SO Boxer Oil
Discussion in 'Classic Motorbikes' started by SteveH, Mar 23, 2010.
  1. SteveH
    SteveH Guest
    Any recommendations as to what to use?
    ISTR BMW say 20/50, but the only 10/50 I could find was Halfords Classic
    Mineral oil.
    Any harm in using 10/40 semi-synth? - and does it matter if it's car
    oil, rather than bike oil, in a boxer? (I have copious amounts of 10/40
    semi-synth car oil)
  2. SteveH
    Adrian Guest
    (SteveH) gurgled happily, sounding much like they
    were saying:
    Don't go to Halfrauds, then...
    http://www.opieoils.co.uk/c-785-20w-50.aspx
    Adrian, Mar 23, 2010
  3. SteveH
    SteveH Guest
    I wanted it today / tomorrow - not next week.
  4. SteveH
    'Hog Guest
    Sling it in! I had 10/40 in the Beemer for the winter rally IIRC and the
    viscocity is right for the warmed up engine.
    I've always found basic car 20/50 in motor factors and it's what I use. I
    don't think old Beemers mind, they just like it fresh and regularly changed.
    'Hog, Mar 23, 2010
  5. SteveH
    SteveH Guest
    Good stuff.
    Next time, I'll buy the Halfords Classic Mineral Oil, as it comes in a
    posh metal can ;-)
  6. SteveH
    Gyp Guest
    10/40 semi-synth will be fine but there's no real need to be that posh.
    Supermarket 20/50 would do fine also.
    As I understand it, the only reason that bike oils are different to car
    oils is that they have to cope with engine, clutch and gearbox all in
    one. Unless it's gone horribly wrong, the oil in your SO Boxer shouldn't
    have to do that.
    Gyp, Mar 23, 2010
  7. SteveH
    SteveH Guest
    Almost tempted to keep the 10/40 for the cars and buy some cheap 20/50.
  8. SteveH
    Fr Jack Guest
    (SteveH) banged this out on the bongos:
    Check your local lidl - if they have their own brand in. Meets all the
    required specs and works fine in airheads, Ks and Accords.
    Fr Jack, Mar 23, 2010
  9. SteveH
    'Hog Guest
    'Hog, Mar 23, 2010
  10. SteveH
    SteveH Guest
  11. SteveH
    They'd get it to you within a day or two IMHO.
    Timo Geusch, Mar 23, 2010
  12. SteveH
    IME they don't like running on 40 if it's getting warm outside, but as I
    pointed out to the guy who bought my Elise, the UK definition of warm is
    slightly different from the, say, German one.
  13. SteveH
    They're a bit old school, but I don't really see what you think the
    problem is?
  14. SteveH
    SteveH Guest
    Just surprised me that it's 2 filters joined by a bit of flexible
    plastic.
    Need to get the Haynes BOL just to work out where the hell to put
    them....
  15. SteveH
    'Hog Guest
    The non oil cooler models can take a one piece filter but for the RS/RT you
    need the split number to get the fecker in.
    'Hog, Mar 23, 2010
  16. SteveH
    Ah, OK. Yes, I can see that.
    Pay attention to the shim locations too, if it's got any.
  17. That filter was developed for the RS, so you could shove it in without
    having to remove the fairing panel.
    The Older Gentleman, Mar 23, 2010
  18. SteveH
    SteveH Guest
    Handy.
    Just got to find some cointainers for all the used oil I'm going to be
    draining out now.
  19. SteveH
    SteveH Guest
    Shim locations?! - for an oil change....
  20. Some - not all of them - have a shim or multiple shims under the oil
    filter cover to ensure that there is enough pressure on the oil
    filter. Not a good idea not to have them if you want oil flowing through
    the filter.
    The Roaming Boxhead, Mar 24, 2010
