Snotoiler
Discussion in 'UK Motorcycles' started by Alan, May 27, 2007.
  1. Alan
    Alan Guest
    Not being up on thses things and usually getting through
    chains and sprockets quite quick because I cant be arsed to
    oil them is there a particular version to purchase for a VFR800
    or is the 'universal Version 7' the one i should lash out for?
    Seem to be around £30 ish on fleabay.
    Thanks
    Alan
    Alan, May 27, 2007
  2. Some tart up there ^ somewhere asked that self same question only a few
    hours ago and you can save all of us a some time and effort if you had
    bothered to fucking read just the header before posting. The advice
    given to her would apply equally to you.
    steve auvache, May 27, 2007
  3. Alan presented the following explanation :
    There are more expensive and better ones. The Scott just dribbles oil
    onto the chain with no regards to the speed, it therefore has to put on
    more than enough at all times. This results in lots of oil used, lots
    of mess and ambient temperature can make a big difference.
    Much better are the electronic ones which accurately meter the
    lubricant dependent on actual distance covered, increasing the quantity
    delivered automatically in wet weather.
    The Mccoi I use seems to be one of the better thought out ones. It uses
    a quality commercial pump to put an accurate amount of oil on the chain
    irrespective of how thick the oil is due to temperature. No mess, no
    continuous adjustments and uses a tiny amount of oil yet the chain is
    always perfectly lubbed.
    Harry Bloomfield, May 27, 2007
  4. This is utter fucking bollox, **** off and get a clue.
  5. Alan
    Is that right? Are you sure?
    No, you're definitely wrong here too.
    ****, that's clever. They have a moisture sensor, do they?
    Pip, May 27, 2007
  6. Alan
    Harry Bloomfield says...
    But for every one like you, there are a couple of hundred happy
    Scottoiler users.
    Most Scottoiler problems are directly attributable to incorrect
    adjustment or bad fitting - the units themselves are very good at what
    they do.
    Lozzo
    Suzuki SV650 K3
    Suzuki GSX-R750L - For Sale £600
    Yamaha SR250 SpazzTrakka
    I ride way too fast to worry about cholestorol.
    Lozzo, May 27, 2007
  7. Alan
    mb Guest
    Tell us, oh wise one, why would the speed make a difference?
    mb, May 27, 2007
  8. Pip submitted this idea :
    Simple logic innit?
    The Scott just delivers a drop of oil dependent upon time. The
    intervals between the drops varies tremendously dependent on the
    viscosity of the oil which itself depends upon the oils temperature.
    Much better has to be a system which delivers a precise amount of oil
    which is only dependent upon the distance travelled by the bike and the
    chain.
    Beat this.... I filled up the oil reservoir of my oiler with 100ml of
    oil 10k miles ago. That 100ml tank still has plenty left in it, my
    chain nice and oily to the touch, it (both chain and oiler) have also
    never needed any adjustment in that time. The wheel rim is also clean.
    It always puts on just enough to keep the chain perfectly lubbed and
    that oil which is eventually flung off, is flung off in dry clumps
    which don't stick to anything.
    Yes, but perhaps it is a little too sensitive.... It goes into rain
    lubrication mode if you simply ride through a slightly moist patch on
    the road and takes a while to return to normal.
  9. Alan
    Tim Guest
    You are spouting utter wank.
    Tim, May 27, 2007
  10. Alan
    He's posting pretty well what most snotoiler owners claim for their
    product of choice.
    I wouldn't use any 'automatic' chain lube system because they all drip
    oil when you don't want them to and you end up with oily marks
    everywhere you park.
    If looking at a chain, spraying some lube on it if required and
    adjusting it if required is beyond someones mechanical ability then
    they really have no place on a motorbike.
    Andy Bonwick, May 27, 2007
  11. Alan
    Adie Guest
    bugger.
    <goes to sell bikes in sig>
    Adie
    keeper of the ukrm faq for my sins
    YZF-R1: ZX9R E1
    Adie, May 27, 2007
  12. Yes and no. I had one fitted to the Bloo GS and promptly parked it up
    for 6 months. Judging by the small patch of oil on the patio directly
    under the nozzle it must have let go a drip every three or four days.
    Certainly nowhere near enough to call the system leaky.
  13. All yours from my pov
    Adie. I'll give you a tenner for the R1, 20 if you don't clean the
    seat.
  14. Alan
    It doesn't relate to the vacuum in the inlet manifold to which it is
    attached, then? The higher the rpm, the greter the manifold
    depression, the more frequently a drop of oil is dispensed.
    My Scott is very similar.
    I don't have an issue with the quantity of oil dispensed. Chain looks
    oily, fling confined to and by chain guard, oiler oil much easier to
    clean off than chain lube.
    Pip, May 27, 2007
  15. Alan
    ginge Guest
    You're more stubborn than incapable.
    ginge, May 27, 2007
  16. Alan
    Adie Guest
    no I have a bloke who's capable. why should I break any nails?
    Adie
    YZF-R1: ZX9R E1
    Adie, May 27, 2007
  17. Alan
    ginge Guest
    See what I mean.
    ginge, May 27, 2007
  18. Alan
    Adie Guest
    he's got to have some uses.
    Adie
    YZF-R1: ZX9R E1
    Adie, May 27, 2007
  19. Alan
    If you use the bike regularly and park it in the same place every time
    then you'll end up with a nice little oil slick after a couple of
    months.
  20. Alan
    Tim Guest
    Then you may have the thing turned up too high. I don't remember
    anything under the Daytona and if I could be bothered I'd go and check.
    Tim, May 27, 2007
