So, I fixed the holes in the zorst...
Discussion in 'UK Motorcycles' started by Mungo \Two Sheds\ Toadfoot, Nov 12, 2008.
  1. ....and ever since it's been a bit sluggish.
    The Viagra, that is.
    There were various holes in the collector box so I gunged them with silicon,
    covered them all with thick exhaust foil stuff, splurged more silicon all
    over to hold them in place, then painted the whole thing with silver
    Hammerite. Do not paint your exhaust with silver Hammerite; it is not
    heat-proof. Despite reading all the words on the tin and not finding any
    that said "Ok to paint bike exhausts with" I still went ahead. Impulsive,
    me. Stinky, my exhaust, and smoky too. It's turned a nice shade of gold
    though, which is nice.
    Anyway, having fixed all the holes and fitting lovely new exhaust gaskets I
    noticed a certain sluggishness. Normally it liked to rev its nuts off at the
    merest whiff of petrol but after being lovingly repaired and fettled the
    cunty thing's revs increased like a diesel van and overtaking became so
    leisurely I could look into car windows to see how fast I was going.
    Adjusting the mixture screws out (making it richer, hopefully; correct me if
    I'm wrong) made it a little better but it still made the BORRRRRRRRRRRR
    noise on full chuff and wasn't 'right'.
    Today I removed the exhaust again, scraped off all the Hammerite and
    silicon, thinking the box might be full of squidged-in silicon, restricting
    the flow of the gases. Nope, not terribly. Bollocks. Dunno. I've fixed the
    holes properly now but was tempted to leave them open to see if it improved
    things! The exhaust ports are a bit black and sooty so I suppose it's
    running rich. When the repairs have set I'll see if it's all back to normal.
    Gotta love old bikes.
    This has been a slightly pissed public service announcement.
  2. Ahhhh, righto. When I fling it back on I'll weaken it to one turn out and go
    from there.
    Definitely not, I know for a fact that it is utterly unfettled, carb-wise.
    I'll see what happens tomorrow before further investigation.
  3. Mungo \Two Sheds\ Toadfoot
    JackH Guest
    I'd have left the carbs well alone - bodging up a few holes in the exhaust
    won't cause for something to go as flat as it sounds this has.
    My first port of call would be to check to make sure that a big lump of rust
    / carbon or whatever hasn't come adrift when the pipes were removed, and
    made its way up inside the exhaust, causing a blockage / restriction.
    Seen this happen before, admittedly on an MBX50 which had a big chunk of
    carbon do the above when dislodged by the fat fecker riding it laying it
    down unexpectedly whilst traversing a roundabout.
    I'd also reset the mixture screws to where they were originally, and whip
    the plugs out and clean them, before going much further.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    03 VW Passat TDI Sport
    89 Vauxhall Nova 1.3 Pearl
    JackH, Nov 12, 2008
  4. Mungo \Two Sheds\ Toadfoot
    Hang on: are you adjusting the idle mixture screw on the carb or some
    top-end or mid-range mixture screw that I've never heard of?
    If the former then it'll have sod-all effect on overtaking.
    What colour are the plugs *immediately* after a moderate-speed run?
    Exhaust ports are often sooty on lower-performance engines.
    Are you sure it's not just the illusion of sluggishness caused by a
    quieter engine? Or are you inadvertently using a different gear for
    the same reason?
    Pip Luscher, Nov 12, 2008
  5. Mungo \Two Sheds\ Toadfoot
    Pete Fisher Guest
    There are holes and HOLES. Does seem a rather extreme reaction I agree.
    Did sound as if he had a look see inside already.
    Oh, yes a two stroke piss quick ? That's why you had to decoke silencers
    in the bad old days before posilube.
    Indeed.
    I was only suggesting a tiny bit of idle mixture adjustment unless a
    known re-jet had been done at any stage.
    Can't rule out something entirely different, possibly ignition
    connection or similar, having been disturbed during the refitting
    process.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 12, 2008
  6. The pilot screws.
    It did strike me as odd that it ran very well until I patched up the holes
    in the exhaust box and put new gaskets in. It feels as though the exhaust
    gases can't get out quickly enough. If I accelerate slowly the revs pick up
    well enough, but full chuff seems to bog it down. The air filter was clean a
    few hundred miles ago but I'll check it for bunged-upness.
    I'll have a squint in a bit.
    No, it's definitely turned into a bit of a slug, though I take your point
    about the quieter exhaust. It used to rev up to the limit very happily but
    doesn't like to now.
    <Sigh> Take the bugger to bits again! :)
    Mungo \Two Sheds\ Toadfoot, Nov 13, 2008
  7. Mungo \Two Sheds\ Toadfoot
    Sounds like it. I'd be interested to hear what the problem was.
    Pip Luscher, Nov 13, 2008
  8. Well, I haven't taken it to bits yet because it's running fairly well now,
    but I don't really know why. I think it was a combination of one exhaust
    gasket not being completely central, or being squished out of central,
    IYSWIM, and a fairly large lump of sooty silicon living inside the exhaust
    collector box. I've set the pilots to what they should be now and it feels a
    lot better, but not 'perfect'. ICBA to take the carbs apart now, not until
    summer, as I'm lacking a nice warm garage, so it'll have to do as it is over
    the winter. I fucking hate winter with a passion.
    Mungo \Two Sheds\ Toadfoot, Nov 15, 2008
