Smelly Helmets
Discussion in 'UK Motorcycles' started by Tosspot, Sep 15, 2008.
  1. Tosspot
    Tosspot Guest
    It must be said, it went a bit mouldy over the winter, the usual, it'll
    pass has not worked.
    What does the FOAK reckon to clean/destink a lid. Fabreze springs to
    mind :(
  2. Tosspot
    Steve Parry Guest
    Wash it, fill it with soapy water and give the insides a good cleaning then
    leave in the air cupboard to dry fully
    Steve Parry
    BMW R80RS, BMW R45, 01 Kawasaki ZX12-R, 07 K1200GT SE
    95 BMW F650, 87 Yamaha FS1, Sukida SK90PY, 91 Kawasaki AR50,
    07 VW Passat SE Estate for comfort
    www.gwynfryn.co.uk
    Steve Parry, Sep 15, 2008
  3. Tosspot
    Febreze will only cover up the smell. Try one of the dry foam carpet
    cleaners. After you see how much gunge comes out of the liner & foam you
    might just go buy a new helmet...
    http://www.1001carpetcare.co.uk/product-range/spot-stain-removal/mousse.html
    wessie, Sep 15, 2008
  4. Tosspot
    Domènec Guest
    Your local shop should have one or more products. At least they do where it
    is warmer and we people sweat a lot. Some can be found here:
    http://www.johnsofromford.co.uk/clothing_accessories.htm
    (I assume you have neither removable liner nor cheek pads).
    Domènec, Sep 15, 2008
  5. Tosspot
    Tosspot Guest
    A Helmet Sanitiser! I couln't, I mean really couldn't go into a shop
    and ask for that.
    Might go for the soaking approach.
  6. Tosspot
    Domènec Guest
    Why? Is it übergay?
    Removable liner? The best you can do (and I do).
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Blott
    Snowy's the gel for that, IWHT.
    Snowy! Bloke here says his helmet pongs a bit. Can you help?
    Wicked Uncle Nigel, Sep 15, 2008
  8. Tosspot
    Tosspot Guest
    <sigh> I knew this was going to happen.
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Tosspot
    What? What?
    WHAT?
  10. Tosspot
    Eddie Guest
    I'm surprised it took so long, TBH.
    Eddie, Sep 15, 2008
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, Eddie
    Well, I'm mystified.
    Someone suggests some equestrian stuff, I suggest that Snowy would be
    able to advise on that, and you lot get all uppity.
    You're all odd.
  12. Tosspot
    Eddie Guest
    Uppity? That wasn't uppity, that was a sense of resignation to the
    inevitable.
    That's probably true.
    BTW: Did you get my email regarding your kind offer last week?
    Eddie, Sep 15, 2008
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Eddie
    I did not. The gmail address in the headers should work.
  14. Tosspot
    Piss, same as for trench foot. Tape up the vents and visor, brim it with
    the amber nectar, leave it for a week to soak. Sorted.
    platypus, Sep 15, 2008
  15. Tosspot
    Eddie Guest
    Hmmm, that's the one I used last time. I'll try again...
    <fx:pause>
    My mail server says its given it to gmail; you should have mail.
    Eddie, Sep 15, 2008
  16. Tosspot
    zymurgy Guest
    You really are going mental in your old age.
    Auvache, is that you ?
    P.
    zymurgy, Sep 16, 2008
  17. Tosspot
    boots Guest
    You could get a cat to piss in it. After that the slight smell of
    mould won't really bother you.
    boots, Sep 16, 2008
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, Eddie
    Hmm...
    Not so's you'd notice. Sorry about this.
    Try nigel.eaton at gmail.
    Wicked Uncle Nigel, Sep 16, 2008
  19. Tosspot
    Eddie Guest
    No, no, don't apologise. *You're* doing *me* a favour, remember?
    Okay, it should be on its way. Again.
    Eddie, Sep 16, 2008
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Eddie
    The whole froup will be delighted and relieved to hear that I got that
    one.
