Snotoiler
Discussion in 'UK Motorcycles' started by Alan, May 27, 2007.
  1. mb wrote on 27/05/2007 :
    It does get more oil, but simply because the engine is likely to be
    running for a longer time - nothing what so ever to do with the
    distance it has travelled.
    Leave the engine running parked on the stand for two hours and you get
    the same amount of oil delivered as you would riding that bike 200
    miles in the two hours. Uselessly the oil will just leave a puddle
    under the bike.
    Mine gets no oil until it moves and will get exactly the same quantity
    delivered to it if I do the 200 miles in two hours or two days, always
    providing it doesn't rain - now that is proportional.
    The more precisely the oil is delivered based upon need, the less is
    needed and the less mess.
    Ideally the Scott oiler needs to be adjusted constantly to suite the
    operating conditions of the bike. As that cannot really be done you aim
    to set it for an average need - far too much around town, not enough on
    the open road. Add in the viscosity changes and you need to adjust it
    every time the weather warms or cools.
    I spend no time looking after and adjusting the lubrication of mine,
    apart from a rare check on the oil level - I can just ride it.
    Harry Bloomfield, May 27, 2007
    #41
  2. Alan
    mb Guest
    Look, Harry, I'll say this once again; More distance = more oil. How do
    you work out that this has "nothing whatsoever" to do with the distance?
    Because everyone leaves their bikes running for extended periods of time
    on the stand? How would your chain do with 2 hours on a dyno?
    That's proportional with distance and oil amount. Not time.
    And you think Scottoiler users spend a great deal of time with checking
    and adjusting?
    mb, May 27, 2007
    #42
  3. mb pretended :
    Simply because their is no DIRECT relationship between the two. It
    dumps oil on the chain whether there is distance covered or not.
    #43
  4. Alan
    mb Guest
    Just because there isn't a direct relationship doesn't mean that oil
    feed isn't proportional with distance.
    I live in the real world; I don't leave my bike running on the stand for
    extended periods, most of the time the engine is running, the bike is
    moving. Therefore, I'd say that there is a proportional relationship
    between oil amount and distance.
    Harry, is that you?;
    http://www.mccoi-forum.de/viewtopic.php?t=273
    mb, May 27, 2007
    #44
  5. No, it's the other M1BYT.
    Antony Gelberg, May 27, 2007
    #45
  6. mb explained on 27/05/2007 :
    Eh? The only way for it to be reasonably proportional, or have some
    sort of relationship one to the other - would be for you to always do
    identical runs. Visit the same places and at quite similar speeds and
    under the same temperature conditions.
    #46
  7. Alan
    DR Guest
    You're trying to fix a problem that only exists in your head.
    Scottoilers work, end of story.
    DR, May 27, 2007
    #47
  8. Hmmm... dead reliable.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, May 27, 2007
    #48
  9. Grimly Curmudgeon explained on 27/05/2007 :
    #49
  10. DR formulated the question :
    They work, but there are better ways to achieve the same end with a
    more reliable, predictable and cleaner result.
    When I first looked at adding a chain lube system, I looked at all of
    the many systems which were available, including both the Scott and the
    Mccoi. I discounted the Scott because it was such a crude system and
    would obviously need constant adjustment and at times leave a trail of
    oil.
    I liked the idea of the Mccoi because it was could be so accurately
    set, the viscosity (within limits) would make no difference and the
    fact that it was so well supported. Its bad point (and still only bad
    point), was that being a German there might be problems with the
    translation.
    It does the job without any intervention from me, which I was certain
    the Scott would not have done. I am well satisfied with the results and
    the extra cost was well worth while. My only criticism of the Mccoi is
    of the hypo needles it used to deliver the oil to the chain and I soon
    improved on that by replacing them with a commercially made item.
    The Germans say the needles work, but I could not make them stay put -
    so I resolved it my own way.
    Harry Bloomfield, May 28, 2007
    #50
  11. Alan
    mb Guest
    Sigh, have you ever heard of the term "commuting"? I believe this would
    give the conditions you describe above.
    mb, May 28, 2007
    #51
  12. Alan
    mb Guest
    He shoots, he scores. Hah!
    Funny, my uncomplicated Scottoiler never did that and has always done what
    it said on the tin.
    mb, May 28, 2007
    #52
  13. Alan
    Dentist Guest
    Harry Bloomfield wrote;
    "Doorstops sir? Of course, we have a large selection of doorstops.
    You can have the wooden wedge, the patented rubber wedge or, the one I
    consider most suitable for sir's requirements, the nuclear-powered,
    radar-guided, homing doorstop self-assembly kit. It's only a few pounds
    more, but provides the added interest of requiring considerable
    modification and many additional parts (no sir, I'm afraid they're not
    available as part of the kit).
    Yes sir, they are the logical choice. You'll take two? How very wise
    sir...".
    Dentist, May 28, 2007
    #53
  14. Alan
    Danny Guest
    Harry Bloomfield wrote:
    -snip-
    There's absolutely nothing "obviously" wrong with the Scottoiler.
    I've had one on every bike I've owned for the last 15 years (which is
    5 bikes), and they do what they say on the tin. No puddles of oil.
    Chains which last much longer (my current Blackbird is on 20k with
    original chain and sprockets). Ok, they do deposit some oil around
    the general area of the chainguard (or it gets flung there), but I've
    never found oil on the tyre anywhere where it could be an issue. My
    bikes do a mix (or did in the past) of a daily commute along with
    weekend rides and trips across Europe, all without incident.
    Danny, May 28, 2007
    #54
  15. Alan
    Danny Guest
    That hasn't happened here.
    Danny, May 28, 2007
    #55
  16. Alan
    Monz Guest
    I did 18,000 on my last gixxer on the original C & S, it's simply a matter
    of spraying regularly [1] with good quality lube QED
    [1] approx 400 to 500 miles and takes less than 5 minutes
    Monz, May 28, 2007
    #56
  17. Alan
    Tim Guest
    Which mine doesn't (no it hasn't run out of oil). I set it on some
    setting, filled it with some oil and that's it. There is no puddle on
    the garage floor (I got off my lardy arse and looked).
    Tim, May 28, 2007
    #57
  18. Alan
    Donald Guest
    I'll be very glad when I get over this mid life crisis biking thing.
    Sometimes I think it would have been cheaper to have had a mistress
    instead. Probably similar amounts of fun.
    I keep the K75S to remind me that I can still do mechanical stuff. Last
    time I looked the thing had trouble starting and running. After taking
    the tank off and emptying the fuel (SORNED for nearly 4 years now) it
    turned out to be a faulty cell in the battery. Time to sell I think, it
    was a brand new battery put in when I SORNED it. So far it's had a new
    rear master cylinder, handlebar grips, battery and front wheel bearings
    and it's not been on the road in that time :-( .
    Donald, May 28, 2007
    #58
  19. Alan
    Dan L Guest
    I have to admit that my own experience with a scottoiler were not
    wholly successful. Mine used to loose it's injector pipe whilst on the
    move, causing the reservoir to dump it's contents all over the rear
    tyre. Despite my best efforts (i.e cable ties / glue / swearing etc.)
    the injector pipe would not stay put. In the end I just stopped using
    it.
    Chain lubing is really not a biggie, but then I don't use the bike
    every day like others.
    Dan L
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6/7)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, May 29, 2007
    #59
  20. Alan
    christofire Guest
    That's my take on heated grips.
    christofire, Jun 27, 2007
    #60
