Sodding MZ
Discussion in 'Classic Motorbikes' started by The Older Gentleman, Apr 18, 2009.
  1. I must have tried every trick in the book. Prime, reserve, not on at all.
    The only way it would fire was with no choke, twist the throttle like
    buggery, close the throttle and hit the button. It would eventually fire on
    one cylinder, then, after more of the same, two cylinders would wake up,
    and, if the battery was still up to it, all four. I would then pull the
    choke and let it run for a while. Bump starting made no difference at all.
    As long as the bike was in regular use, it would fire up by merely pulling
    the choke out and hitting the button. . . . . . but if you left it for two
    weeks. Argh.
    ^..^ Lone Wolf, Apr 22, 2009
    #61
  2. The Older Gentleman
    Pete Fisher Guest
    In communiqué <1iyl9ey.jiqzc81dftpf9N%>,
    On a Morini you can choose which pot. Using both starter jets on all but
    the coldest of days results in too rude an awakening.
    | Pete Fisher at Home: |
    Pete Fisher, Apr 22, 2009
    #62
  3. The Older Gentleman
    ian field Guest
    When I had an MZ I found that the user handbook and the Haynes manual gave 2
    different advance settings - neither of which worked at all well, setting it
    halfway between the two worked much better.
    ian field, Apr 22, 2009
    #63
  4. The Older Gentleman
    ian field Guest
    In future - £40 ultrasonic cleaner from Maplin, caustic soda and hot water,
    throw the sooted up plugs in and let them fizz till the oil floats to the
    surface.
    #64
  5. ian field wrote:
    Wotcha.
    Would this work if we scaled it up a tad ?
    Y'know - it might just work.
    #65
  6. it doesn't. But on an old engine, not all cylinders/pistons/valves etc.
    will be exactly the same any more, and chances are one will be the "best" of
    the bunch.
    I merely relate that I've known several engines where by accident I've
    discovered that having one particular cylinder not firing (dud plug, lead
    accidentally off, etc.) the engine flatly refused to start on the starter,
    and if bumped at high enough speed, would start and run on 3. re-enabling
    the 1 missing pot solved the problem. note that all these are old-fashioned
    coil-and-contact, not electronic, ignition. On such systems, voltage drop
    when running the starter is more critical.
    If the remaining pots were prepared to start on the starter, then it should
    fire up and run on 3.
    Now I think on it, I had another one with a head gasket on the way out,
    which showed similar results, wouldn't fire and pick up unless you pulled
    the plug which had coolant on it and dried it out. That one did actually
    fire on other cylinders, but didn't pick up. Once running, it'd run on all
    4. That's perhaps atypical. The other engines weren't thus afflicted, they
    just didn't start.
    OK. you say it's nonsense and demand an explanation. That's my best guess.
    You explain to ME how the engine failed to start on one of the 3 remaining
    pots, and then run on 3.
    Austin Shackles, Apr 23, 2009
    #66
  7. The Older Gentleman
    ltcrolt Guest
    What did I say about the plugs - to your disbelieving snorts?
    ltcrolt, Apr 23, 2009
    #67
  8. The Older Gentleman
    TOG@Toil Guest
    Oh yes. Abject apoligies. One duff plug I caould accept, but two?
    TOG@Toil, Apr 23, 2009
    #68
  9. TOG@Toil wrote:
    Wotcha.
    Hence the "Sherlock Holmes" approach.
    I've been caught out by the "impossible" before now.
    ^..^ Lone Wolf, Apr 23, 2009
    #69
  10. The Older Gentleman
    ian field Guest
    Years ago I worked for a firm that made industrial ultrasonic cleaners, they
    often left units up to 1500W on soak test overnight, naturally I decided it
    would be a good idea to string my collection of fouled plugs on a length of
    wire and leave them dangling in the test tank overnight. They cleaned up
    with perfect white insulators but on some the packed in seal was damaged and
    blew out under combustion pressure leaving the insulator loose to slide up
    and down in the metal body.
    There has been no such problem with the Maplin unit.
    ian field, Apr 23, 2009
    #70
  11. I freely admit that I've not tested the theory. However, on 2 different
    motors for certain, having 1 cylinder not firing made them impossible to
    start. Whether this would apply to any cylinder, I don't know - Having
    fixed the problem, I didn't look any further.
