Sods law again
Discussion in 'UK Motorcycles' started by TMack, May 21, 2006.
  1. TMack
    TMack Guest
    Yesterday I put a replacement engine into my old cx500 that has been off
    road for a year or so waiting for the transplant. Fired it up before
    tightening down all the nuts and bolts just to make sure it was OK. It
    fired up quite quickly and sounded good - no nasty rattles or clonks. let
    it run for a bit - no water leaking, no oil drips. Feeling really happy that
    the replacement engine was a good one it was back into the workshop to
    torque everything up and complete final fettling such as radiator shrouds
    etc.
    Got it nicely sorted and started it. I let it run for a bit to warm
    up..........hang on a minute, where is that oil coming from? Leaking rear
    casing gasket, that's where. I reckon some numpty has re-used the old
    gasket and damaged it in the process. If it was just an occasional drip I
    would have left it but this was a steady flow and couldn't be ignored. So
    its engine out again again for a new gasket and while I'm at it I'll do the
    cam chain and mechanical seal. The REALLY annoying thing is that it showed
    no sign the first time I started it, it had to wait until I had spent
    another hour on the final stages before showing. I guess the oil hadn't
    quite warmed up and thinned enough for it to show - sod's law!
    Then I found that David Silver had sent the wrong master cylinder repair
    kit - bugger! Then I found out our main drain is almost completely
    blocked - so that's a call to Dynorod on Monday with the consequent expense
    and hassle - buggery bollocking ****!
    TMack, May 21, 2006
  2. The last time I called bloody Dyno, they couldn't come out for three days.
    Utter pants. I ended up getting Thames Water's lot out, who were cheaper and
    good. Drain Doctor aren't bad either. I've now bought drain rods - do you
    know what's blocking it?
    Ali
    Alison Hopkins, May 21, 2006
  3. TMack
    Cane Guest
    Do start me on Sainsburys!
    Cane, May 21, 2006
  4. Grimly Curmudgeon, May 21, 2006
  5. TMack
    Andy Bonwick, May 21, 2006
  6. "Fancy coming round for a meal?"
    I wonder who's living in his flat now, and if they know the history of
    it.
    GS850x2 XS650 SE6a
    Every post contains Nutri-Ceramide-R and Pre-Biotics
    for your reading pleasure.
    Folding@Home Team UKRM
  7. TMack
    Eiron Guest
    Eiron, May 21, 2006
