Sodding MZ
Discussion in 'Classic Motorbikes' started by The Older Gentleman, Apr 18, 2009.
  1. Bought it back from Lone Wolf. Collected it from his gaff. Its starting
    abilities were dmonstrated. Back at the Chateau, on the trailer, and it
    starteth not.
    Not.
    At.
    All.
    Bah
  2. It's only doing it to annoy you, you know. The MZ manual used to have a
    section on fault-finding which had something about "shortage of volts in the
    electrical system".
    'course, shortage of petrol is the favourite. Not got the tap off, has it?
    Austin Shackles, Apr 18, 2009
  3. The Older Gentleman
    crn Guest
    You have most likely flooded the bastard. They all do that sir.
    The same thing happened to me with the Jawa, there is a magic ritual
    which must be followed exactly OR ELSE.
    First dry out the plug and check that the battery is charged and you
    get a good fat spark. Now drain out the surplus fuel from the
    crankcase if it has a plug in the bottom (some dont).
    For the Jawa the ritual is as follows :-
    Turn on the fuel, depress the tickler and count onecrocodiletwocrocodile
    Do not open the throttle. Switch on the ignition and give it a sharp
    kick. If it fires open the throttle slightly to keep it running.
    If it has not fired by the third kick something is wrong.
    If the above does not work the MZ ritual is not the same as the Jawa,
    Get the seller to demonstrate EXACTLY the ritual which he probably
    does not realise he is following.
    crn, Apr 18, 2009
  4. I'm beginning to think so.
  5. The Older Gentleman
    TOG should be able to demonstrate the ritual to himself. IIRC he owned
    this particular bike before.
    Timo Geusch, Apr 18, 2009
  6. wrote:
    Wotcha.
    Ye olde MZ starting ritual.
    Petrol = on
    Choke = on
    Ignition = OFF
    Kick two or three times
    Choke = off
    Ignition = ON
    Kick - and away it goes .
    That's the Wilf Green tried and tested method - it has worked, without fail,
    every time I have gone to use the bike.
    I reckon this MZ is just doing it to be awkward.
    ^..^ Lone Wolf, Apr 18, 2009
  7. Timo Geusch wrote:
    Wotcha.
    I bet he'll never want to own another one after today.
    <runs for cover>
  8. We've had the fuel on and off. Choke open and shut. We've bumped the
    fucking thing half a mile, I reckon. We've heated the plug till it
    glows. We have fuel getting hrough to the plug. We have a spark. We have
    compression. We have no ignition.
  9. The Older Gentleman
    Pete Fisher Guest
    In communiqué <1iydxg1.15df65fwvobxyN%>,
    But is the spark at the right time?
    | Pete Fisher at Home: |
    Pete Fisher, Apr 18, 2009
  10. The Older Gentleman
    ....and strong enough to actually spark in the cylinder?
    I imagine that if it is flooded and has bee turned over with the plug
    out then it would at least have coughed.
    Pip Luscher, Apr 18, 2009
  11. The Older Gentleman
    crn Guest
    If you screw up the ritual and flood it they are a black enamelled bastard
    to start. Welcome to the world of SO 2smokes.
    If you have flooded it you need to get all of the excess fuel out of the
    crankcase. If there is no drain plug petrol off, plug out, wide open
    throttle and push it a mile or so. Plug back in, kick a few times, if the
    plug gets wet repeat until it comes out dry.
    Then apply the correct ritual.
    One final thought - the spark points cam on those has been known to
    move, messing up the timing. Worth checking that the points actually
    open at the right time. Unlikely if it started when you collected it
    but worth checking if all else fails.
    crn, Apr 18, 2009
  12. The Older Gentleman
    You might want to stop now, before people really start taking the piss.
    Krusty
    '03 Tiger 955i
    '02 MV Senna (for sale) '96 Tiger (for sale)
    '79 Fantic Hiro 250 (for sale) '81 Corvette (for sale)
    Krusty, Apr 18, 2009
  13. The Older Gentleman
    SteveH Guest
    Once you get it started, ensure you leave it ticking over on your drive,
    to get it nice and warm.....
    SteveH, Apr 18, 2009
  14. The Older Gentleman
    YTC#1 Guest
    He does that to a lot of bikes ... some only go 53 feet :)
    YTC#1, Apr 18, 2009
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Krusty
    "Too late, Ethel!"
    go and talk to the Catholics.
    Wicked Uncle Nigel, Apr 18, 2009
  16. Oily wrote:
    Wotcha.
    'Ere - show it this :->>
    http://www.moonshiners.org.uk/MZgoeswelsh.htm
    Should remind it of what life is all about.
    There again, venturing into Wales ain't always a good thing ;-)
    ^..^ Lone Wolf, Apr 19, 2009
  17. The Older Gentleman
    crn Guest
    Hmmm - I wonder if all that bouncing around on the trailer has stirred
    up all the shite in the tank and shitted up the carb.
    crn, Apr 19, 2009
  18. wrote:
    Wotcha.
    Now there's a thought. There is a small filter bowl on the bottom of the
    fuel tap, but it may not have caught everything.
  19. And bouncing around on its own wheels wouldn't?
    The Older Gentleman, Apr 19, 2009
  20. No, fuel is getting into the cylinder all right. The plug's getting wet.
    Too much fuel if anything.
