Silencer repair & MOT
Discussion in 'Classic Motorbikes' started by Ace, Aug 23, 2004.
  1. Ace
    Ben Blaney Guest
    I'll give you a call on Friday and let you know.
    Ben Blaney, Aug 24, 2004
  2. Ace
    'Hog Guest
    Gun Gum is not in itself very strong. The Quicksteel stuff Pip and Loz refer
    to should hold Space Shuttle wing tiles on.
    'Hog, Aug 24, 2004
  3. Ace
    Right. This I know, having used both. But for a tape-wrapped rotten
    silencer repair, it seems to me that the former would be perfectly
    good enough and likely to last just as long as the latter.
    I'm interested to learn if I'm wrong about this, and why.
    Ace, Aug 24, 2004
  4. Ace
    'Hog Guest
    Er I've used gum years ago and it fell of after a few days is all I can say.
    I was young and eager, probably didn't prepare the surface very well.
    'Hog, Aug 24, 2004
  5. Ace
    That's a comforting recommendation.
    sweller, Aug 24, 2004
  6. Ace
    Andy Clews Guest
    Comforting, but expensive. Have you seen the price of space shuttle tiles
    lately? And why exactly would you want to glue them to your exhaust
    system? It may not do you any good anyway. You only need a bit of fuel
    tank insulation to fall away when you're next doing Mach 3 and it'll punch
    right through the tiles and you'll be toast.
    I'll get my coat...
    Andy Clews, Aug 24, 2004
  7. 'Swot I thought, but I bunged a big gob of it onto my old CD175 pipes
    (which were also rotting from the inside out) and it lasted for a couple
    of years.
    The Older Gentleman, Aug 24, 2004
  8. Ace
    sweller says...
    A fiver a tube from your local car parts emporium. It's currently
    holding the CB250RS exhaust together, and has got the bike through 2
    strict MOTs.
    Lozzo, Aug 24, 2004
  9. Ace
    Shep© Guest
    Any of the,"Liquid Metals" from B&Q.If hole is big then any bit of
    Coke can cut with good Scissors(don't tell the missus or your Mam)
    that you used them.
    PS
    Just tried some,"JB-Weld" Yankee stuff.£4.99 for two tubes.No better
    than any £2.99 loctite or any other brand.Typical Yanks.All bollocks
    and hype.
    Free Windows/PC help,
    http://www.geocities.com/sheppola/trouble.html
    remove obvious to reply
    email
    Free songs to download and,"BURN" :O)
    http://www.soundclick.com/bands/8/nomessiahsmusic.htm
    Shep©, Aug 25, 2004
  10. Gun Gum is not in itself very strong. The Quicksteel stuff Pip and Loz refer
    [/QUOTE]
    So your saying it's basically shite if you have to rely on it for your
    life.
    I'll get my EVA suit..........................
    Mick Whittingham, Aug 25, 2004
  11. Ace
    Rob Guest
    I think it was on Mon, 23 Aug 2004 17:25:34 +0100 that "'Hog"
    Gun Gum has a tendancy to shrink a bit when it gets hot which is a bit
    of a disadvantage for a product that's supposed to repair exhaust
    systems.
    I've used it to get cars through the MoT (with a bit of oil can
    jubilee-clipped around the bodge) but after a week or so it usually
    starts blowing again, but then again after passing the test you've got
    another 12 months to sort it <G>
    Not tried any of the chemical metal type products yet, but I think the
    expansion box (or whatever it's called) on my Virago is getting a bit
    thin/rusty so I may need to experiment for next year's test.
    Rob
    Rob
    Broseley, Shropshire
    1991 Yamaha XV 535 Virago
    1997 Rover 623GSi
    Rob, Aug 25, 2004
  12. Ace
    Rob says...
    Collector box, and you can buy pattern ones for Viagra 535s
    Lozzo, Aug 26, 2004
  13. Ace
    Rob Guest
    I think it was on Thu, 26 Aug 2004 00:10:23 +0100 that Lozzo
    Thanks for that info, I thought that the Virago exhaust was a one
    piece £400 jobbie only available from Yamaha. I'll have to go Googling
    for suppliers.
    Rob
    Rob
    1997 Rover 623GSi
    Rob, Aug 26, 2004
  14. I didn't know that. It's always a sign of a crappy component if the
    pattern manufacturers reckon it's worth their while tooling up to make
    copies.
    The Older Gentleman, Aug 26, 2004
  15. Ace
    The Older Gentleman says...
    The rear downpipe is usually the first to go on these. You can get
    pattern ones as well.
    Lozzo, Aug 26, 2004
  16. Ace
    Sir.Tony Guest
    Its CB-1 400. He rides too fast on the road. I saw him jump a red light.
    U all ride safely, now ;-)
    Sir.Tony, Aug 26, 2004
  17. Ace
    Sir.Tony Guest
