This weekend, I wheeled the thing out from under its tarpaulin and started looking closer at what I've actually got. First impressions: the paint job really is very high quality. I like the black/ yellow colour scheme, so I'm keeping it. Less good is the black paint splashed by the previous owner on every other bit of chrome apart from the bars, but I'm working on that. First replacement: the filler cap. Undo black painted cap, scre won shiny new chrome one (£4 or so from Dave Silver). Sorted. Silver also provided four nice chrome pattern indicators. These, on inspection, had one wire coming out. The ones on the bike had two. One is power, the other earth, and inside the indicators the earth has been bodged to earth to the indicator reflector. Trying to earth it to anything else drew a blank, so I attached one indicator, and then found it as reluctant to flash. Hm. I had a moment's suspicion, and inspected the bulb. Yup, I've been sold four 12v indicators, so I'll have to swap all the bulbs as well. No worries. The front brake light switch was u/s, but I've got several spares, and so one such was plumbed into the wiring loom, proved to be working fine, and was fitted. All other electrical functions tested and found OK. The front brake lever is a clutch lever turned upside-down, and in my Big Bix Of Old Levers I had nothing that fitted, so I'll get one at Kempton. Removed seat to inspect pan. One crack in the side. Some spot weld blobs and a bit of reinforcement will sort that. Otherwise the seat is great. One side panel mounting bobble has snaped off and been badly repaired. I'll sort it properly with some glass fibre reinforcement. Fitted right-hand mirror. Left-hand lever mount has no mirror fixing point. I suspect it's non-standard. Lots of fasteners have been black painted and will need replacement, but I have two big tins of stainless fasteners, so that will be easy. Looked dubiously at camchain adjuster, whicvh is wound pretty much near its limit. I've bought a secondhand engine (condition unknown), and I have in my possession a spare camchain, tensioner and gasket set, so I'm not too bothered. Exhaust needs to come off to be repainted. Exhaust heat shield needs to be refinished as well. It should be chrome. It's been repainted... guess what? I'll use some silver Smoothrite on it. All in all, a decent running bike that can be worked on and improved as it needs to be.
