Snetterton - a rider monkey's view (long)
Discussion in 'UK Motorcycles' started by Champ, Apr 4, 2005.
  1. Champ
    The weekend started well - most of the team pitched up at Snetterton
    around Saturday lunch time, and we managed to blag the garage we were
    to use for the race on Sunday (the track day organisers wanted £65
    quid; we just walked in through our neighbours garage).
    I went out for the first session of the afternoon, and everything felt
    fine. Despite being on very worn slicks from last season, I felt
    comfortable doing 1:20s, and everything seemed to be working well,
    especially the rebuilt engine and the completely overhauled brakes. In
    fact, they're the best brakes I've ever raced with. However, when we
    came back into the pits Pip's evil eye spotted all sorts of problems:
    - the fuel tank was leaking petrol
    - one fork leg was leaking oil
    - a water hose was leaking water.
    It seemed like most of the internal fluids wanted to get out. The
    most serious problem was the tank. We drained it and applied Belzona
    liquid metal stuff to it, and waited, while, via several complex phone
    calls, I arranged for Gyp to pick up the spare tank from my place
    (which, for some stupid reason, I'd decided against bringing). The
    belzona refused to set, and we basically lost the rest of the
    afternoon. In the mean time, we'd contacted Lozzo and he was on his
    way over with a replacement fork seal and some fork oil. Simon fixed
    the water leak while everyone else was occupied. When Loz arrived
    with the seal, we stripped the fork, replaced it, re-did the fork oil
    and had it all back together in time to get scrutineered, and then get
    down the pub.
    Gyp was an absolute trooper and left at some god-awful hour in order
    to arrive with the replacement tank before 8am on Sunday. The
    quick-fill filler cap was stripped from the old tank and fitted to the
    new one, and after a little cursing it all went together and we were
    ready for practise at 9am, which was undramatic. As usual, we
    practised "gently" and were something like 31st out of 34 starters.
    My time was marginally the fastest, so I had first dibs on position -
    I decided to do the start (which I rather like), Alex always enjoys
    bringing the bike in at the end, so Daz got the middle stint.
    Fate had one last bite to place on our bum. In changing the wheels
    for lovely new slicks for the start of the race, the thread in the
    captive nut of the quick-release rear wheel system stripped. The crew
    were fantastic - there was no panic, they knew they had 50 minutes to
    sort it, and sorted it was. We made the start, and lined up with the
    rest.
    I love the buzz at the start of the race. You can almost feel your
    adrenal gland pumping. I had my usual spiked racing boots on and was
    across the track and away in quick time, making up a bunch of places.
    Once the order had settled a bit I got into a good rhythm and started
    stringing together 1:18 laps. Which is my usual pace, and about what
    I expected. And then something odd happened - as the quick boys came
    past to lap me (after about 20 minutes), I managed to tag on to them
    just a little, and I started putting in 1:17s. And then I was
    catching people, and I started doing 1:16s. And, then, in one heady
    moment, Suze showed me a board saying 1:15 ! [She timed it as
    1:15.97; the official timing system had it as 1:16.15. Drat]. But,
    the session was an absolute buzz, and when I came in at the end of the
    1st hour we were running in 14th place, and 2nd in class.
    Daz went out while I went for a lie down. Our quick pit work had put
    Daz out in a good position - we can refuel so fast now that we make a
    lot of time at the changeovers. Daz put in a bunch of consistent
    laps, and although we lost a little time to some of the teams around
    us, we held on to our top 20 placing, bringing the bike in at the end
    of the 2nd hour in 17th place. More fuel was added, Alex hopped on,
    and we were back out there. Suze always times our stops from foot
    down in the stop box at pit entry to foot down in the stop box at pit
    exit, and we were doing 49 and 50 second stops (there's a 30mph speed
    limit in the pits, too). I must get her to time our actual
    "stationary" time, but I'm sure it's less than 30 seconds.
