Currently rebuilding my 1969 BSA B44 VS and the time has come to strip it back to the frame for powder coating. I have a quick question about silentbloc bushes in the swinging arm. I've not come across these before and am not sure how they're meant to work. If the swinging arm shaft is not tightened at both ends the swinging arm has unacceptable play. If I fasten the plate at the left hand end and tighten the nut at the right hand end of the shaft the whole swinging arm seems to be held tightly and be damped in its up/down movement. Is this how it is meant to be? IE, does tightening the sw. arm shaft compress the rubber in the bushes to its working tension? How can I tell if the silentbloc bushes need replacing? cheers Antony
