In communiqué <1iyey15.12rqps10hioetN%>, Sure the spark is good and strong - tried a spanking new plug? Sounds as if you may have fuel in the crankcase. You should know the drill - plug out, fuel off, empty the float bowl, throttle wide open and kick, kick, kick. Leave the plug out for a bit then try again. If it won't go then you really need to check the ignition timing, but I don't know whether it can 'slip' catastrophically on those. -- +----------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster Gilera Nordwest * 2 Yamaha WR250Z | | Gilera GFR * 2 Moto Morini 2C/375 Morini 350 "Forgotten Error" | +----------------------------------------------------------------+
It deep ends on how long it had been sitting around unused. Pushed gently out of garage - starts. Good shaking up = fuel/water/shite mix blocks pilot jet, then flooded by attempts to start. Sounds as possible as any other theory. Take the fuel pipe off the carb and fill a glass jar - what does it look and smell like. Cloudy = water, brown = rust&shite.
Does it fire with a new plug and a good squirt of StartYouBastard ?. If it fires something is blocked in the carb. CAUTION - Ether spray does not have 2stroke oil so dont try to keep it running too long on spray.
It looks like normal petrol. *Shrug*. I left the plug out of the pot for a few hours, and tried again, and it started! But now it won't.
The Older Gentleman wrote: Wotcha. The stuff in the tank is indeed petrol - or at least that's what I put in it, and it's been running around happily on the first half of the tank's contents. This is getting silly. MZs are ugly, but they are reliable. It's going to be something so bloody obvious. . . . . hindsight is a wonderful thing.
HEH. The LE did one of those on me last week. One of the spade terminals had come off its spade on one of the coils but was jusssst resting against it. Starts - runs for a while - dies - wont start - starts ..... The LE has an ammeter so the fault was kinda obvious when I noticed the needle not moving when I kicked it over.
Well, on Sweller's advice I'll try a new plug, though both the plug that was in it and an old spare I had knocking around both sparked happily. If that fails, I'll check the timing. If that fails I'll break the bastard thing for parts. I wanted a bike to fiddle with, not one that would drive me into an impotent frenzy.
In communiqué There's 'spark' and 'SPARK' that can make a difference even with four strokes IME. The tuned Nordwest could be a sod to start from cold when I first built it. You could see what seemed like a good enough spark, but it wouldn't start. In the end I went a grade softer on the plug, though TBF fiddling with the air gap between the pip on the alternator rotor and the ignition sensor also helped a lot. Heh, time to look for a Morini again for a double whammy ;-) -- +----------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster Gilera Nordwest * 2 Yamaha WR250Z | | Gilera GFR * 2 Moto Morini 2C/375 Morini 350 "Forgotten Error" | +----------------------------------------------------------------+
Sounds like it was flooded, leaving the plug out allowed it to start but maybe you still have a load of fuel in the crankcase. Next time it starts keep it running for at least half an hour. OTOH, how much will you pay me to take it away ?.
I find that it helps to fully charge the battery and then keep the charger attached while trying to start. The odd few extra volts can make a big difference on 6v systems. If this works it is time to start cleaning and checking every connector. Evil bastards (like me) have been known to hot wire the coil to a 12 volt battery - best not for too long though.
I was wondering that too. Assuming (a) it's reed-valve and (b) the valve isn't 'perfect' (i.e. per usual, leaks like a really leaky thing)... can you remove t'plug and set the piston below the transfer port(s), to help the crankcase fuel evaporate? I assume there isn't any sort of crankcase drain. There always is these days: it's those poor banking home-workers burning the documents.
On an old MZ? Bwaaahahahahahahahahaha! <Wipes streaming eyes> There isn't. I drained the carb, removed the plug, and kicked it over a number of times. It's been sitting since yesterday afternoon with the plug out, and I'll shove a new plug in this evening, turn on the fuel, and see what happens.
In communiqué I had a struggle with the chainsaw at 'the chateau' last October. Started first pull but quickly died. Much swearing and heaving on the cord only succeeded in flooding it. In the end, I drained it of fuel, removed the plug and the rudimentary silencer and left it turned upside down for a wile. Not exactly an option in your case though. Classic MX/hill climb treatment for a 'gassed up' stroker is to lean it over on one side whilst revving the tits off it once you do persuade it in to life. That is also a strategy in the case of shagged oil seal though. Enough smoke to elect the whole college of cardinals. -- +----------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster Gilera Nordwest * 2 Yamaha WR250Z | | Gilera GFR * 2 Moto Morini 2C/375 Morini 350 "Forgotten Error" | +----------------------------------------------------------------+
In communiqué <1iyhjro.1dh9q2119vz874N%>, Oh, I do, I do. BTDTGTTS. Always worth trying a new plug before more radical fiddling. -- +----------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster Gilera Nordwest * 2 Yamaha WR250Z | | Gilera GFR * 2 Moto Morini 2C/375 Morini 350 "Forgotten Error" | +----------------------------------------------------------------+
