Sodding MZ
Discussion in 'Classic Motorbikes' started by The Older Gentleman, Apr 18, 2009.
  1. Bob Scott wrote:
    Wotcha.
    There's a good chance I have.
    I ain't sure of what I've got exactly, all I've done is stack the stuff and
    throw away what is obviously junk.
    I seem to recall seeing at least two master cylinders.
    Got a few boxes of gears and the like.
    Whereabouts do you live ?
    You're more than welcome to come and have a nose at what I've got.
    ^..^ Lone Wolf, Apr 26, 2009
  2. The Older Gentleman
    Bob Scott Guest
    My wife reckons the whole MZ falls into the "obviously junk" category.
    It's the only bike I've had that she hasn't ever jumped on the back of.
    Actually, that's not true, she never got a ride on the Gixxer that
    preceded the MZ - but that was a horrible POS which is why I sold it &
    bought the ETZ.
    I'm up in Scotland so nipping over to have a nosey isn't likely to
    happen :)
    I'm in no great hurry to sort the MZ[1], so if you happen upon a front
    wheel or brake gimme a yell and we'll see what we can sort out.
    Bob
    [1] it's nominally summer, herself is between jobs and the Laverda runs
    so the MZ isn't exactly high priority.
    Bob Scott, Apr 26, 2009
  3. The Older Gentleman
    Alex Ferrier Guest
    Problem solved, used a 2" section of old mountain bike inner tube
    (for 1.75-2.1" tyres) as a sleeve. It was an absolute bugger to fit,
    but does the job perfectly, for the time being. It's such a tight
    fit, it doesn't even need any glue.
    'Scuse the mobile pics...
    Before:
    http://i274.photobucket.com/albums/jj262/A1exF/MZ Stuff/DSC00004.jpg
    and after:
    http://i274.photobucket.com/albums/jj262/A1exF/MZ Stuff/DSC00006.jpg
    http://i274.photobucket.com/albums/jj262/A1exF/MZ Stuff/DSC00005.jpg
    It's a bit of a odd mix, this bike. The wheel bearings are clearly
    new all packed with fresh grease and perfect, yet the fork seals,
    sat under the gaters, were fucked. There was only about 100ml of
    what can only be described as sloppy, fishy smelling, marmite in
    the fork tubes. Which are themselves, thankfully, still in excellent
    condition.
    The swing arm bearing has clearly just been done and there is a brand
    new air filter... utterly useless with that gaping crack in the intake
    tube.
    Still need to spilt the motor at some point to sort out the gearchange
    return spring, but that can wait till I've done the cycle parts first.
    Alex Ferrier, Apr 26, 2009
  4. Alex Ferrier wrote:
    Wotcha.
    And indeed, there were no MZ bits to be found.
    Now there's an idea.
    Seems to work ok.
    Oh the joys of SOBs.
  5. The Older Gentleman, Apr 26, 2009
  6. The Older Gentleman
    Alex Ferrier Guest
    Heh, thanks.
  7. The Older Gentleman
    A.Clews Guest
    Thus spake () unto the assembled multitudes:
    It was probably all the pikeys from the Forest of Dean ;-)
    A.Clews, Apr 27, 2009
  8. Or simply put a hair dryer in the air intake and kick it over every
    couple of minutes.
    Oh, and: mine was fussy about choke settings - no more than a third on
    for most cold starts.
    Grimly Curmudgeon, May 4, 2009
