SO Boxer Oil
Discussion in 'Classic Motorbikes' started by SteveH, Mar 23, 2010.
  1. <Nods>
    My RS had shims.
    The Older Gentleman, Mar 24, 2010
  2. SteveH
    Timo @ Work Guest
    .... and of course if it doesn't have any, you need to find out if it
    wasn't supposed to have any or if someone forgot to put them back in.
    Timo @ Work, Mar 24, 2010
  3. SteveH
    TOG@Toil Guest
    Heh. when I did the first oil change on the GN250, I discovered that
    some genius had left out the little spring that holds the filter in
    position and performs the same function as BMW's shims.
    A swift hunt through my Bumper Bike Box of Bolloxed Bike Bits[1]
    unearthed a suitable replacement, though.
    [1] I assume everyone on this NG has something similar [2]
    [2] Contents: odd fasteners, brackets, slightly damaged parts that are
    too good to be thrown away...
    TOG@Toil, Mar 24, 2010
  4. SteveH
    Timo @ Work Guest
    Full of items too good to be thrown away? That'll be my garage then.
  5. SteveH
    M J Carley Guest
    A garage full of Timoed machinery is `items too good to be thrown
    away'?
    M J Carley, Mar 24, 2010
  6. SteveH
    Mirrors broken at the stalk, but with glass intact; spare indicator
    lenses; scraped exhaust cans...
    Ace, Mar 24, 2010
  7. SteveH
    TOG@Toil Guest
    .... double-filament bulbs "because the other filament still works"....
  8. Wotcha.
    The front running lights on the Tiger coloured trike use stop / tail bulbs .
    .. . . . as long as the tail bit is blown. Now if it's the brake light
    filament that blows, then I tend to throw 'em away. 50 / 50 chance of
    getting a good 'un.
    ^..^ Lone Wolf, Mar 24, 2010
  9. That'll be my *office* then!
    Dr Ivan D. Reid, Mar 24, 2010
  10. Ah, the 50/50 argument. Like that dipshit Wagner who reckoned there
    was a 50/50 chance the LHC would destroy the Earth: "Well, it might destroy
    the Earth, or it might not. See, 50/50!"
  11. SteveH
    Rusty Hinge Guest
    I could add to that list...
    Rusty Hinge, Mar 24, 2010
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    <stares at floor, shuffles feet>
    I have a box of ZN1300 bolts that I bought from a man who was scrapping
    one.
    Quite a big box, it is...
    Wicked Uncle Nigel, Mar 24, 2010
  13. SteveH
    Srsly? That's sheer class. Hoarders everywhere should bow down in awe
    at your feet.
    Ace, Mar 25, 2010
  14. SteveH
    How much is it?
    I buy Comma Classic 20/50 - in a metal can - it appears to be the same
    colour/smell as Duckhams Hypergrade - ?10.50 5L
    sweller, Mar 25, 2010
  15. SteveH
    SteveH Guest
    It's about 16 quid.
    Haven't had time to do it yet [1]- so may order some 'classic' oil from
    somewhere now.
    [1] Been busy sorting the Alfa 156 - Sillyspeed split a pipe, so I
    stripped a load of stuff back to investigate. Found out that the
    'specialist' who fitted a 'new' actuator had fitted a used one, or
    hadn't replaced it at all.... a couple of calls to Consumer Direct later
    and they've agreed to fit a new one and fix the leak ASAP.
    SteveH, Mar 25, 2010
  16. SteveH
    Rusty Hinge Guest
    May I share in the asulation, then?
    Rusty Hinge, Mar 25, 2010
  17. SteveH
    SteveH Guest
    Mine has an oil cooler. I don't appear to have the special cooler bleed
    bolt.
    And it makes access very tight for removing the filter cover - the BoL
    doesn't help much with this procedure.
    Fecking over-engineered Kraut crap.
    SteveH, Mar 26, 2010
  18. SteveH
    SteveH Guest
    Oh great.
    I have the wrong oil filter now.
  19. SteveH
    Rusty Hinge Guest
    I need a bigger keyboard and a bigger screen - I have to take my glasses
    off to read the text on this Eee - not to mention having to stick my
    face in it innit.
    Rusty Hinge, Mar 26, 2010
  20. SteveH
    Rusty Hinge Guest
    One day i'll get round to putting Debian on the Acer - none of the above
    whinges apply.
    Did you know you can replace the Tellytubby desktop on Playtime Xan
    dross with a proper KDE? I'm looking into it ATM - I think I'm going to
    have to use a bit of a hack to change the root passworm to do so, though.
    Rusty Hinge, Mar 27, 2010
