Sometimes, not much model development can be a good thing
Discussion in 'Classic Motorbikes' started by Timo Geusch, Jun 14, 2005.
  1. Timo Geusch
    Finally started replacing the wiring loom on the CB450. The one on the
    bike was a bit butchered - not badly, but I didn't fancy fixing it up
    as it wasn't in that great a condition anyway.
    Finally managed to track down a K6 wiring loom in the US about six
    months ago, which was in rather better condition. So this evening, I've
    mostly been replacing the main loom, and so far everything seem to be
    plug'n'pray.
    The proper test is when it comes to wiring in the headlight as that is
    one of the very few things that have changed on these bikes between the
    K4 and the K6. I think they stayed with the sealed beam inserts though
    so I hope there won't be much of a problem there...
    Finally, I'm beginning to see the light at the end of the tunnel...
    <listens for train engine noise>
  2. Timo Geusch
    Oh great. Make sure that running a Halogen bulb doesn't melt anything
    else - guess why I'm playing with the CB450's wiring loom?
    If I were you I'd have a look around for Halogen bulbs with the right
    wattage that fit the original holder. They are available, but bugger me
    if I can remember where from.
    Timo Geusch, Jun 15, 2005
  3. Timo Geusch
    Erm - lens with reflector, I assume?
    My thinking was more going along the lines of getting a bulb with the
    correct wattage, but as a halogen bulb. And I can't find the friggin'
    link to the company that stocks them...
    I think it's vastly overrated, this unbodging.
    Timo Geusch, Jun 16, 2005
  4. Timo Geusch
    What sort of bulb is it? I got a halogen bulb for the Z200 in the local
    bike shop, and it's the 35w/35w bayonet type like the CG125 takes.
    Also, if the halogen bulb you fit is the same wattage as the one it
    replaces, why would you need to uprate the wiring?
    platypus, Jun 16, 2005
