Sound levels
Discussion in 'UK Motorcycles' started by Krusty, Jun 24, 2005.
  1. Krusty
    To aid my ongoing fiddling with baffles, I've bought meself one of
    these http://www.maplin.co.uk/module.aspx?ModuleNo=25671&doy=24m6
    However I'm a bit confuddled. It's got 'A' & 'C' weighting, & in the
    instructions it says 'C' should be used for measuring things like
    engines, so that's what I set it to.
    Now I'm no expert, but I'm guessing 112dB at idle is a tad on the noisy
    side. Better than the 117dB I was getting before fitting my latest
    bodged baffles, but still not good.
    The thing is it doesn't /sound/ that loud. So I changed the meter to
    'A' weighting, & that gives 92dB, which seems far more accurate to my
    untrained ear.
    So the question is, should I be using 'A' or 'C' weighting?
  2. A Weighting A standard weighting of the audible frequencies designed to reflect the response of the human ear to noise.
    C Weighting A standard weighting of the audible frequencies used for the measurement of Peak Sound Pressure level.
    dB(A) Decibels A weighted
    dB(C) Decibels C Weighted
    Most measuremens are done in dBa or DB(A. Like response curves in Hi-Fi,
    hence the specification of the Race Noise Limit as 105dBA.
    http://www.bristolmc.org.uk/Reference/exhaust_noise.htm
    eric the brave, Jun 24, 2005
  3. Krusty
    M J Carley Guest
    `A' is supposed to mimic (crudely) the response of the ear to
    continuous noise. Use that.
    M J Carley, Jun 24, 2005
  4. Krusty
    It does thanks. I'll ignore the instructions & use 'A' then.
  5. Krusty
    Cheers, 'A' it is then.
