.SIG Change
Discussion in 'UK Motorcycles' started by Nigel Eaton, Aug 29, 2004.
  1. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Nigel Eaton
    Bad form, and so on, but WTF.
    A quick furtle below decks tonight revealed that there are *two* centre
    stand levers. A big "I'm a centre stand lever, me" one that's totally
    impossible to use. And a small, discreet one alongside it.
    Tread on *that* one, and it's easier to put on the centre stand than the
    ZZR is.
    Amazing.
    Oh, and it's 381 kilos. Dry.
    Nigel - Manufacturer of the "Champion-104" range of rearsets
    WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20 BOTAFOT#150 HYPO#0(KoTL)
    Honda GL1000K2 Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Nigel Eaton, Aug 30, 2004
  2. Nigel Eaton
    I wonder if the Trophy has one of them.
    More fun dry, according to Lozzo.
    platypus, Aug 30, 2004
  3. Nigel Eaton
    Salad Dodger Guest
    I was right, then. 381 plays 370. ;-p
    | ___ Salad Dodger
    |_\_____/_| ..69684../..16324.../..3180./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:78 Pts:1680 Miles:5701
    Salad Dodger, Aug 30, 2004
  4. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    Wanna go double or quits for weight when the rider's on board? ;^)
    Nigel Eaton, Aug 31, 2004
  5. Nigel Eaton
    Salad Dodger Guest
    I reckon "quits" is favourite.
    | ___ Salad Dodger
    \|^|/ ANORAK#17
    Salad Dodger, Aug 31, 2004
  6. Nigel Eaton
    Nigel Eaton Guest
    Where's your sense of adventure man?
    Further reading of the manual reveals a claimed 120 HP output. Hmmm...
  7. Nigel Eaton
    Nigel Eaton wrote:
    Bloody heck! That's _heavy_.
    Muck, Aug 31, 2004
  8. Nigel Eaton
    Nigel Eaton says...
    So make that 400kg and 100bhp
    Lozzo, Aug 31, 2004
  9. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Muck
    Mmm-hmm. Pushing it backwards on gravel is an interesting experience.
    I'm considering buying a CG125[1] as a tug.
    If it ever gets tires and decides it would like a lie down I propose to
    let it.
    [1] Makes Sign Of Holy Pushrods
  10. Nigel Eaton
    Salad Dodger Guest
    Sir wants an electric reverse gear, sir does. ;-p
    | ___ Salad Dodger
    \|^|/ ANORAK#17
  11. Nigel Eaton
    Nigel Eaton Guest
    Fucking right sir does. But sir doesn't have one and will have to get
    used to it.
  12. Nigel Eaton
    Salad Dodger Guest
    Top tip: Don't park it nose to kerb on a steeply cambered road.
    | ___ Salad Dodger
    \|^|/ ANORAK#17
  13. Nigel Eaton
    Nigel Eaton Guest
    Heh, that one I had figured out for myself.
    It's the required 180 degree turn on exiting (or, I guess) entering my
    garage that's proving a little challenging.
    Plans for a turntable are being mulled over even as I type.
  14. Salad Dodger wrote
    That works for any bike.
    steve auvache, Aug 31, 2004
  15. There must be an ex-Railtrack one going on Ebay.
    The Older Gentleman, Aug 31, 2004
  16. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Nigel Eaton
    Two 1/4" sheet circ plates, greased, with a bolt in the middle...
    simple.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Aug 31, 2004
  17. Nigel Eaton
    There's always the time-honoured two-beer-tray trick, one inside the
    other with a bit of oil in there too - stick the centre stand on 'em
    and round you go. OTOH, with 300kg revolving, it could be a bit
    unwieldy ...
    Pip, Aug 31, 2004
  18. It was somewhere around Barstow, on the edge of the desert, when the
    Aye.. beer trays are fine for lightweight bikes, but I think 1/4" plate
    would be needed just to make sure the ctr stand doesn't punch holes or
    dent the fucker.
    GS 850 x2 / SE 6a
