Smokin'
Discussion in 'Classic Motorbikes' started by ^..^ Lone Wolf, Feb 14, 2008.
  1. ^..^ Lone Wolf
    crn Guest
    Sounds like excess oil is accumulating in the case instead of being pumped
    back into the oil tank. If so that implies a weak oil pump which cannot
    keep up at tickover. Or maybe an internal oil leak putting excess oil
    into the crankcase.
    crn, Feb 16, 2008
  2. Wotcha.
    Yep - it would seem there is too much oil in there. I can rule out the
    internal leak - I've left the bottom off the crankcase for a good few hours
    and nothing gets past the pump. I've pulled the pump apart, and even fitted
    another one, but still no joy. It's looking like this is just a quirk of
    this particular engine. The more I try to cure it, the more puzzled I get.
    I've tried just about everything I can think of.
    Ah, the pleasures of owing a SOB ;-)
    ^..^ Lone Wolf, Feb 17, 2008
  3. ^..^ Lone Wolf
    A.Clews Guest
    Thus spake ^..^ Lone Wolf () unto the assembled multitudes:
    Seems odd that your other B31 with a supposedly identical engine doesn't do
    this. What about comparing the positioning, shape or design of the oil
    pickup in both engines?
    A.Clews, Feb 17, 2008
  4. ^..^ Lone Wolf
    A.Clews Guest
    Have you compared the 'behaviour' and appearance of the oil return with
    that of your other B31? i.e. does the oil return on your non-smoking B31
    also splutter when the bike is on its sidestand or is it a steady flow?
    Do the bikes lean on their sidestands at different angles? Perhaps you
    should try swapping the sidestands to see if that makes a difference :)
  5. ^..^ Lone Wolf
    Tim Guest
    Will you have to get a £10 smoking licence for this SOB?
    Tim, Feb 17, 2008
  6. Wotcha.
    One of the first things I tried was the rings. There are some Italian ones
    around that are next to useless. I managed to find some genuine Hepolite
    ones and promptly fitted 'em. No different at all. Thinking the bore
    itself may be suspect ( although nothing measured up as worn, and it already
    had a fairly new piston ) I ordered a new piston and had the barrel bored to
    suit - .004" clearance. It still smokes.
    Cheers.
  7. Wotcha.
    I've swapped the oil pump from one to the other - it makes no difference.
    I've even wondered if the flywheels in the smokey one are of a larger
    diameter, but short of pulling the engine apart there ain't an easy way of
    measuring 'em.
  8. Wotcha.
    They both do what they are supposed to. Full flow as the oil is cleared
    initially, then plenty of air bubbles as it scavenges correctly.
    Hmm - now there's an idea.
    The one just might be leaning that little bit too far, thus allowing the
    flywheel to dip into the accumulated oil.
    <<goes out to the garage>>
    Watch this space ;-)
  9. Wotcha.
    I rather hope it will work similar to the VED - being old and decrepit[1],
    they will not levy a tax on it :)
    [1] A bit like the rider, really.
  10. Wotcha.
    Oh dear - replying to myself now.
    I've just been playing at motorbikes ;-)
    The smokey one does lean a tad further than the non smokey one.
    http://www.lonewolf.me.uk/LWMEimages/angleofdangle.jpg
    The yellow one is the smoking machine.
    I dragged the thing down to the river, I must admit the temptation to lob
    the bugger in was great, but I resisted and performed a little experiment.
    With the bike almost vertical, it does smoke a little, but that could be
    residual oil in the down pipe.
    When on the side stand, smoke starts within less than a minute.
    http://www.lonewolf.me.uk/LWMEvideo/smokeyb31.wmv
    My next plan of attack is to remove the "sump plate" and see if I can modify
    both it and the oil pump pick up.
    Once again - watch this space ;-)
  11. Wotcha.
    Believe me, this has crossed my mind, but short of pulling the engine apart,
    there ain't an easy way to measure 'em.
    Ah well - back to the garage with it.
  12. ^..^ Lone Wolf
    Tim Guest
    While I think of it, what did you do about 4-star fuel? Did you get the
    head done and if so where did you go?
    Tim, Feb 17, 2008
  13. ^..^ Lone Wolf
    One last thought on differences, do you use the same oil on both?
    Pip Luscher, Feb 17, 2008
  14. Wotcha.
    There's a Texaco garage by me that still sells leaded four star - hell of a
    price though.
    I don't bother with it, although my mate bungs a few quids worth in his
    Starfire every now and again.
    I'll get the head done when the valve seats start packing up - same on the
    Guzzi, and that's been running for about five or six years now with no ill
    effects ( famous last words - you just watch the exhaust valve seat drop out
    now ).
  15. Wotcha.
    Yep - same oil in just about everything I run.
    I just happen to have a spare B33 bottom end - which is the same as the B31.
    This spare bottom end was sat, upside down on the bench, and used to compare
    clearances with the smokey engine. It seems the flywheels are the same
    size. Bugger ! I removed the oil pump and made an extension so that it now
    reaches to the bottom of the sump plate. The whole plot was put back
    together - and the result was a resounding failure :) Thinking that the
    oil may have somehow been getting down the valve guides when the bike was
    leaned over, the next move was taking the oil feed from the head and routing
    it directly back to the oil tank. No difference at all. I then removed the
    sidestand and modified it so that the bike sits more upright. OK - this
    hasn't stopped it smoking, but it take a bit longer before it starts now.
    I've sourced a new oil pump - so that will be going in as soon as I get it.
    My 'project B33' needs a new pump anyway, so it's a win-win situation.
    Anyroad - it's getting too chilly to be playing at motorbikes, so I'm
    grabbing my tea, then hitting the pub.
  16. ^..^ Lone Wolf
    A.Clews Guest
    I notice from your video clip that the idle speed is a lot faster when the
    bike is on its side stand. Might that be significant? What if you up the
    revs to match the leaning idle speed when the bike is upright?
    A.Clews, Feb 18, 2008
  17. ^..^ Lone Wolf
    A.Clews Guest
    Thus spake Ross () unto the assembled multitudes:
    It's 33 years since I touched a BSA but I don't recall any particular
    problem removing and refitting a rear wheel.
    I think the only problem you need be wary of is the back wheel covered in
    oily muck, mostly originating from the engine. That's what used to happen
    with my C15 and I have no reason to think a Starfire will behave any
    differently :)
    The usual warning about making sure your tyre levers don't repuncture the
    tube applies, of course... but I'm sure you already know that.
  18. Wotcha.
    I deliberately turned the engine speed up - it moves the oil quicker ( to no
    avail ) and also lets the bike run for a few minutes longer before the
    amount of oil fouls the plug and the whole plot splutters to a halt. It
    smokes just as bad if you turn the tickover back to normal when on the
    sidestand.
    Cheers.
    ^..^ Lone Wolf, Feb 18, 2008
  19. Wotcha,
    No serious problems. It should be a "quick detach" wheel. Just remove the
    spindle and spacer, from the right hand side, and the wheel will pull out.
    It's on splines - the sprocket and brake drum remain where they are. Same
    back wheel ( more or less ) as early B31 - B33.
  20. Wotcha.
    No such luxury on BSA pre-unit singles, I'm afraid.
    Cheers.
Similar Threads
Loading...
