Smoking from Yamaha DT80 1982
Discussion in 'Motorbike Technical Discussion' started by Masospaghetti, Apr 20, 2005.
  1. Hey all, I have a small DT80 enduro that runs pretty well but smokes
    fairly bad, especially when it is cold. I know it is a 2-stroke and that
    it will smoke some, but there's a steady stream of smoke coming out the
    tailpipe. The smoke looks white or grey.
    Is it normal for it to smoke so much? It calms down some when it warms
    up but it'll still smoke pretty bad when juiced. I switched from regular
    2-stroke oil to synthetic smokeless with little effect. What else could
    this be coming from?
  2. You might have a leaky crankshaft oil seal on the primary drive side.
    Pull off the oil filler cap and see if you get pulsations of air
    pressure while the engine is idling.
    If the oil seal leaks, it's going to push air into the area under the
    clutch cover every time the piston goes down. When it goes up, the
    engine will suck oil...
    If the oil seal on the magneto side of the crankshaft leaks, you'll get
    crappy running and some 2-stroke oil will get up behind the magneto.
    The engine won't idle right, because it's pushing fuel/air/oil mix into
    the magneto instead of pushing it up the transfer passages to be
    burned...
    Motorcycle shops that work on 2-strokes should have a rig to pressurize
    the cylinder. It would have a pressure gauge so you can watch how bad
    the leakage is.
    krusty kritter, Apr 21, 2005
  3. Thanks for comments.
    I removed the head just a few weeks ago, what should I look out for? I
    cleaned the deposits on the piston and head and it has a fairly new
    spark plug.
    Masospaghetti, Apr 21, 2005
  4. Unburned fuel makes *black* smoke. Water vapor makes *white* smoke.
    Burning oil makes *blue* smoke...
    Leave the cylinder head on and run the engine with the oil filler cap
    off like I told you. if you feel pulses of air pressure coming out the
    oil filler hole, you have a bad oil seal on the primary drive side of
    the engine. There will *never* be any air pressure (above normal air
    pressure for whatever altitude you're at) inside the clutch cover of a
    2-stroke engine with good oil seals while it's running...
  5. *All* two-strokes chuck unburned fuel out of the exhaust.......
    The Older Gentleman, Apr 21, 2005
  6. Will do. Thanks for advice.
    Masospaghetti, Apr 22, 2005
  7. Masospaghetti
    Hank Guest
    a lot of oil in your muffler will take a LONG time to burn off, so switching
    to synthetic mix oil may not show immediate results
    YMMV
    Tim
    Hank, Apr 22, 2005
  8. Another thing that 2-strokes do is distill all the gasoline and lighter
    fractions out of pre-mixed or injected oil and the oil gets realy thick
    and accumulates in the bottom of the crankcase...
    When you open the throttle and ride really hard, the oil thins from the
    heat and fresh gasoline and it starts getting pumped out of the bottom
    of the crankcase...
    Then the motorcycle looks like a cropduster flying low and attracts a
    lot of attention from the cops, especially if you're the only speeding
    2-smoke on the road...
    A few motorbikes had drain plugs in the bottom of the crankcase to let
    this drain out. The Suzuki 500 Titan was one. When Suzuki built the
    next generation of two strokes, they thought this accumulation of oil
    in the bottom of the cases might actually be a "good thing". They
    connected rubber hoses from the bottom of one crankcase to the transfer
    port of an adjacent cylinder, hoping that the crankcase pressure would
    recycle excess oil between cylinders...
    krusty kritter, Apr 22, 2005
  9. This is slightly off-topic, but can I replace certain oil seals without
    disassembling the engine? I'm most concerned about the clutch pushrod
    oil seal, the kickstarter seal, and the output shaft oil seal. I can see
    all of 'em from the outside. Are these replaceable without getting into
    the guts of it?
    Masospaghetti, Apr 26, 2005
  10. Large diameter lip-type oil seals like that transmission output shaft
    has usually have a stamped sheet metal part inside, the rubber is
    molded over the stamped metal part. Allthat holds oil seals in the
    crankcases is friction, no rubber glue is used. On a Yamaha 2-stroke
    that I once owned, crankcase pumping air pressure was enough to force
    the magneto end oil seal out of the crankcase half...
    You will probably never find this advice in a manual:
    If you *carefully* drill two small holes in the oil seals and thread
    sheet
    metal screws into those holes you can probably pull the seal out by
    pulling on the screws with pliers, without splitting the cases...
    Then the new seal can be pushed in and very gently tapped into place
    with a rawhide mallet...
    krusty kritter, Apr 26, 2005
  11. Thanx krusty! I will definitely try that...my output shaft seal is
    leaking like a mofo.
    Im not getting any air pulses from the oil filler hole, though. Would
    "smokeless" synthetic still put out some smoke if my piston rings were worn?
    Masospaghetti, May 1, 2005
  12. Maybe. The function of the piston rings on a 2-stroke engine isn't oil
    control, they work to hold in compression pressure. Suppose the hot
    gasses of combustion do leak past the rings and get to the fuel/air/oil
    mix in the crankcase. They could possibly make the "smokeless" oil that
    has gathered in the bottom of the crankcase get hot enough to make a
    visible vapor that wouldn't be seen if the synthetic oil was actually
    being burned in the combustion chamber...
    Got a barbecue or a hibachi? Take it outside, fire it up and pour a few
    tablespoons of your "smokeless" synthetic oil in a old pan and heat it
    up over glowing charcoal and see if it does start smoking like crazy...
    Maybe the smoke is coming from a lot of that "smokeless" oil in the
    bottom of your crankcase, or, as another poster said, from oil
    collected in your exhaust system. The only *other* source of oil smoke
    would be transmission oil leaking into the crankcase past a bad seal
    or, worse than that, the sealer on the mating surface between the case
    halves leaks and lets transmission oil into the crankcase. But you'd
    have air pulsing into the transmission if it was a leaky seal or leaky
    case halves...
    krusty kritter, May 2, 2005
  13. Well, I replaced my piston rings and the bike still smokes pretty bad.
    Is there anything else it could be? The smoke looks blue. Could it be
    the oil injection injecting too much oil?
    Masospaghetti, May 18, 2005
  14. Thanx for the advice. I'll try that.
    I did remove the tranny dipstick and couldn't feel any air, though.
