Silly in the snow
Discussion in 'UK Motorcycles' started by TOG@Toil, Jan 7, 2010.
  1. TOG@Toil
    TOG@Toil Guest
    Is defined as deciding that buggrit, you're going to dig out the GN250
    and make it into work. Cleared the paper from home and set out at
    11.20am.
    Actually, once I'd get a couple of miles from home, the roads were
    mostly clear of ice, although every sidestreet round our way, and the
    street outside the new office (Leonard Street, EC) were like glass.
    Main streets in the City are fine.
    Feet out like outrigger skis on a French Nutter's BMW GS, into the
    kerb and onto the broken surface of the ice, bottom gear and hope.
    I only saw one other bloke on a motorcycle in the entire trip, and he
    was on a CG125[1]. Plus two bods on scooters.
    Return journey will be interesting, though, as it's freezing again.
  2. TOG@Toil
    I saw a bloke on a big trailie riding up Wimbledon Park Road this
    morning. Fool.
    "Minor delays are occurring between Earl's Court and Wimbledon due to a
    signal failure at East Putney."
    Ho hum.
    ogden, Jan 7, 2010
  3. TOG@Toil
    Frag.
    ogden, Jan 7, 2010
  4. TOG@Toil
    DozynSleepy Guest
    Heh !
    http://www.whocanisue.com/
    DozynSleepy, Jan 7, 2010
  5. TOG@Toil
    TOG@Toil Guest
    Argh
    [1] Makes Sign Of Holy Pushrods[2]
    [2] And Holy Gyroscope Up Arse
  6. TOG@Toil
    Catman Guest
    Have you looked at the dish to see if it's covered in snow?
    www.cuore-sportivo.co.uk
    Catman, Jan 7, 2010
  7. TOG@Toil
    ian field Guest
    According to yesterdays weather forecast, we're going to get what for on
    Sunday.
    ian field, Jan 7, 2010
  8. TOG@Toil
    It doesn't, as Sweller has said.
    You could use the metre long HD 'ties to hold something decent onto your
    tyre, but you generally run into 'arm/mudguard clearance issues.
    Next size down mud tyre with studs.
    Hog, Jan 7, 2010
  9. TOG@Toil
    Catman Guest
    Freeview? Cable? I thought they were free anyway.
    Catman, Jan 7, 2010
  10. TOG@Toil
    B 650 Guest
    Excellent, glad I worked from home today then....
    B 650, Jan 7, 2010
  11. TOG@Toil
    It only says minor.
    It said severe delays the other day and it only took me an extra 10
    minutes to get to work. Another day it was "part suspended" and I was
    still only half an hour behind usual.
    ogden, Jan 7, 2010
  12. Somebody recounted how they'd used scrap cable as makeshift grippers.
    Grimly Curmudgeon, Jan 7, 2010
  13. TOG@Toil
    A few JH-203A would do the trick, and cheap
    www.blacktoe.co.uk
    But it will be kinda grip>slip>grip>slip as the wheel turns.
    Hog, Jan 7, 2010
  14. Oh Gawd. Got home again without incident, but the side streets are
    basically skid pans.
    The Older Gentleman, Jan 7, 2010
  15. TOG@Toil
    frag Guest
    frag, Jan 7, 2010
  16. TOG@Toil
    ian field Guest
    Today's forecast showed the same weather map for Sunday again, so the
    chances they've been over pessimistic are diminishing.
    At the very least, I'll wait for the cars to pack it down for me.
  17. *Cough*
    Remind me: which country managed to get five Eurostars to break down *in
    the same day* just the other week?
  18. TOG@Toil
    I bet they can snip posts too
    wessie, Jan 7, 2010
  19. TOG@Toil
    ginge Guest
    There isn't one. There isn't even a "British Rail" now, it's all
    privatised, with franchises running the various regions, and railtrack
    is the organisation that own the lines.
    ginge, Jan 7, 2010
  20. [...]
    Oh, that's OK, then. After all, the invisible hand of the free market
    will ensure you get the best possible services for your money. <snicker>
    Leszek Karlik, Jan 8, 2010
