed glass, and I've got another spare one snapped off at the base.
    I should be able to merge them, right? The stem goes up through the
    mirror body, with a nut inside the mirror body locking the stem into
    its ball socket. The glass is retained by a lip over the body. It is
    one moulded piece. The nut had to be tightened with the glass not in
    place. Then the rest of the body somehow had to be moulded around it.
    No, there is no sign of flex - it would be impossible to just push the
    glass into place.
    TimC, Oct 26, 2011
  3. Zebee Johnstone
    Diogenes Guest
    Yeah, but you're a SERIOUS biker. I got sore muscles just reading
    about your journey. :)
    Onya bike
    Gerry
    Diogenes, Oct 26, 2011
  4. Zebee Johnstone
    F Murtz Guest
    My r100 mirrors are two parts glued together, have a close look for an
    almost invisible line right around the outer extremities,if there is, a
    knife blade ,saw or some such might separate them. it can be glued back
    together again with methylene chloride (solvent)or various other glues.
    F Murtz, Oct 28, 2011
  5. Zebee Johnstone
    bthumble Guest
    You could have pushed it (downhill!) to the gate before starting it, but noooo..... :)
    bthumble, Oct 31, 2011
