Somebody stop me...
Discussion in 'UK Motorcycles' started by Eddie, Jan 12, 2007.
  1. Eddie
    Eddie Guest
    Eddie, Jan 12, 2007
  2. Eddie
    You don't really get the whole 'tool porn' thing, do you.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Jan 12, 2007
  3. Eddie
    Shame on you. It's a tool, ffs. A *power* tool. One that makes noise, &
    causes injury, & has the power to destroy metal. How could you *not*
    need one?
    Krusty
  4. Eddie
    Eddie Guest
    A vice and a steady hand?
    Eddie, Jan 12, 2007
  5. Eddie
    Eddie Guest
    .... is the correct answer.
    I'll have to sneak it into the garage. And tidy up the bench, too: I
    made a space to fit the bench grinder, but I'd rather put the drill
    where that is, and I've still got to find a space for the vice as well.
    Eddie, Jan 12, 2007
  6. Eddie
    Eddie Guest
    Not for how often I lockwire stuff, it doesn't.
    Eddie, Jan 12, 2007
  7. A cow-orker has found another good use for a bench drill -- putting
    a 6 mm hole straight through surplus hard disk drives to render them
    compliant with the Uni's directive on disposal of data carriers.
    Dr Ivan D. Reid, Jan 12, 2007
  8. Eddie
    Eddie Guest
    The scrutineers mustn't have been looking properly.
    Eddie, Jan 12, 2007
  9. Of course you do. I bought one of those about 6mon ago and it's been
    fine - not the piece of cheap shit I was expecting for that price,
    although the vice could be a bit bigger.
    You'd be surprised just how much difference a bench drill makes to
    accuracy of cut and the sheer ease of handling. It's also highly
    entertaining when a piece of metal gets whipped out of your hand and
    narrowly misses your ear.
    Grimly Curmudgeon, Jan 12, 2007
  10. Eddie
    Eddie Guest
    I'm willing to risk it.
    Eddie, Jan 12, 2007
  11. Not as entertaining as when you forget to remove the lathe chuck key
    and it whips out on start-up and smacks you in the solar plexus.
    DAMHIK,IJK,OK...
  12. Eddie
    Typo corrected, etc.
    ogden, Jan 13, 2007
  13. Eddie
    Eddie Guest
    At least if they didn't let me start it would give you a chance of
    beating me.
    Eddie, Jan 13, 2007
  14. Eddie
    Eddie Guest
    Tch. Uncoordinated accessories.
    Eddie, Jan 14, 2007
  15. Eddie
    Christofire Guest
    What, like this:
    (Music vid, probably safe for work if your work lets you dick about on
    youtube, but not if they're uptight)
    Christofire, Jan 18, 2007
  16. Eddie
    zymurgy Guest
    What a waste. And for a Uni too. Not like it's state secrets or
    anything.
    We used to take a 14lb sledge hammer to our 12" platters at BAe.
    I'm sure you could get fairly complete data recovery on a modern drive
    with a neat hole through the HDA. One pass only though probably, and a
    bit copy only.
    Cheers,
    Paul.
    zymurgy, Jan 18, 2007