    Alex started to have some problems in his stint - the chain had
    stretched (or something) and was jumping the sprockets, and slowly
    getting worse. He stuck with the correct procedure, which is to stay
    out as long as the bike is not dangerous, but towards the end of his
    stint it got very bad, and he started losing lots of time. He
    signalled to Suze that he was coming in, about 10 minutes early. As
    soon as he stopped he told the crew the problem, so they pulled the
    wheel out and threw the new one in. The QD system on the rear wheel
    relies on the chain adjustment being consistent, so spanners were
    required to adjust the chain, and here things went wrong. In the heat
    of the moment, the chain was adjusted without the wheel spindle in
    place (which can be done because the wheel is semi-captive in the QD
    system), but mis-adjustment of the 'push' and 'pull' adjustment bolts
    distorted the carrier slightly, and the spindle wouldn't go all the
    way through. And then it wouldn't come out. I sat by, waiting for it
    to be sorted, which it eventually was, but in all the "stop to stop"
    time was 7 minutes, when it should have been less than 3.
    So, back out there. Wherever I'd found the extra couple of seconds in
    my first stint, I'd lost them again - I couldn't do better than 1:18s,
    but I seemed to be able to do them consistently enough, so I had to be
    happy with that. This session was a fair bit quieter - although the
    race was amazingly crash-free (only 5 in the whole six hours,
    apparently, and the pace car never turned a wheel), there was quite a
    lot of mechanical carnage, and a walk up the back of the pit garages
    showed a lot of bikes in bits with people frantically working on
    them). I was also feeling pretty tired, and had couple of lapses of
    concentration, causing me to give myself a stern talking to in my
    crash helment. Eventually, I saw the 3, 2, 1, IN boards, and was glad
    to hand over. I waited for the positions to settle and checked the
    screens, and we were still well inside the top 20, around 17th, and
    3rd in class.
    Daz went out, and put in some good times (faster than his first stint,
    I believe), and after the changeover to Alex we were running in 16th
    place. Points in the "overall" championship are awarded down to 15th,
    so we started to wonder if we might trouble the scorers for the first
    time (our previous best overall finish was 22nd). And then the team
    running in 15th pitted, and we were promoted! Yes! Often the last
    hour of an endurance race is pretty settled, but this was nail-biting
    stuff - the teams behind us were lapping faster, but did they have
    time? The Kawasaki Newcastle bike overtook Alex to claim 15th, and
    then almost immediately pitted for fuel, and in the words of Simon had
    "the most leisurely stop you can imagine - I expected them to get
    sandwiches out". So, we were still there. But then a hard charging
    R1 was cutting through the field - having dropped down the order with
    mechanical problems earlier, it was now catching Alex at more than 5
    seconds a lap, and, with less than 30 minutes to go he got past and
    just kicked us out of the points. But the tension wasn't over yet -
    the bikes in 17th, 18th and 19th place were all on the same lap, and
    everyone was still racing hard. The time ticked away, and the team
    alternated between watching the results monitor (set up in our
    neighbours pit) and watching over the pit wall). With less than 10
    minutes to go, things looked safe, despite Alex going grass tracking a
    couple of times. The flag came out at 6pm, and the whole team hung
    over the wall waving Alex past. We'd got our best result ever!
    We all gathered in Parc Ferme with big grins and lots of back slapping
    and hand shaking, both amongst ourselves and with the other teams we
    know - there's always such a sense of achievement in finishing an
    endurance race that everyone is pleased for everyone else. Despite
    various mechanical problems, the Team Ixion boys brought their bike
    home, and (I think) really enjoyed themselves.
    And then we went to the prize giving, which is a first for Team UKRM!
    Alex, Daz and I collected a big pot each, and had our photo taken. It
    took me a couple of hours to get the grin off my face.
    So, what a great start to the season. The whole team really were just
    that - a team. Everyone did their job, worked hard, and made it
    happen. Many thanks to, in no particular order, Suze, Simon, Pip,
    Nigel, Gyp and Hog, as well as to Lozzo and Adie (and not forgetting
    our marshal, Nigel's sister Tracey). Also, thanks to the supporters
    that I only briefly had time to chat to during the day.
    Roll on Brands Hatch!
    Champ, Apr 4, 2005
  2. Champ
    Steve Parry Guest
    Champ fumbled, fiddled and fingered:
    Magnificent team work all around!
