Silent Intel 775 CPU Cooler
Discussion in 'UK Motorcycles' started by deadmail, Sep 9, 2006.
  1. deadmail
    deadmail Guest
    OK, as subject, has anyone a recommendation for a quite cooler for an
    intel 775 CPU?
    I'm building a(nother) media centre PC and whilst the case fan, PSU and
    hard drive are all nice and quiet the CPU fan is loud enough to be
    irritating.
  2. deadmail
    Antonio Guest
    The movies you are watching aren't loud enough then.
    Zalman is a good start. Try here for an idea on products
    http://www.quietpc.com/gb-en-gbp/products/intelcooling
    Ebuyer is a good place to see reviews and any bargains on 'em.
    You might want to try
    http://www.ebuyer.com/UK/product/108402 and
    http://www.ebuyer.com/UK/product/98869
    Antonio, Sep 9, 2006
  3. deadmail
    Antonio Guest
    Whoops that ones gone. It would be the following but thats gone too. Looks
    like they are fresh out. Quietpc is probably a better stop after all, just
    check the reviews on ebuyer.
    http://www.ebuyer.com/UK/product/103639
  4. deadmail
    muddy cat Guest
    Do they have the liquid cooling thingys like the Cray used?
    muddy cat, Sep 9, 2006
  5. deadmail
    Antonio Guest
    Liquid cooled is for poncy show offs with open cases or glass sided desktop
    pcs, but perhaps not suited to the role of a media centre PC. Coolant leak
    is less forgiving in a pc as well.
    Mind you having a media centre pc that was a talking point (goldfish etc or
    go one up with piranha) could be an interesting direction.
  6. deadmail
    deadmail Guest
    Yes, but water cooling is too much of a pain. I just want something
    quieter. I suppose I should wait until I've got the cases back on 'cos
    it might be good enough.
  7. deadmail
    Dan White Guest
    Sorry, I just have to...
    A quite *what*?
    That should sort you out.
    If you want a 3.5" hard drive enclosure, I have one of those going spare.
    Dan White, Sep 9, 2006
  8. deadmail
    deadmail Guest
    "life's too short to proof read usenet"TM
    Well, I'm looking for people's personal recommendations on what they've
    used 'cos it all looks fine and dandy but they're flogging the stuff
    after all.
    Not sure about the noise ratings 'cos most of them have a considerable
    range and, in any case, I don't know how loud the standard Intel cooler
    is.
    Not for me thanks, I think the case is plenty cool enough without
    additional cooling for HD.
  9. deadmail
    Dan White Guest
    Right, well I have an AMD CPU, but the last cooler I brought from them was
    silent until run at full power[1], when it was merely "bloody quiet".
    Regular blasting with a compressed air can is a good idea whichever fan you
    get.
    It's not a cooling enclosure, it's an 5 1/4" acoustic enclosure that you fit
    a 3.5" drive into to reduce the noise. Two aluminium plates draw out the
    heat to the side of the case.
    [1] It came with 3 resistive power cables, so you could up the speed if you
    got a faster processor.
  10. deadmail
    OH- Guest
    If your motherboard has CPU fan speed control, check out the
    Arctic Alpine 7. Not terribly loud at full speed and both good
    cooling and low noise at lower speed. And cheap, no frills like
    heavy copper, fashionable heatpipes or cheesy LEDs.
    OH-, Sep 9, 2006
  11. deadmail
    Cab Guest
    I concur with the one with the spiccy sounding name. I've got one in
    the media centre PC, I built.
    Cab, Sep 10, 2006
  12. deadmail
    Christofire Guest
    I've helped build two PCs with water cooling for friends and installed
    Asetek kits in both. They've never leaked in over two years.
    Apart from having to mount the radiator outside the box due to limited
    space inside, I don't see why it's not suited. Running the fans on a
    slower setting[1] would make for a very quiet PC.
    However, for a silent PC the OP might look to see if there's a media
    centre version of http://www.quietpc.com/gb-en-gbp/products/tnn/tnn500af
    [1] there's 7v and 12v settings on the Asetek kits
    Christofire, Sep 10, 2006
  13. deadmail
    Christofire Guest
    If you can get access to the foam eggbox shaped packing that computer
    bits sometimes come packed in, putting some opposite the fan on the
    case side may help.
    I tried this with mine and it worked a bit, but this isn't a media pc
    case so I don't know if it's possible for yours.
  14. deadmail
    deadmail Guest
    Six hundred quid... FFS.
    It's just the CPU fan that's a bit loud. The rest is quiet enough; hard
    drives, case fans and PSU.
    deadmail, Sep 10, 2006
  15. deadmail
    deadmail Guest
    I'm using one of these:
    http://www.silverstonetek.com/products-lc17.htm
    So there's ample room. I think I'll replace the CPU fan though since if
    I run it disconnected (briefly) things are much quieter.
  16. deadmail
    Christofire Guest
    Looks quite nice that.
    On that quietpc site they sell noise reduction foam for quite high
    prices. Hence I tried the packing foam.
  17. deadmail
    deadmail Guest
    Well, I've gone for something from that crowd. And replacement case
    fans as well.
  18. deadmail
    Guest Guest
    I can recommend these as very effective and quiet, though it is tall. I
    bought from these people aswell.
    http://www.shinyhardware.co.uk/products/product.asp/pid=172
    Chri$
    Guest, Sep 12, 2006
