Small diameter bolt broken off below surface - suggestions please
Discussion in 'UK Motorcycles' started by TMack, Apr 28, 2007.
  1. TMack
    TMack Guest
    Working on the engine of the spare "donor" bike for my SO LS650. I removed
    head cover but one bolt broke off about 5 to 7mm below the surface of the
    mating face on the cylinder head that the head cover bolts on to. I reckon
    there may be 15 to 20 mm of bolt left in the hole. It is an M6 bolt so the
    hole doesn't leave much room. I need to be careful because I don't want to
    scratch the mating surface around the hole. If all else fails I should be
    able to drill it out and helicoil it but I want to avoid that if possible.
    My current plan is to get some left hand drill bits and try to drill it out,
    starting with a smaller diameter bit and working up in diameter, hoping that
    it will free off due to heat, vibration and anticlockwise drill rotation
    before the threads in the head get damaged. Any better ideas?
    TMack, Apr 28, 2007
  2. TMack
    R Guest
    Plan A sounds feasible. Plenty of Plus Gas etc will help.
    Can you get any reasonable heat to it to assist the removal?
    R, Apr 28, 2007
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, TMack
    Sounds good to me. If you can get a centre punch down to the stub first,
    even more betterer.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Honda GL1000K2 (Falling apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Wicked Uncle Nigel, Apr 28, 2007
  4. TMack
    Dave Emerson Guest
    Where are you?
    I've got a special tool to fix this exact problem, it's a short LH drill tip
    with an expanding collar.
    The tip drills into the core of the stud, which is sometimes enough to do
    the job anyway, then the collar feeds into the hole and locks, so the torque
    of the drill forces the stud out.
    This widget cost $35 from the US should be treated with some care but,
    though it's only meant for 6mm studs, I've used it successfully for 8mm and
    even 10mm...
    Dave Emerson, Apr 28, 2007
  5. TMack
    Beav Guest
    You'd be in a better position if the head is mounted solidly in a drill
    press. Going at it wth a hand held drill is going to be a difficult
    proposition.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Apr 28, 2007
  6. TMack
    10 minutes work with a small pin punch, a scriber and a 1/2 lb hammer.
    Just make a small punch mark on the edge of the broken bolt and then
    turn it out by hand. Works for me.
    Andy Bonwick, May 3, 2007
