SO Italian fork reassembly
Discussion in 'Classic Motorbikes' started by Eiron, Mar 23, 2008.
  1. Eiron
    Eiron Guest
    I've got some Paoli 35mm forks to put on my SO Cagiva.
    Anyone know how to tighten the bolt at the bottom that holds the damper?
    Will a rattle-gun work or do I need to take the spring out and insert
    a special tool to hold the damper while applying two grunts of torque?
    Eiron, Mar 23, 2008
  2. Eiron
    peter Guest
    Removing the spring and wedging the damper rod with a screwdriver
    handle or similar is the method favoured by this SO Morini bodger
    (Paoilis on 250 , Marzocchis on 359).
    PF
    peter, Mar 26, 2008
  3. Eiron
    Eiron Guest
    The rattle-gun worked OK.
    I don't know how much torque I applied but I guess it was enough.
    Eiron, Mar 26, 2008
  4. <G> One half-turn short of a stripped thread, then.
    The Older Gentleman, Mar 26, 2008
