signal light problem....
Discussion in 'Motorbike Technical Discussion' started by jr41, Apr 24, 2007.
  1. jr41
    jr41 Guest
    hav a kawasaki gpx '91. lookd at all the globe, ther a.o.k., wat other
    areas should i look for??? jus wanted to see if i can fix it myself to
    sav $.
    jr41, Apr 24, 2007
  2. jr41
    Albrecht Guest
    If the turn signals don't work at all, check the fuses in the fuse
    panel.
    If the signals work ok on one side of the motorcycle, but don't work
    right on the other side, you know the flasher is probably ok.
    If one of the turn signal bulbs is burned out, the other bulb on that
    side will stay on when you push the turn signal button.
    Same thing will happen if one of the wires to a turn signal makes a
    bad connection.
    Same thing will happen if the contacts inside the turn signal socket
    are corroded.
    Albrecht, Apr 24, 2007
  3. And again, in English?
    The Older Gentleman, Apr 24, 2007
  4. jr41
    jr41 Guest
    basically none of the signal lights work at all. i checked the bulbs
    and the fuse, there fine. thought it would be that thing that makes
    the lights blinker but a mechanic told me if thats broken then the
    lights would still be on but but not flashing. so thats not it. what
    other areas can i look for in the bike??????
    much appreciate the help.....
    jr41, Apr 27, 2007
  5. Not necessarily. It could indeed be a fritzed flasher relay.
    Or the switch, or the wiring from the switch.
    The Older Gentleman, Apr 27, 2007
  6. jr41
    John Johnson Guest
    Yeah, though I'd probably check the wiring first (it's easier), then the
    switch, then the flasher relay. If the OP knows how to use a
    multi-meter, this stuff is fairly straightforward: check for voltage to
    the switch, check for voltage from the switch (and note how much drop
    there is), check for voltage to the flasher relay, check for voltage
    from the flasher relay (or some variation on this). At any point, when
    you lose the voltage, you test the particular part.
    As for the switch, I'd recommend pulling it apart and thoroughly
    cleaning it, no matter what. Clean contacts make a happy switch and will
    go a long way towards preventing other (sometimes expensive) troubles.
    If the OP doesn't really understand what I've just written...well
    they've got two choices:
    -ask for clarification and we'll walk you through it
    -find a friend who understands automotive electrics and give them
    pizza/beer to look at it. (ToG will do it if you wave a good-enough
    bottle of scotch under his nose ;-)
    Either option can be effective, depending on the circumstances. :)
    Later,
    John
    John Johnson, Apr 27, 2007
  7. jr41
    Mark Olson Guest
    Rather than using a voltmeter I strongly favor use of a test light.
    It won't tell you how much voltage drop there might be (other than
    a rough indication by glowing brighter/less brightly) but it does
    put a load on the circuit which is necessary to find high-resistance
    connections that a voltmeter won't indicate since it is a high impedance
    load.
    All that said, if the OP doesn't really understand electrickery, all
    bets are off and there's no substitute for having a knowledgeable
    person on scene. No amount of explaining measurement techniques is
    going to help much if the recipient just doesn't grasp the fundamentals
    of Ohm's/Kirchoff's/Thevenin's laws...
    Mark Olson, Apr 27, 2007
