Slipping Clutch
Discussion in 'Australian Motorcycles' started by giraffe, Aug 12, 2003.
  1. giraffe
    giraffe Guest
    Hi,
    On my 1989 GS500 the clutch is recently slipping and I don't know how to
    adjust it. This all started to happen after I borrowed the bike to a young
    male friend :)
    I received a phone call late at night, the guy told me all of a sudden the
    engine stopped driving the rear wheel, it would rev freely but the front
    sprocket was not spinning.
    The bike was loaded onto a truck and ended up in a garage where I went to
    work on it with a friend.
    We found that there's a grub-screw on the left side of the bike behind a
    little cover, the grub screw had a locknut and a slot on it so that it could
    be turned into and away from the "engine" - this would adjust the clutch
    until the bike would move forward.
    Unfortunately after a lot of adjusting the bike would still slip at higher
    RPM, it would pull nicely at low RPM but once in the powerband it would
    begin to rev out.
    I should mention that while trying to adjust the clutch cable (before we
    found the grub screw) we actually damaged the clutch lever adjuster, I will
    look for a replacement today and install it but i'm not sure if this will
    end my problems.
    Would anyone like to provide some insights into the problem ? I was recently
    told that my clutch with "only" 41,000km should still have plenty of life
    left !
    Thanks !
  2. giraffe
    vinyl Guest
    How does one "borrow" something TO someone?
    vinyl, Aug 13, 2003
