So my brakes are okay...
Discussion in 'UK Motorcycles' started by Rowland McDonnell, Feb 28, 2006.
  1. Well, sort of. Probably. I think I've stopped 'em dragging, but I've
    not yet done a test ride, and whatever the case, I'll have to have 'em
    off again to lube the rubber boots with grease rather than the `fill 'em
    up with silicon lubricating fluid' for the short test I'm going to do
    being careful not to let the brakes heat up too much. The test run will
    stop off at somewhere that sells brake grease (yet to be found), and
    somewhere that'll do me an MOT (found).
    But Sod's law has come into play. I've had to fix an electrical fault
    that appeared just before I went for a test run: flickering rear light.
    And now it's bloody snowing; quite heavily, actually. Thank you baby
    Jesus.
    Rowland.