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Apr 4, 2005
  3. Champ wrote
    I have most of your stops on tape. Easy enough to extract the data.
    I might have been there for that had some **** bothered to tell me where
    we finally finished. I didn't know about the 3rd in Class, AGGOGW.
    Indeed.
    A Good Day, well done all.
    steve auvache, Apr 4, 2005
  4. Champ
    Paul - xxx Guest
    Champ composed the following;:
    Professionalism at it's best .. ;)
    I used to be into sidecar racing and the starts always got to me .. I
    _always_ wanted to piss so badly that I let go of the handles right until
    the start flag dropped ... ;)
    Extremely well done.
    Indeed, Might even get there meself to watch for an hour or two .. we think
    we're going to be nearby that weekend.
    Paul - xxx, Apr 4, 2005
  5. Champ
    Champ wrote:
    Before I start, some pictures (taken by Steve Auvache):
    http://www.sweller.dynalias.org/krc/0405snet/
    Don't know what happened to the one with Suze and Hog on the pit wall
    it's just not on the camera. Real shame as Suze didn't leave her post
    all race.
    On one stop (the last, I think) according to the time monitor the total
    lap time was 1'40, with the rider (it was Daz) running around the 1'18s
    the total stop cost us 22 seconds. This is including the pit lane entry
    stop, 30 mph speed limit, rider change and a full 25 litres of fuel.
    I'm guessing but I don't think the fuel rig is actually connected for
    more than 4 seconds.
    We claimed a few laps back after the spindle debacle by these quick
    stops. Some teams took four or so minutes to fuel and change riders we
    took seven including a tyre change and a bonus **** up; so not bad but
    not good enough.
    Hoo Har!
    sweller, Apr 4, 2005
  6. Champ
    Steve P Guest
    Great stuff, and a good report as well.
    Has the web site been moved? I just tried to check out when the rounds
    'near' to me are on. If you are at Donington again I'll definately try
    and get there.
    Keep it up!
    Steve P, Apr 4, 2005
  7. Champ
    Ooh, could I ask you to do that please?
    Champ, Apr 4, 2005
  8. Champ
    Alex Ferrier Guest
    Alex Ferrier, Apr 4, 2005
  9. Champ
    dwb Guest
    dwb, Apr 4, 2005
  10. Champ
    Still waiting for that idle faux-oirish **** darsy to get his finger
    out.
    Dates are here : www.krcendurance.co.uk.
    Our 2005 site should be up soon.
    Champ, Apr 4, 2005
  11. Champ wrote
    No probs but gimme time.
    I have looked the tape over twice and will be able to sit down and write
    it up during the back end of the week.
    Or you can wait a little longer until I get it onto the computer and I
    will cut the relevant sections out for you and you can analise it to
    death at your leisure.
  12. Champ
    sorby Guest
    Without wanting to step on darsy's toes - if he's too busy then I'm more
    than happy to throw something together - even if it's just in the interim
    until darsy gets time.
    Lemme know.
    sorby, Apr 4, 2005
  13. Champ
    Steve P Guest
    The Donington round is on my birfday, cool! (it probably will be)
  14. Champ
    mostly finished, but having problems FTPing stuff to the server.
    darsy, Apr 4, 2005
  15. Champ
    Ben Guest
    It was too bloody roasting last year so I wouldn't mind it being a tad
    cooler.
    Ben, Apr 4, 2005
  16. Champ
    Fr Jack Guest
    Fr Jack, Apr 4, 2005
  17. Champ
    Champ, Apr 4, 2005
  18. Champ
    Nigel Kennedy or Gary Oldman, I'm not sure which but I'm fairly confident
    they're not Gyp.
  19. Champ wrote
    I dunno.
    Anyway, if you look at the expression on his face it seems that he
    pleased about something. At least I think it is pleased.
  20. Champ
    Christofire Guest
    Congratulations, and thanks for the report. I was wondering how things
    had gone on as the group seemed strangely devoid of any reports. Well
    done one and all.
    Christofire, Apr 4, 2005
