Silencer repair & MOT
Discussion in 'Classic Motorbikes' started by Ace, Aug 23, 2004.
  1. Ace
    Just noticed a hole in the silencer on the 400/4 wot I'm flogging to
    Blaney next week and was thinking of patching it up so's he can get it
    through the MOT when he gets home on it.
    So, two question:
    Is ye olde 'Holts Gun Gum' still the best tool for the job?
    Will such a repair be acceptable for the MOT test?
    Ace, Aug 23, 2004
  2. Ace
    Cammo Guest
    Any exhaust paste should do. Cut up a beer can and jubilee clip it round the
    repair to be sure.
    Yes. Done it lots of times.
    "A durable repair to an exhaust system which effectively prevents leaks is
    acceptable providing the system is structurally sound."
    http://www.motuk.co.uk/mcmanual_620.htm
    Cammo, Aug 23, 2004
  3. Ace
    Paul - xxx Guest
    Ace vaguely muttered something like ...
    I dunno the technical wording, but if you can pull it off, it shouldn't be
    good enough and should fail an MOT. If you try to pull it off and it won't
    come, and still doesn't allow leakage then it'll be OK and should pass the
    MOT .. ;)
    Paul ...
    (8(|) ... Homer Rocks
    "A tosser is a tosser, no matter what mode of transport they're using."
    Paul - xxx, Aug 23, 2004
  4. Ace
    Cheers Cammo - I thought it would still be the case but it's nice to
    be sure.
    Ace, Aug 23, 2004
  5. Ace
    'Hog Guest
    Wot about that liquid metal in a tin that Loz/nigeel/other always rave
    about. Gun Gum is a bit iffy.
    'Hog, Aug 23, 2004
  6. Ace
    SteveH Guest
    I've used ordinary car body filler in the past.
    SteveH, Aug 23, 2004
  7. Ace
    Molly Guest
    I did about a month ago to get Gareth's bike through the MOT.
    Molly, Aug 23, 2004
  8. Ace
    Bathroom sealer.
    If its a big hole (bigger than a 1p piece) small sheet of aluminium stuck
    on with bathroom sealer.
    Bathroom sealer is the stuff of Gods.
    sweller, Aug 23, 2004
  9. Chemical Metal. YKIMS.
    The Older Gentleman, Aug 23, 2004
  10. Ace
    [/QUOTE]
    I spit on your "Chemical Metal".
    Quiksteel roolz.
    Pip, Aug 23, 2004
  11. Ace
    Pip says...
    Quiksteel roolz.[/QUOTE]
    Quiksteel is holding my Honda exhaust together, has been for about a
    year now.
    Lozzo, Aug 23, 2004
  12. sweller wrote
    Dunnit melt though?
    Yeah, all right, I could see it working for the back end of a can, which
    isn't that hot but I would think twice about using it anywhere near the
    pipes.
    steve auvache, Aug 23, 2004
  13. Ace
    It's ok for header pipes - IME.
  14. sweller wrote
    I'll think twice if ever the opportunity presents itself then.
    Although be warned, Just think about what will be haunting you should
    it all go horribly wrong.
  15. Ace
    Dave Eades Guest
    Plumbers Mait is also good. it sets like concrete and can be sanded and
    painted after an hout. worked for me anyway
    Dave Eades, Aug 23, 2004
  16. It's all the same sort of stuff, anyway. Those aluminium epoxy mixes are
    the utter bollocks.
  17. Ace
    Ben Blaney Guest
    This will save me emailing you. I've ordered a new silencer from
    David Silver. They reckon they can get it to my parents' place by
    Friday (I leave early doors Saturday morning). I asked them to also
    send all associated items.
    So, we should be okay. <fingers crossed>
    Ben Blaney, Aug 24, 2004
  18. Ace
    On Mon, 23 Aug 2004 20:10:06 +0100,
    Wondered about that, but it's rotted on the underside of the silencer
    where the remaining metal seems to be about .001" thick, so I didn't
    think there'd be much left to key it onto, IYSWIM. Wouldn't it tend to
    just cause a bigger bit to vibrate free round the edges.
    Anyway, I got the Gun Gum (tape) last night so I'll give it a whirl
    later on.
    Ace, Aug 24, 2004
  19. Ace
    Oh, OK. I'll hold off the repair then. If it doesn't arrive, let me
    know on Friday and I'll do it before you arrive.
    Ace, Aug 24, 2004
  20. Ace
    In what way? Given that it's specifically aimed at silencer repair I'm
    not sure how it could be "iffy".
    I was only really trying to work out if it's been supereceded since I
    last used it about twenty years ago.
    Ace, Aug 24, 2004
