Silly in the snow
Discussion in 'UK Motorcycles' started by TOG@Toil, Jan 7, 2010.
  1. No, it's not.
    The Older Gentleman, Jan 8, 2010
  2. Can you identify him? You'd have a tough job.
    Sorry, but you're pontificating on something about which you know, as
    you've just proved, very little.
    I'd take Corfield's word on this any day. There are some people on ukrm
    with whom you don't argue on certain topics - Sweller on anything
    political, Ivan on science, and Corfield on railways.
  3. TOG@Toil
    In charge of what? The track and signals are controlled by Network Rail
    bu the trains are controlled by the Train Operating Companies forming
    ATOC. All of this is overseen by the legendarily toothless SRA.
    There is nobody 'in charge' which is half the problem. Every party
    points the finger at somebody else.
    ogden, Jan 8, 2010
  4. TOG@Toil
    Francis Guest
    Bullshit.
    And I prove it with the SNCF own stats for my region:
    url:http://www.ter-sncf.com/Images/Aquitaine/Tridion/nov%
    202009_tcm11-26036.pdf
    Worse, the SNCF does not use the number of trains that should have run on
    a given day but those that really started: the cancelled trains are
    computed as "on time"...
    Francis, Jan 8, 2010
  5. Yes, usually.
    Quite surreal.
  6. Makes sense in a strange way.
    If they never left, they can't be late.
    Grimly Curmudgeon, Jan 8, 2010
  7. "Sheep have 'forgotten how to cope with snow'"
    http://www.telegraph.co.uk/news/ukn...eep-have-forgotten-how-to-cope-with-snow.html
    Dr Ivan D. Reid, Jan 8, 2010
  8. TOG@Toil
    frag Guest
    took a blunt brush and painted...
    Err, that is Des you're talking to there. New around here are you? :)
    frag, Jan 9, 2010
  9. TOG@Toil
    Cab Guest
    Des is talking bollocks again. Line C is also a bloody nightmare as are
    a lot of the RER lines and the Transilien. SWMBO was up the creek recently
    when a numpty crashed into a block of concrete which then fell onto the rails
    and caused two weeks worth of hassle (the SNCF had promised to repair it within
    three working days).
    Even French trains get affected by snow (witnessed recently when I dropped
    off the SiL at Austerlitz and the last 12 trains were delayed from parting
    from 30 mins up.
    Every time I travel back from Lyon by TGV, the trains are _always_ delayed
    getting into Paris.
    The service is good, but by no means 99% good.
    Cab, Jan 9, 2010
  10. TOG@Toil
    No need, that's a pretty good summary.
    Personally, I don't have too great a problem with the DfT. I'd rather
    they actually take the whole shooting match off the franchises (and FOCs)
    and direct it as an integrated whole.
    sweller, Jan 9, 2010
  11. TOG@Toil
    LUL is pretty phenomenal when you consider the sheer volume of people
    moved. The problem now is not so much the trains but the physical
    limitations of the stations themselves.
    Footfall is the next big capacity problem facing both the 'overground'
    and LUL.
  12. TOG@Toil
    I travel on the railways nearly every day - both long distance and the
    usual commute and that is simply not my experience.
    Under-investment yes, too much profiteering yes, but not biblically crap.
    I very rarely stand but it's worth bearing in mind the sheer numbers of
    people shifted on a daily basis.
    The reason people commute such long distance is another question
    altogether...
  13. TOG@Toil
    And maybe call it something snappy like British Rail?
    ogden, Jan 9, 2010
  14. TOG@Toil
    The railway network and the timetabling are gloriously complex but I guess
    one can sit a wonderful team of experts down to design a working system.
    Then decide what it is going to cost. How do you insulate a working system
    from petty politics and changing politics. How do you tie future
    governments into the required budget. How do you build in the flexibility
    to adapt to change in a positive affordable manner.
    A Not for Profit company in public/private ownership perhaps?
    Has the public auditor ever tried to calculate the extra cost of the
    complexity and bureaucracy in the current system againt an alternative
    model?
    Hog, Jan 10, 2010
  15. TOG@Toil
    Saved me a fair bit of typing.
    Crudely the problem boils down to public finances. Road infrastructure
    expenditure is accounted as investment whereas railway is counted as
    subsidy.
    Until that playing field is levelled the madness will continue.
    sweller, Jan 10, 2010
  16. TOG@Toil
    It is a quite bizzarely complex issue, and add in the enormous hurdles in
    the way of building new routes. The network only seems to be around 50% of
    what could be used in terms of passenger and freight capacity and
    geographical coverage.
    Perhaps start with the freight capacity and coverage. One reason being the
    costs of maintenance of the road network, which is quite well designed for
    moving people around, in relative terms. I've a friend at Mouchel who is one
    of the principal pavement engineers and was told recently wear calculations
    are based on freight and weather. Cars make marginal extra impact.
    Oh well, as against what it cost pre Thatcher and what some of the other
    countries spend now per freight ton and passenger, per mile. ICBW but I
    expect the costs of the legal and administrative complexity are not small.
    Hog, Jan 10, 2010
  17. TOG@Toil
    Road users pay more in VED tax than the Exchequer spends on roads I think so
    one can see where that kind of thinking might come from.
    If I was asked to contribute 50% more VED to to fund a 20 year plan to take
    a significant portion of HGV freight off the roads I'd be willing enough.
    Don't you think that specific taxation taken from users of transport
    infrastructure should all be used for said infrastructure though?
    Hog, Jan 10, 2010
  18. TOG@Toil
    Well it might need a redesign of the hub and spoke freight model but a great
    deal of product is moved like that anyway, is it not?
    Hog, Jan 10, 2010
  19. I think this is fair, especially the 'fly by night' comment.
    The Older Gentleman, Jan 10, 2010
  20. TOG@Toil
    It's worth noting that even though studs are illegal over here you can
    buy them from touratech if you feel the need to behave badly.
    Andy Bonwick, Jan 11, 2010
