Soft Brakes
Discussion in 'Bay Area Bikers' started by Brandon High, Apr 16, 2004.
  1. Brandon High
    Brandon High Guest
    The brakes on my ZX-7R have been feeling a little soft lately. They
    still work well, but it requires a little more lever travel, and the
    lever can be pulled back almost to the grip. I'm just trying to figure
    out what the problem might be.
    Initially, I thought I'd boiled them at my last track day and just the
    fluid was screwed. I flushed them last Sunday with Motul 600 and the bar
    is slightly firmer, but it's not a huge improvement. If I didn't do the
    work myself, I wouldn't know it was done.
    I've got SS lines already, so it's not that. I'm also running EBC HH
    pads.
    The bike stops fine (on the street) once the pads have picked up some
    heat.
    Does anyone have suggestions of what to look at to firm things up? The
    bike is 6 years old, so I doubt there could be anything significantly
    worn in the master cylinder or calipers. But it's a good excuse to put a
    Brembo radial master on...
    There's also the possibility that it's just "a Kawasaki thing", since
    the lever on my 10R and on a friend's 9R are both somewhat soft.
    -B
  2. Brandon High
    Brandon High Guest
    Done last sunday with Denise's help. The old fluid was less than 6 month
    old.
    Doing it as soon as I get home.
    Done.
    I already tried the obvious stuff, that's why I'm asking.
    -B
    Brandon High, Apr 17, 2004
  3. Brandon High
    Eric Murray Guest
    Try pressing the pistons back in the calipers, like you
    would when replacing pads. Then pump them back out
    with the lever. Sometimes the pistons just get
    in the wrong position and need to be reset.
    Sometimes this indicates caliper pistons that need cleaning.
    Eric
    Eric Murray, Apr 17, 2004