    Taking a 4-cylinder engine, firing 1-4-3-2, if for example 1 was missing but
    4-3-2 were OK, I'd have though that the momentum created by the other 3
    firing would carry it past 1 with enough speed to fire 4 again - after all,
    most engines will (just) idle on 3 - and when you're trying to start it,
    you're not generally using idle mixture level.
    Austin Shackles, Apr 24, 2009
    #71
  12. The Older Gentleman
    Indeed, and the voltage drop theory just doesn't hack it - either
    there's enough juice for a viable spark or there isn't. There
    s no difference betwee a #1 spark and a #3 spark.
    http://xkcd.com/552/
    You've observed, in a couple of Shite Old Engines, that one cylinder
    seems to fire up on a cold start more easily than the others. Plug,
    valve clearances (and timings due to uneve cam wear), choke/mixture
    settings etc. etc. will all have an effect, and it's quite
    conceivable, indeed completely normal, that in a SOE they won't all be
    contributing equally.
    How you get from that observation to:
    I've no idea.
    Sure, most engines should be able to run on three. What's your point?
    Ace, Apr 24, 2009
    #72
  13. hehe.
    I did say that I'd not done any further testing to prove or disprove my
    theory.
    Maybe one day I'll have time and inclination to pursue it.
    The voltage drop thing is perfectly valid though: the coil/contact woks in a
    similar way to a transformer: you put 12V in and get maybe 10,000V out. If
    you put less in, you get less out. Which is why a lot of things had a 6v or
    9V coil and a ballast resistor which was switched out of circuit when
    cranking.
    The point about the SOEngines is exactly what I said, and you repeated: the
    4 (or however many) sets of components are not all equal, due to
    differential wear etc., and also due to statistical variation in manufacture
    of thing like plugs, even if you fit a new set.
    If the voltage drop when cranking lowers the plug electrode voltage to a
    point where it's in the critical zone where it will spark/not spark
    depending on minor variations such as these (and indeed mixture) then you
    can easily get one pot that will fire more reliably than the others.
    Modern electronic systems generate higher voltages than the older systems,
    which means they're less prone to this issue. Also, injection systems
    usually get the fuelling more accurate, meaning it's more likely to fire.
    #73
  14. The Older Gentleman
    Ah. I thought you were implying that only one cylinder fired *by
    design*! Hence my somewhat derogatory responce.
    But yes, I guess that an engine can where to the point that it's
    always the one cylinder that's in best condition (spark plug, coil,
    compression, etc) that catches first on starting. But what that
    really means is that the rest of your engine is knackered.
    Champ, Apr 24, 2009
    #74
  15. The Older Gentleman
    Not necessarily. The cylinder that starts first could be the one out of
    spec, for instance running rich due to a worn jet or a partial blockage.
    platypus, Apr 24, 2009
    #75
  16. The Older Gentleman
    A.Clews Guest
    Thus spake Austin Shackles () unto the assembled multitudes:
    ITYF that only applies to Chinese motorcycles... ;-)
    Sorry, couldn't resist.
    A.Clews, Apr 24, 2009
    #76
  17. Champ wrote:
    Wotcha.
    Now you can see why I like singles - I always build 'em with the one pot
    that starts ;-)
    ^..^ Lone Wolf, Apr 24, 2009
    #77
  18. The Older Gentleman
    Did you fit the pot that didn't start to the MZ before you flogged it back
    to TOG?
    #78
  19. platypus wrote:
    Wotcha.
    .. . . . and I would have got away with it if it wasn't for you meddling
    kids.
    Speaking of MZs - I went over to pick up the "few bits and pieces" that came
    with my recently acquired ETZ. I had to make two trips in the work's van,
    the guy I picked 'em up off followed me with his trailer full of bits, and
    the boot of his car rather packed too. I dread to think what I'll be
    sorting through in the morning - I counted at least twelve wheels going in
    to my garage.
    ^..^ Lone Wolf, Apr 25, 2009
    #79
  20. The Older Gentleman
    Twelve wheels? You could go MZ endurance racing with that lot.
    platypus, Apr 25, 2009
    #80
